Question about Konica Minolta magicolor 2430 DL Laser Printer
After replacing black toner cartridge printer displays Drum Low
Replaced black toner cartridge now printer displays Drum Low Minolta Konica magicolor 2300 DL
The drum and the black printer cartridge are two separate items. You will have to purchase a new drum for it. I just had to do the same thing and it ran me $150.00 at Staples.
Posted on Jun 01, 2009
Konica Minolta 7272 coad 29-04 how was the solve
Have the developer and drum replaced. Ensure tech clears the counters first before installing parts, and run required post checks while in the drum cart clean the sensors and remove old toner and developer. Your code is dealing with the drum and developer. Developer is replaced 250,000 copies, drum 250,000.
for parts try this site for starters:
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Jun 24, 2015 | Konica Minolta Office Equipment & Supplies
Where is the ATDC sensor
If you replaced the developer unit then you already replaced the ATDC sensor. using third party toner or KMBS? if so use only KMBS
Jul 25, 2014 | Konica Minolta Bizhub C360...
Trying to change a black cartridge on a 1650 en model. How do I rotate the cartridges after opening the door?
You can't rotate the toner cartridges manually without potentially damaging the printer. To get the cartridges to rotate, close the door and go through the following sequence:
- Press Menu Select to get to the main menu
- Go to the Print Menu
- Go to the Quality Menu
- Select Replace Toner
- Use the arrows to select Black
- When the display says "Black" press Menu Select
- Press it again, the display should read "Open door and replace black toner"
Now the black toner should be positioned to be replaced, and you should be good to go!
Mar 15, 2011 | Konica Minolta Magicolor 1600W Laser...
Konica minolta 2530 dl Replaced black cartridge now says others not installed and "cannot rotate cartridges"
Clean toner chip reader, remove OPC drum and all toners, under the toner rack there is a 3 pin chip reader, use pressure air to clean it.
Jul 21, 2009 | Konica Minolta magicolor 2430 DL Laser...
Cannot revolve cartridges
Doing a complete power off/on and following the notes on Konica/Minolta website for changing cartridge
Jan 27, 2009 | Konica Minolta magicolor 2430 DL Laser...
Konica Minolta Magicolor 2400W drum cartrige-how to replace?
Did you buy a whole new drum unit, or just change the cartridge? If so, the fuse may still be blown. Also, you may need to empty the spent toner out of the old cartridge.
Oct 07, 2008 | Konica Minolta magicolor 2400 Laser...
Drum cartridge
just open cover turn the toner rack if needed and replace the toner.
in right there is a black button, what is pushed down with the cover, you can push it down with pen or something, then the rack rotates easy. be sure to turn off the printer first
Jan 18, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Toner problems
A couple of suggestions. 1. make sure there is not any plastic shipping tabs that need to be removed from the cartridge. 2. try reseating the cartridge. 3. Try replacing that cyan cartridge. It may be defective. Also make sure you use Minolta brand toners!
Apr 07, 2007 | Konica Minolta magicolor 2300DL Laser...
Konica Minolta magicolor 2430 DL Laser Printer Logo
391 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
