Question about Whirlpool RBD305PD Electric Double Oven
Whirlpool double oven control panel blank RBD245PDQ14
  • 833 Answers
SOURCE: Whirlpool Double oven - control panel stopped working
Atlanta...sounds like you may have a power supply problem or the panel is bad. Cut the power, open the unit up and see if there is a fuse in there or a reset. No good? Then replace the circuit board. They just, well, die sometime. Happened to my microwave. Some units may be available remanufactured. Look around on the web.
Posted on Dec 07, 2007
  • 1314 Answers
SOURCE: Display F2 E6 error, then dead. Keypad realted? How do I remove control panel?
fiest press the on key see if the display comes if not the turn the power off for 5-8 seconds if that doesnt do it turn power off then pull the oven out from the wall and remove the top to acess eoc pull the mylar ribbion out of the eoc by releasing the latch which is a tiny pullout bar at the base of the connector at the eoc then you cam clean the ribbon gently with a clean pencial eraser also under the top panel will be a tech sheet with more info pay atten to resseting the oven cavity size on start up
Posted on May 16, 2008
SOURCE: Dead Whirlpool Double Oven
This happened to us the first time we used the self-cleaning feature. The repairman said we had to replace the whole electronic panel -- but when he put in the new panel it didn't work either. It turned out he just needed to replace the oven shutdown thermal fuse I believe. We finally got up enough courage to try the self-cleaning again and the exact thing happened. The door is locked and the electronic panel is dead again. So when we get it fixed we will never use the self-clean again.
Posted on Dec 05, 2008
SOURCE: how to remove the control panel on Whirlpool double oven Model RBD305PDS14
Emge & Associates is investigating gas and electric ovens manufactured by Whirlpool, including such popular brands as Whirlpool, Jenn-Air, KitchenAid and Maytag.
The firm is investigating reports that the electronic control panel on certain models is subject to failure after a limited number of uses of the appliance’s “self-cleaning” setting. While most foods are cooked at temperatures reaching 375 degrees, the “self-cleaning” setting raises the interior oven temperature to 1,400 degrees. Due to defects in the design and or manufacturing, the electronics contained on many ranges are damaged by extremely high heat. Repairs to damaged control panels typically cost in excess of $300 per replacement.
If you have experienced failure of the control panel in your range after using the “self-cleaning” setting, you can join this investigation by contacting Emge & Associates at (800) 629-3409 or (619) 618-2974.
Posted on Dec 19, 2009
SOURCE: Whirlpool electric double oven #RBD305PDQ14 control panel blank
The control panel part on my Whirlpool double oven (part #8302319) went blank six months back. Replaced it. Asked if there was a warranty on the part, was told no there was not. Yesterday, the six month old control panel went blank. Disappointed that Whirlpool manufactures such garbage.
Posted on Feb 01, 2010
No power on double oven after a storm
I have a RBD275PRS00 built in double oven. Had an electric
www.fixya.com/support/t8971528-rbd275prs00_built
Apr 16, 2011 - Had an electric storm the other night and ever since the oven won't -Whirlpool ... Question about Whirlpool RBD275PR Electric Double Oven ... For an oven to require parts after 2.5 yrs of service and 2 self cleanings tells me ... fiest press the on key see if the display comes if not the turn the power off for 5-8 ...
Whirlpool panel buzzing Ovens Questions & Answers - Fixya
www.fixya.com > Forum > Tags > panel buzzing > Ovens
Whirlpool ovens panel buzzing related questions and answers. ... the control panel on my Whirlpool electric double oven Model is RBD305PDS14? ... No power on control panel During self clean cycle the power to the panel went out. ... panel the instrument panel on an oven won't change time because of a storm problem.
Jan 01, 2016 | Whirlpool RBD275PR Electric Double Oven
What is wrong with my Whirlpool Double Wall Oven-Mod RBD305PDB8? Control Panel is blank. Light & timer works. Nothing else. Breaker ok.
This is a symptom of a common control board failure. Although your board has been discontinued by Whirlpool, your original EOC electronic oven control can be rebuilt. See here for details:
http://www.fixyourboard.com/boards/8302319.html
or here:
http://www.fixyourboard.com/boards/4451991.html
Sep 01, 2015 | Whirlpool Ovens
Rbd275pdb12
Control Panel has likely failed (circuit board). You can try removing the power wire from the back of the panel and then replug it back in to see if it resets the board, but Im sorry to say your likely going to have to remove and replace the control panel.
Dec 02, 2013 | Whirlpool RBD305PD Electric Double Oven
WHIRLPOOL double wall oven has a blank control screen the start button is the only button that beeps
Their is a small in line fuse going to the oven control. Service manual
6b484ffa-e6f8-4c65-aa67-df87a903038a.pngPage 4-2 shows how to get to it. Radio shack has the fuses
Nov 24, 2013 | Ovens
My whirlpool double oven accubake GBD307PDS09 display went blank!!!! HELP!
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty. GBD RBD Whirlpool Oven Problems Causes and Solutions
May 03, 2017 | Whirlpool GBD307PD Electric Double Oven
Hi--my whirlpool double oven,model gbd277pds10 all of a sudden has a blank panel ,nothing works ,when you touch a command it just beeps, can anyone help me, please..
Getting beeps when you push the keypad buttons means that power is getting to the control board. First, try shutting off the breaker to power down the oven for a few minutes, then turn back on. This will force a system reset, hopefully the oven will recover.
If not, you probably have a problem in the control board. If this is the case we may be able to save you some money if you can get the board pulled. We repair oven controllers at www.fixyourboard.com
Sep 10, 2009 | Whirlpool GBD307PDS Electric Double Oven
Whirlpool Accubake System Mod.# RBD275PB10 front panel blank
Hello Edward!
May 13, 2017 | Whirlpool RBD305PD Electric Double Oven
I suspect a poor connection at the wiring to the EOC is the cause of the failures.
Apr 21, 2017 | Whirlpool RBD305PD Electric Double Oven
Dec 06, 2007 | Whirlpool RBD245PRS Stainless Steel Oven
Whirlpool RBD305PD Electric Double Oven Logo
81 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
