Question about Nippon Lrcr504bb Universal Remote Control Rca 4 Device
Code search brand - Nippon Lrcr504bb Universal Remote Control Rca 4 Device
Need remote codes for sanyo 32 tv using an uei universal remote control
Use code search to find something that works. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not contain all possible codes.
Jan 17, 2017 | Sanyo Televison & Video
Will a vizio xru100 control a sony smp200
If it has set-up code to Sony brand TV, you can. It will be better to do a code search procedure, if you're note sure about it. Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts.
Jul 27, 2016 | Televison & Video
Need RCA remote to turn a Toshiba TV need code
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Programming Notes
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Mar 06, 2016 | RCA Televison & Video
Code for RCA digital TV converter box my remote model number
Programming Notes
How to manually program onn remote
Programming Notes
Mar 06, 2016 | Televison & Video
Xfinity codes for yamaha rx-v1065 audio device
1273,1294. Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
Programming Notes
Mar 05, 2016 | Yamaha Televison & Video
I can't find the right Phillips brand for my codes ? It doesn't have the code search button. Only input?
Code search is a procedure that have to follow. There will be no such button marked as code search to no remote control. You should follow the instructions in its user manual to do a code search. Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
Nov 18, 2015 | Televison & Video
I have a oleia tv im trying to program my rca rcu403 but it wont work
your oleia tv code is 1610 OR 1240 OR 073
In order for the 3 component universal remote to control your TV you must program it with the TV code
that matches your TV These instructions explain the preferred method of programming the remote the
Direct Entry method 1 Manually turn on the TV
2 Locate the enclosed TV Code List. Find your brand of TV
Note If your brand isn t listed, use one of the Code Search methods to
program this remote control See Code Search on page 24
3 Press and hold the CODE SEARCH key until the indicator light
illuminates Then release the CODE SEARCH key
4 Press and release the TV key The indicator light blinks and then remains lit
5 Use the number keys to enter the first code listed for your brand.
After you enter a valid three digit code, the indicator light turns off
Note If you enter an invalid code the LED will flash rapidly for 2 seconds
Start over at step 3
6 Aim the remote at your TV and press the ON OFF key If your TV turns off
you have found the correct code
7 Enter the code in the box provided on this page for future reference.
8 If your TV doesn turn off repeat steps 3 6 above entering the next code
for your brand.
If none of the codes work or your brand is not listed use one of the Code
Search methods to program this remote See Code Search on page 24
For a description of each key on the remote control refer to the Key
Descriptions section
If your component s brand isn t listed in the Code List or you have tried all of the codes for your brand and
the remote does not operate your component use one of the Code Search methods below Manual Code
Search or Auto Code Search. Both Code Search methods search all of the codes because your component s
code may be listed under another brand in the code list.
Note The Code Search method may take a long time because the remote searches all of the codes in its
memory for the code which operates your component. Therefore, if your brand is listed in the Code List
use the Direct Entry method described Manual Code Search
1 Turn on the component you want the remote to operate.
2 Press and hold the CODE SEARCH key until the indicator
light illuminates. Then release the CODE SEARCH key.
3 Press and release the component key that corresponds to the
component you want the remote to operate TV
indicator light blinks once and then
remains lit
4 Aim the remote at the component and press the ON OFF key
continuously until the component turns off
Important Because there are so many codes, you may have
to press the ON OFF key many times possibly up to
200 times.
5 When the component turns off press the ENTER key to store
the code
6 Use Code Retrieval on the next page to identify the code for
your component for future reference
Nov 05, 2011 | RCA RCU403 Remote Control
Need code for a dynex tv
The code for the dynex is not listed you will have to do a search:
Code Search (by Brand)
Lets you search for a code for a specific
Brand within the Code Library for a
particular manufacturer.
1. Turn on the device (TV, VCR, etc.) to
be controlled.
2. Press and hold the CODE SEARCH
button until the red indicator remains
on, then release the CODE SEARCH
button.
3. Press and release the desired Mode
button (TV, VCR, etc.). The red
indicator blinks off once.
4. Press and release the numeric button
(0-9) corresponding to desired
Manufacturer (see table below).
Note, pressing “0” performs a full
library search same as Device Library
Code Search Method.
5. Press the CHANNEL UP button ((or
POWER or PLAY (VCR only))
repeatedly until the device to be
controlled changes channel.
6. Press and release MUTE to install
the code.
Note, when all codes under a Brand
have been searched the red indicator
flashes rapidly for 3 seconds.
Code Search (by Device)
If after trying “Direct Code Entry” or
“Code Search (by Brand)” your device
does not respond, or if your brand is not
listed, try doing a device search of the
code library for your code by following
the steps below.
1. Manually turn on the device (TV,
VCR, etc.) to be controlled.
button until the red indicator stays
button.
indicator blinks, then stays lit.
4. Press the CHANNEL UP button
repeatedly (up to 300 times) until
the device to be controlled changes
channel. The red indicator blinks,
then stays lit.
5. Press and release MUTE to install
the code.
Most users will want to store VCR
codes under the VCR button, Cable
codes under Cable, etc. If you want to
store a VCR code under Cable, etc., first
follow the procedure for Direct Code
Entry and press Cable in step 2 of
Direct Code Entry, then enter ANY
VCR code in step 3 of Direct Code
Entry. Then follow the steps above for
Brand Search or Complete Search.
Jan 12, 2009 | Philips PM3S Remote Control
Nippon Lrcr504bb Universal Remote Control Rca 4 Device Logo
53 people viewed this question
Top Nippon Televison & Video Experts
Electro Med Services...
Are you a Nippon Televison and Video Expert? Answer questions, earn points and help others
