Question about Nostalgia Electrics Retro Microwave
Power is on,all lights are on but it does not turn on when i press the button
Can't get out of demo mode Westinghouse oven WVE916SA!
DEMONSTRATION MODE – PROGRAMMABLE CONTROLLER MODELS
For display purposes, the appliance has a demonstration mode to enable demonstration of oven functionality without consuming power. In demonstration mode, the display, the light and the fan only are operational.
When the appliance is in demonstration mode and the display is switched on, the clock symbol will be on.
If the appliance is in demonstration mode, to operate the appliance normally the demonstration mode will need to be deactivated.
To deactivate demonstration mode:
1. Ensure the oven is off by pressing the ON/OFF button. 2. Press and hold the ON/OFF button until the display turns
ON then OFF and a single ‘beep’ is heard. Immediately after press and hold the ‘Timer’ and ‘–’ buttons simultaneously, until a triple beep sounds to confirm
the operation.
Nov 15, 2013 | Microwave Ovens
Hello, I have an AEG microwave, 6 years old. When I turn the button to chose the cookingtime and the WATT , the display shows what I choosed so thats OK. When i then press the start button the microwave...
This can be due to wrong choice or fault in the power supply ,main board or the magnetron.
You should try with a preset selection and if the microwave works then the fault relates to correcting the power to time settings.
Check out with microwave cooking tips.
Feb 01, 2013 | AEG MC143EUX 750 Watts Microwave Oven
There is power supply to the micro however when turned on sounds like microwave is working before any buttons pressed and no buttons work when pressed. Also when door is opened display light comes on and...
Without a make and model number it is difficult to guess.
If the door switches are faulty, odd things will happen. I suggest they are checked first of all.
Feb 15, 2011 | Microwave Ovens
I have danby dmw112 1100 watts microwave that will not cook
i have power and light is on can not press any numbers or start button or any other button.it keeps on peeping steady
May 30, 2010 | Danby DMW112 Microwave Oven
EVM1750SMS has No power. Outlet is good
press the start/off button for 3 seconds see if it displays locked, if it does press again for 3 seconds to unlock then press the clock button and follow the prompts.
Mar 07, 2010 | GE EVM1750 Microwave Oven
I have Emerson Microwave #mw8999sv which has the Express Cook option- cooking 1 - 6 minutes. How do I cook for 1 minute 30 seconds, etc.? Thank you.
The owner's manual is here. On page 10 we find:
COOKING IN ONE STAGE
1. Press the POWER button; the Microwave and High
Cook indicators will light and “PL 10” will light in the
display.
2. Press the POWER button different times to set the
desired power; the display will show the percentage
you chose. If selecting power level 70%-10%, the
Low Cook indicator will light instead of the High
Cook indicator.
3. Press number keys to set the desired cooking time.
OPERATION(CONTINUED)
4. Press the START/+30SEC. button to start cooking;
the Microwave and one of the Cook indicators will
blink and the display will countdown the remaining
cooking time in minutes and seconds. It will beep
five times when cooking is completed.
Sep 08, 2009 | Emerson Microwave Ovens
Nostalgia Electrics Retro Microwave Logo
35 people viewed this question
Top Nostalgia Electrics Microwave Ovens Experts
William Miller
William Miller
Are you a Nostalgia Electrics Microwave Oven Expert? Answer questions, earn points and help others
