Question about Vacuums
My shark rotator will not turn on is there a reset button?
HELP!!!! I have a shark rotator lift away vacuum that the brush will not spin, the belt is intact and it just won't spin what is wrong ?? I tried resetting the button on the outlet bt not the proble
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Shark replacement parts for your Shark vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=shark
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Jan 05, 2017 | Shark Vacuums
ON THE SHARK ROTATOR PROFESSIONAL, WHERE IS THE RESET SWITCH?
do you mean how to make it run again after , example my carpet had a long string and i accidentally sucked it up well, until the machine stopped ? if this is sounding familiar try to check the brush roller remove whatever you find and it should turn itself back on
if that is not the situation please let me know i will be happy to find additional info for you if possible
Dec 06, 2016 | Shark Vacuums
Shark rotator will not power on
Your Shark vacuum is equipped with a motor protective thermostat. If for some reason your vacuum overheats, the thermostat will automatically turn the unit off. Should this occur, you would need to restart the motor thermostat. Turn off your unit and unplug the vacuum from the power. Clean the filters and dust cup filters. Check for blockages in hose, accessories and inlet openings. Then allow the unit to cool for a minimum of 45 minutes before plugging it back and turning it on.
http://www.thinkcrucial.com/search?type=product&q=shark
Ava B.
Sep 15, 2016 | Shark Rotator Lift-Away Professional HEPA...
My shark proffesional nv502 vacuum wont power on. My daughter sucked up a sock and it shut down to avoid overheating the motor I guess. Well--3 days later andit still wont turn back on. Is there a reset...
it should start after awhile is it the whole machine or just the brush bar. oh there is no reset from what i read.over heat motor it shuts down till it cools.
Feb 08, 2015 | Shark Rotator Professional Lift-Away...
CAN I BUY A REPLACEMENT MOTOR FOR A SHARK ROTATOR VACUUM ?
Yes you can buy motor for Shark Rotator Vacuum. But it is not available online. You will have to contact customer care department of Shark Rotator. Dont worry about warranty. Even if your product has lapsed warranty period, Shark will provide you motor after payment to its maintenance person who may visit your home if required for installation.
Oct 04, 2014 | Vacuums
Why is my Shark nv500 vaccum carpet brush is not spinning?
I am having the same issue. The brush won't even move when I turn it with my hand. I just posted this same question.
Aug 01, 2014 | Shark Rotator Professional Lift-Away...
Beater bar is not working
Shark Rotator Troubleshooting - YouTube
? 10:35
www.youtube.com/watch?v=H_dovG2javs
Oct 23, 2012 - Uploaded by VacBin
I show you how to fix common problems with the Shark Rotator..... I have Shark Rotator Prof Liftaway and ...
Feb 01, 2014 | Shark Rotator Professional Bagless Upright...
Shark rotator reset button
If shut off may be motor heated when it cools it should start buy its self
Dec 30, 2013 | Euro-Pro NV22 Shark Navigator Bagless...
Vacuums Logo
1,246 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
