Question about Sharp Office Equipment & Supplies
Printer will not copy although we can still print documents sent from the computer.
Sharp AL-1655CS stopped copying . We can print when sending documents to the printer. Why can we print but not copy?
  • hayden du plessis
    hayden du plessis May 11, 2010
    A little more info please.....
    Does the copy button work ? does it make a noise? does it try to copy?
  • 469 Answers
Is it infax mode?
Do you get a green Start Button?
Are there any error codes diaplayed when you push the button?
If no to these, unplug the machine for several minutes and restart.
Hope this is of some help
Posted on May 20, 2009
I have a Sharp AL-1655CS and when i make copies, the copies are really dark. For example, the white areas come out gray and dark. How can I fix this problem?
I would try a different toner cartridge or possibly a drum cartridge. Have you had the machine serviced at all? When?
Feb 14, 2011 | Sharp AL-1655CS Laser Printer
Cannot scan using Sharp AL-1655CS
Make sure that you install the driver for your operating system. Check the stop of the scanner under copying table to the left.Do installing the equipment from panel of management. Check in "system" of the "panels of management" consumption resource of your printer and scanner. The Driver of the scanner is fixed from printer apart. Arouse update the drivers in accordance with your operating system.Windows or Vista or Linuks on put www.sharp.com
Oct 07, 2009 | Sharp AL-1655CS Copier
Copier says ready to print. when button is
you will require to check several things like ink toners alignments and settings try resetting the wholesystem. top of all there may be some software problem try reinstalling the softwares if it is connected to computer
Jul 21, 2009 | Sharp AL-1655CS Laser Printer
Error code E7-11
CCD drive circuit (CCD PWB, ASIC harness) trouble
Copy lamp lighting trouble (Copy lamp, inverter PWB)
OR the scanner shaft is dirty. Clean it and re-oil it with 3n1 oil.
Jul 17, 2009 | Sharp AL-1655CS Copier
Sharp AL 1655CS Grayscale Copier prints with black lines
Lines on copies can come from the optict area, charge grid and comb or the fusing roller. Stop the copy halfway through the cycle and see where the line starts to appear. If you see it as much as you do the rest of the print, it is either optical or in the drum charge unit.
Jun 26, 2009 | Sharp AL-1655CS Copier
Paper not feeding correctly
Is your scanner moving correctly and traveling to the proper position when using the document feeder?
How does it copy on the scanner glass?
Apr 10, 2008 | Sharp AL-1655CS Laser Printer
Single line printing in copy mode
CLEAN OFF GLASS ON TOP WITH WINDEX THEN RETRY COPIER
Jan 17, 2008 | Sharp AL-1655CS Laser Printer
Copies
I can't remember but there should be a button with the name above it No. of Copies press this then you will be able to enter 1-99 copies. The energy saver you can adjust within the menu to longer or not come on at all. This will be in your manual.
Thanks J
Jan 10, 2008 | Sharp AL-1655CS Laser Printer
Copy
there is some alighnment problem with adf contact technician
Sep 17, 2007 | Sharp AL-1655CS Laser Printer
190 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
