Question about Exercise & Fitness
My treadmill oma-117m show E02 error and keep beeping
5 Suggested Answers
SOURCE: Carl lewis treadmill
I also have this problem. I rang Carl Lewis Support and they said to check the connections on the circuit board (Located in the floor panel next to the motor). If the treadmill had recently been moved something may have been dislodged. I checked mine and found a few loose wires and plugged them fully back in but this didn't help my treadmill. I'm awaiting a response from an e-mail i sent them now.
Posted on Jul 26, 2009
mark24354
  • 776 Answers
SOURCE: The machine keeps saying E02.It
There are only a few manufacturers of treadmills and they put a bunch of diffierent brand names on them. The E02 error is most likely a "no power to motor" error. Open it up and make sure the electical connectors to the motor are firmly attached. Hopefully this the problem and it is easily solved.
If it is more than just the wire attachement, it might be the fuse for the motor or, a bad motor control panel (this would be the most expensive option and likely not worth replacing. Look for a glass fuse (glass tube with metal on each end) and see if it is bad. The elevation motor might have a separate fuse so look for both.
Good luck
-Mark
Posted on May 22, 2011
ercupa190
  • 12223 Answers
SOURCE: lifetrack OMA-117 treadmill constant beeping not moving
1) adjust the REED swithc , see the diagram clean , and tight the wires connector very well.
2)Try to RUN the software calibration for diagnose, and troubleshooting.
God bless you
Posted on Jun 30, 2012
ercupa190
  • 12223 Answers
SOURCE: Get an e02 error every time I press start on my hyper extension treadmill
Replace the old battery from display board
2) clean the contacts batteries+adjust the REED swithc see diagram
3) tight the ribbon cables and clean it
4) LUBE the deck belt and rollers bearing
5) Test the motor and see the control motor board see the b.diagram
Posted on Mar 05, 2013
Error message E02 on Reebok ZR8 Threadmill - please help if possible
If you wish to get some details about treadmill error codes ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Dec 01, 2016 | Exercise & Fitness
Why does my t210 treadmill stop and then come up error e02?
Hi this is due to the treadmill's belt speed loss.
This happens if the motor is faulty or if the belt is stopped suddenly due to too much weight on it or misuse.
I would have the motor checked if I were you.
Feb 08, 2016 | Exercise & Fitness
How the error e02 on fit king treadmill be repaired
Dear sir,
I am having a treadmill of Fitking model no. W590 it is showing error code e02.
Kindly suggest what to do. I am eagerly waiting for ur response
Rgds
Yash Pal
Jul 15, 2013 | Exercise & Fitness
Sierra motorized treadmill with e2 code error
E02" You may not have enough voltage going to the machine. Turn the machine off and on
again at the switch at the rear of the treadmill. If this does not fix the problem you may have lower board problem see the diagrams attached and fix it.
God bless you2_4_2013_6_08_21_pm.jpg2_4_2013_6_09_23_pm.png2_4_2013_6_09_37_pm.gif
Feb 04, 2013 | Exercise & Fitness
Lifetrack OMA-117 treadmill constant beeping not moving
God bless you
Jun 29, 2012 | Exercise & Fitness
It keeps beeping and the speed display has e02 in it
hi,
first of all check the speed sensor of ur treadmill. u can see it near the motor pulley . clean it and re fix it. and then try again. if the problem remains, there will be problem with ur motor driving card. may be the motor driving igbt have some problem. be sure to take proper care before doing any thing in the motor driving card, chances to get electric shock. replace the igbt if found faulty. also check its gate driving transistors also.
ok
Jan 03, 2011 | Exercise & Fitness
Jul 06, 2009 | Exercise & Fitness
Candence 825, motor not driving belt, smells of burning
Hi Jill, have you found a solution yet as I seem to be getting a sililar error. Do you get a E02 message and a beep. Thanks Nicky
May 18, 2009 | Cadence Weslo 825 Treadmill Walking Belt
Exercise & Fitness Logo
171 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
