AUVIO Full Band FM Transmitter for iPod/iPhone Logo
A
Anonymous Posted on Dec 30, 2013
It will not transmit with my Ipod but works with my Iphone
How to acess a disabled iphone 4's information
when you enter wrong passcode many time than your iphone will be disabled locked. and only option available is restore iphone with recent backup. so you wont lost much data.
Below trick is working with ipod you can try it with iphone and at the end of the post i have given detail procedure for how to restore iphone without deleting data.
First try to recover your password for that connect your iphone to computer via usb cable.
Now ipod iphone is recognize by computer and find the folder named ipod. Now browse ipod folder and open ipod_control folder , inside that folder there is ipod _unlock file. Try to edit that file with some software to recover your password inside that file otherwise. Delete or rename that file and power of your ipod and restart it. There is other way to recover password but when I put such answer my answer marked as spam and deleted and some senior member using that answer method for their answer and get reputation.
Ipod got disabled when you have entered wrong passcode many times. And to unlock this passcode either recover your passcode from ipod or restore your ipod via ituens.
For that connect ipod to computer and if ipod is recognized by computer then open itunes click on device tab then summary tab on right side pane you will find restore ipod.Click on restore ipod and ipod will be restored but this will erase all data on ipod.
If you don't want to delete data then there is option to restore ipod from backup. So restore ipod from recent backup. For that open itunes - click on devices and right click on ipod there you will find option restore from backup.
If none of above method can solve your problem then enter into dfu or recovery mode. For that connect your ipod via usb cable to computer and thenPower off your ipod, now press and hold power button and home button for 15 seconds, now release power buttonbut keep holding home button now itunes will detect ipod in recovery mode now restore your ipod. Ipad iphone restore without losing data
tip
How To Connect Your iPhone, iPad, or iPod To The TV
The following devices have support for TV out:
  • iPhone
  • iPad
  • iPod touch
  • iPod nano (3rd generation and later)
  • iPod classic, iPod (5th generation), and iPod photo
Note: Other iPod models may support viewing of photos or slideshows on the iPod display but do not support TV out.
The following docks support TV out when used with an iPod model or iPhone that supports TV out:
  • Apple Universal Dock (requires either the Apple Composite AV Cable or the Apple Component AV Cable-will not work with the iPod AV Cable). Search the store for part number MB125G.
  • iPod Universal Dock or iPod with color display dock (iPod photo dock)
Important: The iPhone dock does not support TV out.
iPod models that support TV out can support viewing on a television in several ways. Use the tables below to see which cables and docks can be used with each iPod model. Check the documentation that came with the cable or iPod for information on how to connect and enable TV out.
Note: If you choose to use a third-party cable, make sure it has the "Works with iPhone" or "Made for iPod" label. Learn more about iPod and iPhone accessories.
All you need to get TV out is a compatible iPhone, iPad, or iPod and the correct cable. If your device works with the component and composite cables, then the choice depends on the TV(s) you will be connecting to.
  • Apple Composite AV Cable (part number MB129LL) will connect any iPhone, iPad, or iPod to your TV using RCA Cables.
  • Apple Component AV Cable (part number MB128LL) will connect any iPhone, iPad, or iPod (except iPod with color display (iPod photo), and iPod (5th generation)) to your TV using Component Cables.
A dock can be a welcome addition if you're going to keep your cables connected to the TV. The Apple Universal Dock includes an Apple Remote so you can pause and adjust the volume from a distance. The docks and cables are sold separately.
tip
How to Transfer Files from iPod to Mac?
Normal 0 7.8 磅 0 2 false false false MicrosoftInternetExplorer4
What you Need...write.jpg Mac OS X v10.4 or above;
An iPod;
iMacsoft iPod to Mac Transfer.
Why Choose iMacsoft iPod to Mac Transfer...write.jpg iMacsoft iPod to Mac Transfer, the excellent iPod and iPhone management tool is specially designed for Mac users. It can fast transfer, rip, copy and manage your music, videos, photos, podcasts and TV Shows between iPod/iPhone and Mac and add them to your local iTunes library.
What can iMacsoft iPod to Mac Transfer Do...write.jpg s.gif Rip, copy and manage iPod music, videos, photos, podcasts and TV Shows between iPod/iPhone and Mac. Transfer files from iPod to Mac, iPhone to Mac.
s.gif Edit and delete iPod/iPhone playlists.
s.gif Copy files among multiple iPods. Transfer iPod to iPod on Mac.
s.gif Transfer iPod music, videos, photos to iPhone.
How iMacsoft iPod to Mac Transfer Working...write.jpg Step 1. Run software and click the "Add Files to iPod" or "Add Folder to iPod" button.
Step 2. Click "Open" button to import selected files to your iPod.
ipod-to-mac-localfolder.jpg Step 3. When following dialogbox appear, you have done that!
ipod-to-mac-4.jpg download0.gifFree Donwload iMacsoft iPod to Mac Transfer to transfer your files from iPod to Mac.
Normal 0 7.8 磅 0 2 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:普通表格; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
on Jun 01, 2010 • Computers & Internet
Iphone4 will not playing music through docking station Sony XDR-DS12IP... Iphone was working with system perfectly until sunday? still manages to charge iphone ? Iphone message iphone not configured...
first return sony and get ihome because sony is bad at docky station(not affending ps) or you can do is take it where you got it and bring the ios deviece and get it checked if it works congrauts if it doesn`t BUY IHOME.
How can I use JVC AVX810 with Iphone? Currently IPOD works fine with the USB cable but IPHONE is not recognised. Maybe there is an adaptor that can solve it?
JVC KS-PD100 iPod Interface Adapter (257KSPD100, sold separately). This optional iPod Interface Adapter supports audio playback for the following iPod models - iPod click-wheel (3rd gen), iPod photo (4th gen), iPod mini (1st/2nd gen), iPod nano (1st/2nd/3rd/4th gen), iPod video (5th gen), and iPod classic (80/120/160GB). The KS-PD100 is not compatible with the iPod touch (1st/2nd/3rd gen), iPod nano (5th gen), or iPhone (2G/3G/3GS). This iPod interface will also not charge the iPod nano (4th generation). *Apple firmware updates may change functionality results.
There u go.....
tip
How to transfer videos (any video format) to iPhone/iPod?
Many people get videos that download from the internet or received from friends. However, those videos are playable on PC but not iPhone/iPod. Why? iPhone/iPod supports following video and audio formats:
H.264, MPEG-4 in .mp4, .mov, .m4v formats, and MP3, protected AAC, AAC, Audible, Apple lossless in .aac, .mp3, .m4a files.
If you have a video that is not one of video formats above, then you can't watch it on your iPhone/iPod.
So, how to watch any videos on your iPhone/iPod? Normally, people try to get a video converter for iPhone/iPod and convert videos to iPhone/iPod supported video formats then synchronizing videos to iPhone/iPod with iTunes.
But it will be great if there is iPhone/iPod transfer that can transfer any videos to iPhone/iPod and make these playable on iPhone/iPod. No doubt, Wondershare iPhone Transfer can convert video and transfer video and music between iPhone/iPod without iTunes. Let's talk little more about it.
Wondershare iPhone Transfer features a simple and straightforward interface. It's a really useful tool for both iPhone and iPod users. You can transfer music to PC and transfer any video to iPhone/iPod without iTunes, as easy as drag files between two folders.
It allowes you to create/delete playlists on iPhone/iPod directly. User aslo can backup all ablums as a zipped file on PC for later restore.
The latest Wondershare iPhone Transfer supports iPod Nano 5G, iPod Touch3G and iPhone OS 3.1
It's also possible to download the Wondershare iPhone Transfer trial version, to try your first 100 files transfer for totally FREE.
on Dec 30, 2009 • Computers & Internet
When i put my IPhone 3G on dock it said that this accesory wasnt made for IPhone
This means your dock is not compatible with the iPhone 3G, or slightly compatible. I've had this problem with an FM transmitter in my car, I can use it to transmit my tunes to whatever station but I cannot use the charge features of the FM transmitter. Consult your manual for the dock about compatibility.
5answers
IPod Touch WiFi issue
  1. Tap Settings > Wi-Fi Networks, then pick the network.
  2. In the DHCP panel, select the Renew Lease button.
  1. Make sure you have an Internet connection and have installed iTunes 7.4 or later from www.apple.com/itunes. Apple recommends using the latest version of iTunes.
  2. Connect iPhone or iPod touch to your computer.
  3. In iTunes, select iPhone or iPod touch in the Source pane and click the Summary tab.
  4. Click "Check for Update." iTunes will tell you if there's a newer version of the iPhone or iPod touch software available.
  5. Click Update to install the latest version of the software. Or click Restore to restore iPhone or iPod touch to its original settings (this erases all data on iPhone or iPod touch). Follow the onscreen instructions to complete the restore process.
Top AUVIO Audio Players & Recorders Experts
 Mikey
Mikey
john h
ADMIN Andrew
ADMIN Andrew
Are you an AUVIO Audio Player and Recorder Expert? Answer questions, earn points and help others
