Question about B&K Plumbing
How to adjust hot water on a B&K one lever shower faucet. When lever is at its highest on HOT the water is only luke warm.
  • 68 Answers
SOURCE: Single handle Pioneer shower faucet
its the mixing slide in there its stuck u can take it apart at the handle it pulls out shake it if it doesnt move its bad. what happens is over time sediment gets in there and seazes it up. if you take it apart and its not stuck then its ur mixing valve on your boiler is bad good luck
Posted on Dec 21, 2008
  • 10 Answers
SOURCE: No hot water pressure on kohler bath / shower faucet
Try draining the system and apply air pressure (min 30psi) to each faucet. Open other hot water faucets to allow pressure to vent. Next try draining and cleaning the hot water tank.
Posted on Oct 24, 2009
  • 186 Answers
SOURCE: No hot water or pressure at shower head
Hello. No Poltergeist involved! These valves have an anti scald feature. I'm sorry but I'm not familiar with your particular handle type so I've included a link to Moens site. Click the link and look about 2/3 of the way down and find the downloads for your product. The information you need is on page 5 of the document.
builderdale
Posted on Mar 02, 2010
woodchuck789
  • 4070 Answers
SOURCE: hot water on bathroom faucet won't get hot only luke warm
That is a type where the water is mixed inside the valve and the valve has gotten worn or loose inside. Replace it or take it apart to see what isn't working properly.
Posted on Apr 12, 2010
SOURCE: Cold water is leaking on to hot side causing luke warm water
i have a 7570 salora that took the top off and i can't get it back together right
Posted on Jul 30, 2010
Warm water in shower and cold in sink
How long has this been like this? Have you replaced any faucets, or have you installed a new water heater recently?
Jan 17, 2013 | Home
My gas shower is either luke warm or very hot whats wrong
If all the other faucets work, then the problem is the mixing valve in your shower. You will need a new shower fixture.
Apr 10, 2012 | Bosch Water Heaters
When turning on the hot water on dedicated hot water faucets, the water is almost scalding. However, when turning on the shower and tub that has only one faucet handle (mixes cold and hot) and put the...
Pull apart the front of the valve and there is a limiter that is set to limit hte hot water, you need to adjust that limiter. I find many valves are shipped with teh setting too cold.
Oct 09, 2010 | Delta & Single Handle Shower Faucet
I turn it all the way towards the hot but my water will only get luke warm. i try tried to fix it myself but only got as far as unscrewing the base.... Can you tell me what to do?
Take handle off of shower faucet and it will have a dial to remove and adjust to proper flow. Just remember where it is at. Remove it and move it about 1/8 to 1/4 turn counter clocwise and reinstall to increase to hotter temp.
May 21, 2010 | Moen Posi-Temp Single HandleTub And Shower...
How do you adjust temp. water luke warm? This is a single handle. Hot water set at 145.
These type faucets have anti scald dial setting that if you remove the handle you can gain access to it.
Just remove handle and mark or remember where it is and pull it out and reinsert it about 1/4 turn counter clockwise.
It has got marks on it and looks like a little gear.
May 19, 2010 | Danze & Single Handle Tub And Shower...
Hot water on bathroom faucet won't get hot only luke warm
Apr 12, 2010 | American Standard Bath Faucet Ceramix...
Mira Sport shower running luke warm
Your hot water must come from your coil in boiler and not from a seperate hot water heater - more then likely furnace hasn't been on for heating your house nor has it been on for any draw of hot water. You have to wait till it goes on and brings the water temperature up to your setting or get a hot water tank put in or a new type wall mounted gas instant hot water unit.
Mar 14, 2010 | Home
Feb 19, 2010 | Moen 7065 Vestige Single-Handle Kitchen...
The temperature in my shower is very luke warm only at the shower
Do you mean the other faucets in the house are hot and only the shower is warm? If so there is an anti-scald adjustment on the faucet that needs to be turned up a few notches. Havent adjusted a Grohe faucet but most faucets you rmove the handle and behind the handle is a nothced adjustment ring that prevents the faucet from getting too hot. This ring, or stop, is pulled out and twisted clockwise(or counter clockwise to set higher or lower max temp, then pushed back. maybe you can look up grohe to see which way ring or stop adjusts for hotter water.
Jan 23, 2010 | Grohe Integrated 1/2'' Shower Thermostatic...
Oct 07, 2009 | Kohler K-T10335-4-CP Lyntier Rite-temp...
Plumbing Logo
54 people viewed this question
Top B&K Plumbing Experts
Tom Chichester
Bill Boyd
Daryl Gleaton
Are you a B&K Plumbing Expert? Answer questions, earn points and help others
