Question about Kenmore Washing Machines
Leaking water kenmore washer is leaking. started a few weeks ago as a very small leak, coming out under the front. yesterday water started pouring out as soon as i started it. we checked hoses and found no leaks. when we lifted/tipped it up, and saw water coming from above the motor. Any idea what is causing this and how much parts might be?
    Scholar:
  • 85 Answers
Your pump is leaking. it is attached to the front of the motor. Very common. Pump retails around $60.
Part number is 3363394
Posted on May 20, 2009
1998 Chevrolet Cavalier 2.4L losing coolant quickly
Stop Leak--can't get that out & it will plug the heater core
& other things --- bad move.
Why are you driving a car with any coolant leaks?
You may have ruined the motor by now
We can't find your leak from the internet or guess where it is
Mar 15, 2014 | 1998 Chevrolet Cavalier
My Kenmore Elite front load steam washer started pouring water from the detergent dispenser
It might be needed to remove the panel to get access to the tubing , please check this link for tips to check this out: dispenser
Jul 05, 2012 | Kenmore Elite Washing Machines
My kenmore washer has just started this week leaking water underneath somewhere!! I noticed water down the side next to the wall & behind the washer. I then placed a few small towels behind & down...
This is either your water pump, inlet valve, or you have a hole at the top of the outer drum. Try using the small load water level, if no leaks try medium. Also try seeing if the hoses are leaking. I also have seen mice bite holes in the drain lines. I hope i have helped you. God bless!
Aug 20, 2010 | Kenmore 26442 Top Load Washer
Washer leaks water in the back of the washer but i cannot see any signs of the leak. this is a front load washer . model 970 ca0042 00,
I have a Kenmore front loading washer HE2 Plus.
Started leaking only 6 months old from the back over the spin motor.
I found a bolt had come out of the motor bracket causing the motor to crack a small hole in the plastic outer drum. I've been down for about a month waiting on the part and service. This is under warranty and we cant get any help any sooner from sears, not even a loaner.
Will not purchase Kenmore products again, 2nd front loader from Kenmore, 2nd problems.
Oct 14, 2009 | Kenmore Washing Machines
I have a Kenmore 80 Series washer that started leaking just a little a few weeks ago. Checked all the exterior hoses and they are fine. Today it leaked worse. It appears to be coming from the front not the...
You have a hole in the water pump.
You need to remove the control panel.
Locate two gold clips, one on each side of the unit.
Remove clips, open the lid and pull the cabinet toward you. Water pump is right in front at the bottom.
Sep 03, 2009 | Washing Machines
Kenmore front load washer
check teh rubber seal on teh front door. They sometimes leak down the front of the door.
Jan 14, 2008 | Kenmore 44832 Front Load Washer
Water leaking when when washer is running a large or super load
the leak could be coming from anywhere in the washer it just leaks out from the lowest point of the washer i would suggest placing a putty knife under the top on the right and left side and pushing the tabs in to pop off the front panel to see where the leak is coming from
Oct 30, 2007 | Kenmore 24872 Top Load Washer
Water leaking
Leaking pump or drain connexion most likely you will have to get under to check it out. Put a several sheet to news paper under the machine and pull it out as it stands to see where the water is coming from front/back/sides Do a wash and repeat. But you will need the service of an engineer I guess unless you are good with a wrench.
Aug 05, 2007 | Kenmore 43142 Front Load Washer
Slow leak in our HE 3T Washer?
khorak, I've seen this on this model a bunch of times. The inlet valve is weeping water. You need to change it out. The top has 3 screws in the back and it will slide off toward the back. The valve sits on the left side, right up on top. Easy job, part number is 8181694. Catriver
Jun 23, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
139 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
