Question about IBM Infoprint 1120 Laser Printer
IBM Infoprint1120 and Lexmark T520 toner cartridges.
Is there anyway to mix them? I know this can be done because I have a 1120 using a T520 toner. I'm just not sure how to force this change.
  • 13 Answers
You cannot use Lexmark toner cartridges in IBM models and vice-versa because the toner carts have a smartchip that identifies the toner to the printer. IBM printers expect to see IBM toners and Lexmark machines expect to see Lexmark toners. If you put the wrong cartridge in you will get '32' Unsupported print cartridge error.
Some refillers may swap the smartchip when they refill cartridges and this would be the only reason why you may have seen it done before.. IS your current toner a refilled one? It's technically possible to make an IBM printer into a Lexmark printer to accept Lexmark toners by replacing the System Board... but why would you bother doing that...just use the right toner.
Posted on May 28, 2009
I installed a new IBM 28P2494 toner cartridge in my Infoprint1120 printer and get a series of dark lines across the page. I reinstalled the old cartridge and it seems fine.
then it does sound like the cartridge might be no good.
have you tried to tell your printer to do a head alignment test with the cartridge in.
or to do a cleanup test.
Nov 27, 2016 | IBM Office Equipment & Supplies
Out of toner
Make sure that the toner ink cartridge is a genuine Lexmark toner cartridge. Try removing the toner cartridge and then shake the toner sideways. Re-seat the toner cartridges and check if the error persists. If it does, please contact our Technical Support Hotline.
Dec 03, 2012 | Lexmark T520/522 BLACK PREBATE TONER
Black marks on pages when i print
Do the streaks get fainter as you print more pages?
It sounds to me like have toner on your rollers/fuser.
Print out 10 prints from the printer and see if it improves.
If you remove the fuser wiper cover from the top of the printer and look down you will see part of the fuser roller (DON'T TOUCH VERY HOT) and check if there is toner on it.
John
Nov 21, 2011 | Lexmark T520 Laser Printer
I went to put a new toner in my Lexmark T520 and it won't print now it comes up with incompatibility in the window...how do I fix this?
Did you replace the toner cartridge with a Lexmark new or factory refurbished cartridge?
If not, then more than likely that's your problem. Lexmark put smart chips in the cartridges that prevents there re-use unless these chips were either replaced or scrubbed clean.
If this is a factory new or refurbished cartridge, contact Lexmark.
Oct 06, 2010 | Lexmark T520 Laser Printer
Lexmark t520 suddenly prints poor quality, i.e. the previous page prints softly onto the next page and the right side of the page (2" from right) is streaked with toner. Please help. TIA, Mike
this sounds like you have a fuser problem look at the fuser and see if it has toner build up on the rollers ghost printing can be caused by the toner cartridge or the fuser. this would indicate that your fuser isnt maintaining enough heat for complete fusing. is you take the rear covers off and run your print job. look to the far left side of the fuser and you will see the heat lamp lit up. this light should cycle on every 1 1/2 pages or so. any longer than that and it wont keep up with the print job
Oct 28, 2009 | Lexmark T520 Laser Printer
How to you fill ink on a lexmark T520
laser dont use ink they use toner which is a powder and this isnt something you would want to attempt just buy a new toner cartridge
Sep 05, 2009 | Lexmark T520 Laser Printer
Infoprint 1120 929 service toner sensor error code
The problem is caused by one of the following (normally it's the cartridge that's faulty, very common on Lexmark's and IBM Infoprints)
The toner sensor is not operating properly, the developer
drive assembly is not operating properly or the print
cartridge is defective
Jun 09, 2008 | IBM Infoprint 1120 Laser Printer
Cleaning page
Ideally just replace the toner cartridge. But if fairly new, just clean the loose toner off from the old cartridge's printing surface by swabbing it as you manually turn the drum. If while doing this you notice black burned into the glassy surface of the toner cartridge or scars along the surface you'll just have to replace it. Happens once in a while, especially with refurbished cartridges.
May 08, 2008 | Lexmark T520 Laser Printer
IBM INFOPRINT 1120
Julie1665, Here are some things that could be causing your problem: -Could be the paper you are printing does not meet the printer specifications. -Could be toner leaking out of the cartridge. -Could be environmental issues, too hot or cold or humid. -The toner density could be set too high. -The electrical contacts that connect the toner cartridge to the printer could be dirty or just not making good contact. -the printer power supply could be defective. -With regards to your toner cartridge are you using new IBM cartridges or refilled/remanufactured? I?ve had many customers call me to fix a printer problem that turned out to be a bad cartridge. All of these are within the capabilities of the typical user except changing the power supply. Let us know if you have any other questions and please don?t forget to rate this post.
Feb 22, 2007 | IBM Infoprint 1120 Laser Printer
IBM Infoprint 1120 Laser Printer Logo
498 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
