Question about Whirlpool WTW6200S Top Load Washer
Whirlpool cabrio wtw6200swo unbalance - Whirlpool WTW6200S Top Load Washer
2 Suggested Answers
GodBlessU
  • 3513 Answers
SOURCE: i have a whirlpool cabrio washer wtw6200swo when
Hi
UL error means unbalanced load. In this case you have to rebalance the load and start it again.
Please check the link for whirlpool cabrio washer fault codes and the resolution that has been given in the chart:-
http://www.advantagesupplyfl.com/WhirlpoolCabrioWasherFaultCodes.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Jul 19, 2011
How do you remove the cover for Cabrio Platinum Top Load Washer to see if clothes have gotten stuck between wall & basket of washer. I can not wash one load without getting the UL Off Balance Code!
it is extremely unlikely that clothes have got to the position you mentioned
unbalance comes from
1--- clothes out of balance in the tub--too much on one side
2--machine not level on the floor --- rubber feet missing from adjuster bolts
3-- suspension rods and insulators for the tub broken or missing
these suspension rubbers/ plastics break on a regular basis and allow the tub to sit at an unlevel state causing an unbalance situation when spinning
top covers are either held in place with screws at the front and back ( under plastic trim buttons ) or simply clip on to the side walls at the top
talk with a service agent as to how to remove the top or download a workshop manual for the machine from the net
Oct 29, 2016 | Whirlpool WTW6400SW Cabrio Washer
Whirlpool Cabrio gets unbalanced load at 7 minutes
Make sure load is properly sorted with like materials and paired up, do not mix things like towels with pants or shirts all together as different items absorb more water then others and can create unbalance when trying to enter final spin. If issue continues, it is very possible and item of clothing may have found itself stuck between spin basket and outer tub. This is very likely scenario due to design of this washer. If that is the case, spin basket must be removed then remove clothing to resolve issues.
Jun 02, 2014 | Whirlpool WTW6400SW Cabrio Washer
Clothes inmachine alway needs readjusting due to unbalance and UL symbol keeps coming up.
It could be one of the suspension springs inside. Broken or jumped off
Apr 07, 2014 | Whirlpool Cabrio WTW6300SB
Whirlpool wtw6200swo model # ct2370895 serial # the tub on the washer is not spining, can you help?
Bad drive coupler or belt, this links the motor to the transmission, if it has failed then no spinning and or agitation.
GOOD LUCK !
Aug 26, 2010 | Whirlpool Washing Machines
Why does my Cabrio keep going unbalanced . It reads UL and the drum bangs around bad shutting the washer off.
dont know if this will help but try to me it sounds like an unbalance load view the load and try to redistribute the load good luck hope this works if not let me know scott8326@hotmail.com
Feb 17, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
What causes Cabrio washer to get unbalanced in spin cycle?
Try making sure that your draining hose isnt jammed all the way down the hole. When you installed it the u shaped accessory was needed for the draining hose. Try pulling the draining hose out...curve the front and zip tying it to your cold water valve. This will allow it to drain properly and not get water push back into the drum causing it to be unlevel
Aug 02, 2009 | Whirlpool WTW6200S Top Load Washer
Whirlpool WTW6200S Top Load Washer Logo
24 people viewed this question
Dan Webster
Dan Webster
Sal De
