Question about Panasonic DMRE85HEBSM DVD Recorder
Panasonic dmre-85h This machine does its self check, them sits waiting for a comand. the HDD works fine, but when you put a disc in the laser tries to find the toc but the disc motor does about one revolution then the machine shuts down, you cannot even get the disc out, you have to take the lid off to retrive the disc.I thought it might be the caps in the power supply but they read ok. Iam thinking it might be the disc motor, or the motor control. Has anyone a copy of the service manual as iam in the dark without one.
Trouble with my Panasonic DVD recorder DMR-E55EB
Am afraid that this is indicative of a weakening optics or the laser. You can of course still give it a cleaning using CD ROM cleaner normally used for computers. Additionally you can try using a can of compress air to force out any dust inside the unit. Other than that all other actions would require opening the unit for a look and see, manual cleaning or worst case scenario, parts replacement.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 25, 2008 | Panasonic DMR-E85H DVD Recorder
PANASONIC DMR-E65S
Does the player make squealing noises or is it totally quiet? Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable.
Totally silent means that the photo sensor is not getting any usable input from the laser at all, meaning that the pickup is "blind" for lack of a better word.
This can be caused by an obstruction of the beam by foreign matter on the lens or inside the pickup all the way to a marginal or failed laser diode and/or photosensor array. This can also be caused by a bad ribbon cable with one or more severed traces.
You could try to clean the optics. This is the most common malfunction as far as i know in all disc players. It would involve taking the cover off and finding a way to expose the lense, and then cleaning it with a very gentle brush. some players have a cover for the lense that swings to the side during playing, this greatly reduces the chance of dust accumulating, but its still worth the try.
If you actually see dust on the lense, then its just that simple. clean, close, play.
It may also be worth your while to check on the small shafting that guides the carriage of the laser pickup. Dirt, grome, dust and solidified lubricant can cause stoppage of the carriage and the laser eye then fails to read the next track. Please refer to the image below.
Goodluck...
Apr 05, 2008 | Panasonic DMR-E65 DVD Recorder
I have put in a dvd into the slot, it will not play, the message saying self check keeps displaying
Hi
Assuming that the machine accepts the disc in and begins to spin the disc, you will hear a spinning sound, and goes no further than this point, it would suggest the optical pick up is unable to read any data on the disc or the spindle motor is unable to spin the disc to its correct velocity, it is more than likely the laser has failed, either way the machine needs to be serviced.
Regards
TechSupp12
Dec 12, 2010 | Panasonic Televison & Video
I've got 2 Panasonic DMR-EX79 DVD Recorders, one is faulty (stuck in self check did not complete loop) my question is, is it possible to put the hdd from the faulty machine into the healthy machine to...
Assuming the hard drive is not faulty I do not see why not provided that the configuration in machine 2 is identical to machine 1. Hopefully the electronics of machine 1 did not enter some sort of identifier in the hard drive that would render it useless in another machine. (Ex: Win 10 does this but Win 7 does not!). Good luck!
Aug 28, 2017 | Panasonic Televison & Video
I just bought new discs for my Canon DC100. The
It's possible that, for some reason, the disks aren't compatible. It can almost drive you crazy trying to figure out why. To find out for sure if this is the case, try some new Panasonic discs, with the same specifications as the old ones that worked, and see if they work. If they don't work, you're probably having a dvr issue with the laser lens or related parts within the camera. There are many issues with dvrs that develop over time, requiring replacement parts and service. In those cases, it's usually better to get a replacement camcorder. The new HDD camcorders are immune from a lot of problems inherent with dvr and tape recorders.
Apr 18, 2010 | Canon DC100 DVD Camcorder
Pansonic e 85h won't play recorded disc or finalize recorded discs also unable to play previously finalized discs, hdd is working and recording fine, what could be the problem on this dmr e 85h panasonic...
The symptoms sound like the laser needs cleaning adjusting or replacing by a qualified technician. If it is under warranty then you can return it. The only other thing youmight try is to open it and gently clean the laser lens with a q tip and a drop of alcohol if you know how. Otherwise get it professionally serviced.
Kind Regards
Chris
Mar 12, 2010 | Panasonic DMR-E85H DVD Recorder
DMR-EZ48V- DVD drive not working
Check Panasonic.com for Firmware updates. If it has a reset button reset it. Take off the cover remove dust and lint, also clean laser eye with rubbing alcohol. DO NOT LOOK DIRECTLY AT THE LASER LENS IF YOU PLUG IT IN, DURING THE OPERATION.
Sep 10, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Not Playing DVDs any more.
Get a laser cleaning disk, and follow through with the instructions about how to clean the laser with it.
If you are able to remove the DVD player drive, you can manualy clean the laser.
If cleaning the laser does not fix the fault, then this means that there is a failure somewhere else in the drive, or the laser itself is defective. Most of the time, these drive's are not worth servicing.
eHow, cleaning a DVD laser lens:
http://www.ehow.com/how_2036275_clean-lens-dvd.html
Jerry G.
May 14, 2008 | Panasonic Diga DMR-EH75V DVD...
DVD recording problems
I have the same unit with the same exact problem. I ended up taking it in for repair and it's now working perfectly. I paid $100 for the repair. I dropped the unit off and picked it up myself. I think $30 additional is charged for shipping and handling in US.
PANASONIC CAMERA & DIGITAL SERVICE CENTER
1590 Touhy Ave
Elk Grove, IL 60007-5319
EMAIL camerarepair@us.panasonic.com
888-439-2676
Part Number
RFKNEH75VP
Description
RAM/DIGITAL PCB MODULE
Mar 30, 2008 | Panasonic Diga DMR-EH75V DVD...
Panasonic DMRE85HEBSM DVD Recorder Logo
102 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
