Question about Elite Epm250 Popcorn Maker
Failure to heat
Popcorn maker is not getting hot. over 8 minutes has passed and still no heat. whats the problem?
Popcorn burns
tim, heating corn longer will cause burns. So, reduce heat or if using popcorn packets, heat for 1.55 minutes and you will get great results.
Feb 18, 2015 | Kitchen Appliances - Others
Base doesn't get hot
You cannot repair home model poppers, return to store or replace.
Feb 10, 2014 | Cuisinart CPM-900 EasyPop Popcorn Maker...
Model 39A gets too hot too fast
That model has a thermostat (also called a high limit) that is set at 450F. it should produce a popping cycle of 3 mins, and yes will burn popcorn if you don't dump it fairly quickly.
The speed it heats cannot be too fast, there is only so many watts in the heat element. it may go to hot, but never to fast.
The best way to test temp is time the 2nd popping cycle with a stop watch. the second batch should be 3 mins +/- 30 seconds. if it is 4 mins it is too cold. a 2 min popping cycle is to hot.
A popper that is too cold is also popping poor quality popcorn, higher amount of unpopped kernels, and small chewy popcorn.
Measure carfully when doing time test popping. That model is 2oz oil, 6oz popcorn, and 1 tsp salt. Start timing when you put ingredients in, and stop when you dump it. The kettle must be hot, that is why you time the 2nd batch.
May 20, 2013 | Star 39 JetStar Popcorn Maker
Elite Epm250 Popcorn Maker instructions
Turn on the heater and let heat for 2-3 minutes. The Elite EPM 250 popcorn maker uses a 2.5 oz kettle. This is for 1/3 cup of uncooked kernels. Add kernels with a tablespoon of popcorn oil (available in markets) and a 1/3 teaspoon of what's called "Flavacol". It's a seasoning that they use in movie theaters to add flavor, saltiness and color. It's available online (ebay) or at Smart and Final. Use this combo and you can't go wrong. For cleaning, let kettle cool, the add 1/2 cup water. Turn on kettle and let boil for 2-3 minutes. Then empty it out.
Jan 15, 2012 | Elite Epm250 Popcorn Maker
The popper gets hot for th first batch then the heating is rather hit and miss.
There's a thermostat inside that controls the temp of the heating surface. It has to thoroughly cool after making a batch. Probably 10 to 20 minutes.
Dec 06, 2010 | West Bend 82306 Stir Crazy® Popcorn...
Use
Is the heater heating? Please check it ... Plug it into the outlet ... and put your hand GENTLY on the burner to see if it heats up. Of course, if it gets hot ... remove your hand.
I suspect the heater is not functioning 'pop'erly ...
Thanks for your interest in FixYa.com
Jul 15, 2010 | Back to Basics Disney Popper PD5 Popcorn...
The kettle will not get hot! The light comes on and the #1 and #3 switch both light up, but no heat!?!?!
We disassembled the kettle and noticed that the black wire had been disconnected from the base connector which is attached to the heating element. We re-attached the wire clip to the harness and it heated up on the first try. Please note that you may need to crimp the wire connector to the base for a stronger hold. My guess is that as we were moving the unit back and forth the wire connector had seperated.
Aug 11, 2009 | Maximatic Deluxe Popcorn Trolley Popcorn...
Popcorn kettle not heating up
You can call Nostalgia Products at 920-347-9122. They are open Monday thru Friday 8-5 CST.
Mar 02, 2009 | Nostalgia Electrics CCP-509 Popcorn Maker
Cooking Pot Return Problems
I use an old heavy 3-quart alumnium sauce pan with a loose-fitting lid, canola oil, and high heat with about 1/2-cup of standard grocery-store yellow popcorn. I get the empty pot nice and hot, add the oil, then the corn, then the pot lid. I shake it occasionally, but basically let it go until the lid starts to rise off the pot, and I don't hear any more pops. Pour it into a large bowl, toss it with very fine sea salt, and go to town! It's also fantastic made with bacon fat, but you need to use slightly lower heat to keep it from burning and prepare for visitors: The smell of popcorn and bacon fat draws crowds.
Feb 16, 2008 | Paragon 1911-8 Popcorn Maker
Westbend hot air popcorn maker
Method One
  1. Pour a quarter cup of popcorn kernels into a paper bag.
  2. Fold the top of the bag three times.
  3. Place the paper bag in the microwave.
  4. Set the timer for 40 to 60 seconds. (mine took 3-4 minutes)
  5. Wait and have fun.
  6. Remove the bag and pour the popcorn into a dish.
  7. Cook unbaked kernels for about 15 to 20 seconds.
  8. Add the extra popcorn to the other batch.
  9. Pour melted butter and salt onto the popcorn.
  10. Serve.
Method Two
  1. Take a frying pan and a fitting lid.
  2. Put some grease (canola oil for example) in it to make sure your corns won't stick to your pan.
  3. Wait until the pan is hot--you can add 1 or 2 kernels to the pan as it heats up... when they pop, the pan is hot enough to add the rest of the corn
  4. Put in the corns, make sure you use corns which are meant to use in a pan.
  5. Put on the lid fast! Make sure no corns flip out. Shake your pan a few times to make sure all corns are loose.
  6. Now you hear a lot of pops, just wait until all sound is gone.
  7. When nothing happens quickly take of the pan and put your corns in a bowl.
  8. Put on salt/sugar.
  9. Serve.
Method Three
  1. Buy some microwave popcorn.
  2. Follow the instructions.
  3. Serve.
Nov 18, 2007 | West Bend 01568 Popcorn Maker
Elite Epm250 Popcorn Maker Logo
42 people viewed this question
Top Elite Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Ruth summersides
Andrew Taylor
Andrew Taylor
Are you an Elite Kitchen Appliances - Other Expert? Answer questions, earn points and help others
