Question about OTC Digital Timing Light 3367
Gas is it possible to place t,d,c from wrong end when excelleratiing my car varies in the stuttering from running grate to puttering like gasping 4 gas
  • 5,660 Answers
TDC is Top Dead Center. This is when (For setting the timing) Number One piston is all the way up in the cylinder, and the Intake Valve has closed.
The Combustion cycle is about to occur.
(Four Stroke Cycle engine. Intake, Compression,
Combustion, Exhaust)
The spark plug will spark, igniting the fuel/air mixture, and shove the piston down.
To static time the engine you first remove the Number 1 spark plug. You then place a finger over the spark plug hole, trying to seal it the best you can. Then you have someone BUMP, the engine over, (Or use a Remote Start Switch), until the air pressure blows your finger away. (Not in as harmed!)
You will be observing the harmonic balancer, and the markings on it. You are looking for 0, or TDC on the balancer. What you may have missed, is that when your finger is blown away, the balancer will have gone Past -> TDC.
You need to turn the balancer back to TDC. It is too far forward.
If you keep turning the balancer forward, you will have the exhaust valve starting to open. You need the Intake valve almost closed. Turn the balancer back.
Posted on May 19, 2009
  • joecoolvette
    joecoolvette May 19, 2009
    Forward for a balancer, is the direction it normally turns. Turning it back, is the opposite direction.
Why does my mitsubishin galant stutter and ping when I accelerate?
A common cause is old plug leads, could also be the wrong grade of gas or a failing O2 sensor.
Aug 07, 2014 | 2000 Mitsubishi Galant
I have 2002 nissan xterra it will run if I give it gas but when slowing down and coming to a stop it will putter and shut off what is the problem
check fuel injectors, possibly clogged, also change fuel filter and another is a possible, fuel pump inside the gas tank.
Nov 07, 2012 | Cars & Trucks
Lawn mower runs and then putters down, won't die but runs slow.
clean the air filter,wash out in turps if foam type,then wash in soapy hot water,then rinse,let dry,then put litle bit of clean engine oil in it,squeeze.drain all fuel,and put fresh in.may have to pull carb to bits and blow out,and reassemble.put new spark plug in.is it a briggs engine,or tecumseh?
Jul 11, 2010 | Garden
Pinging noise from the the engine
Pinging is a sign of low octane fuel in the tank or the engine may have jumped time if the vehicle has high mileage, I believe the Lincoln has a timing chain rather then a timing belt, the chain is much stronger and lasts at least double to triple the amount of mileage a belt lasts.
Have a shop run a timing strobe on the crank to see where your timing marks are in respect to the factory requirements, if the car is timed properly and there isn't anything wrong with the gas in the tank(try adding an octane booster to see if that helps allieviate the ping) then test the computer system for any possible codes, perhaps the 02 sensor is bad or the I.A.C.(Idle Air Control Motor) is defective causing the engine to run too lean and ping, a code stored in the computers memory will reveal this.
Jun 09, 2010 | 2002 Lincoln Continental
I am trying to remove the shaft from an Odyssey 2-ball putter and can't get it off. I have used a heat gun and a tourch to no avail. It appears to be an "over the hosel" attachment but none the less the...
Rosemary, I found a broken Ping putter in the trash can and took it to a golf repair place and they put a new shaft in for not too much money and it was a great putter for many years before I needed a belly putter to help me keep the putter more steady.
Nov 13, 2009 | Odyssey Steel 2 Ball Srt Putter
Buick Century 97 runs rough and stutters when cold and gas applie
Your cat should last quite a while now it is replaced. I recommend testing coil packs and module. Change plugs and wires and double check your vacuum hoses.
Aug 14, 2009 | 1997 Buick Century
1996 Cavalier--PLEASE HELP
Maybe try to replace the map sensor and the oxygen sensors
Jul 26, 2008 | 1996 Chevrolet Cavalier
OTC Digital Timing Light 3367 Logo
103 people viewed this question
Top OTC Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you an OTC Measuring Tool and Sensor Expert? Answer questions, earn points and help others
