Question about Dryers
Washer dryer not drying clothes
My washer dryer is not drying clothes at all
    Problem Solver:
  • 14 Answers
Obvious solutions:
1. Check your lint screen to make certain it is clean
2. Check your vent hose to make sure that the hose is not crimped or blocked.
3. Check the exterior vent to make sure that there is no lint buildup there that is effecting the performance
The next two solutions are:
Check the thermostat and the heating coil to make sure they are working properly. If not, you may need to replace one or both. If you can obtain a service manual for your particular brand you should be able to follow instructions and make this repair yourself.
Good luck. I hope it is solved in the first steps!
Posted on May 19, 2009
Why is my hotpoint tcm570 tumble dryer leaving a puddle on the floor
Since no dryer I am aware of uses any liquid, I suggest you may be putting wet clothes into the dryer.
This can happen if the washer does not spin the clothes nearly dry. Many dryers have small holes in the dryer drum to let excess water flow out, I would guess that may be the case with yours.
Are your clothes nearly dry when they come out of the washer?
If not, perhaps the washer has a loose belt or has a problem with the "dry" cycle.
God bless your efforts.
Nov 02, 2015 | Hotpoint Dryers
My washer/dryer isn't drying clothes
this is all i could find on the internet and that is the manual not sure if its going to be of any help to you but you could go to this link and download the manual and see if it does help you out.
i think its the first one on the page.
candy alise go4w464 washer dryer not drying clothes Google Search
Oct 31, 2017 | Candy Washing Machines
I have a GE washer/dryer Model WSM2700RAWWH stack type and the dryer is taking very long time to dry the clothes. Please advise if it can be fixed. If not what will be best alternate washer/dryer stack...
first things first. if any dryer regardless of brand takes 2-3 hours to dry cloths 90% of the time it is your exhaust duct. take the exhaust duct off the back of the dryer and dry some clothes if the clothes dry fast then you need to have your exhaust duct cleaned. either DIY or call a professional
if it still takes a long time to dry then it could be the thermostats or the thermistor.
but in my experience its normally the exhaust duct.
Feb 10, 2011 | GE Washing Machines
Dryer will not Dry!
A conventional dryer uses 240 volts to heat air, which passes through the tumbling laundry, picking up moisture, which is then vented to the building's exterior.
Your dryer uses 120 volts to warm air, which picks up moisture from the tumbling clothes, which then passes through a vent pipe in the back right corner of the dryer where a cold water spray causes the moisture to condense, run to the drain, and then is pumped out of the washer/dryer combo. There is no exterior vent to the outside of the building. Drying with your dryer will take at least twice as long as with a standard dryer. You can wash large loads, but can only dry small loads, and the clothes will not be as dry when dryer is finished as they will be with a standard dryer.
All that said, to make sure your dryer is performing as well as it can, you might like to take the back cover off and check the elbow at the very left bottom corner (when viewed from behind) to make sure nothing is obstructing the flow of water under the tub to the drain.
Aug 21, 2009 | LG WD-3243RHD Front Load Washer / Dryer
Washer-dryer # wm3677HW will not dry,heats up, run, on and on
You're a moron. This unit washes and dries. That's the whole point of it. Perhaps you should do some research before answering the question. the most likely cause is the water lever sensor.
Aug 09, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Hotpoint bwd129 washer dryer won't dry my clothes.
my Hotpoint dry will not dry my clothes. It will run for hours and the clothes still haven't dry just felt hot.
Oct 05, 2008 | Washing Machines
My indesit widl126s
my washer works fine but the dryer wont heat up or dry the clothes it goes onto dry but all the clothes are still coming out wet and the drum is cold
Apr 01, 2008 | Washing Machines
Cloths not getting dry
id look into a clogged and or kinked exhaust vent. perhaps where it leaves the home theres a screen over the housing thats clogged itself w/lint. its generating heat, thats good now just needs to release it somehow
Mar 16, 2008 | Washing Machines
Clothes dryer
washer dryer and dryer ony machines differ in a huge way. the big diff. is the drums on each are completly different sizes. the conventional dryer has the bigger, giving better air flow and tumble to clothes. the w/d has a smaller drum thus less air flow and less tumble between clothes. the best way to see this effect is remove half the clothes after a wash and then select a drying cycle. u will see that by giving the clothes more room to tumble free of each other rather than tumbling in a large ball will dry them. washer dryers are really only a marketing tool.
(ex main brand engineer)
Nov 12, 2007 | Candy DQW150 Front Load Washer / Dryer
Dryers Logo
128 people viewed this question
Top Dryers Experts
