Question about HP LaserJet 8150n Printer
49.05 ERROR LASER - HP LaserJet 8150n Printer
Show error 52.00
Note this a not something users can repair themselves. It is a fault with scanning motor. may need motor or whole scanning assembly to be replaced. Only service centre can perform this.
HP LaserJet 4200 and 4300 Series Printers - Numerical Error Messages 52.XY PRINTER ERROR For help press? alternates with 52.XY PRINTER ERROR To continue turn off then on
Description
A temporary printer error has occurred.
X Description 0- Scanner error
1- Scanner startup error
2- Scanner rotation error
Action
  1. Press the (Select) button to continue.
  2. Turn the printer off and then turn the printer power on.
  3. If the message persists, contact HP Customer Support.
The laser scanner speed is incorrect. X description: 1 = Scanner startup error 2 = Scanner rotation error.
1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner. HP LaserJet 4200 and 4300 Series Printers Numerical Error Messages
Apr 16, 2016 | HP LaserJet 4350n Printer
Mpc 2050 sc 222
Laser sync detection error (Y): Replace BCU board Laser sync detection error (Y): Replace laser unit Laser sync detection error (Y): Check laser unit connections
May 23, 2015 | Ricoh Aficio Mpc2050 Color Digital...
5120 code error
Any of these error codes (51.20 51.21 51.22 51.23) points to a failure with one of the laser scanner assemblies on the HP Color LaserJet 4610 an 4650 series. To solve these error codes, replace the corresponding laser scanner. Sometimes when the laser scanner fails you will also hear loud noises (often higher-pitched noises like screeching sounds); the noises can be another sign that the laser scanner needs replacing.
51.XY
PRINTER ERROR
For help press
alternates with
51.XY
PRINTER ERROR
A printer error has occurred.
X Description
1 beam detect error
2 laser error
Y Description
0 no color / black
1 Press to continue.
2 Turn the printer off and then on.
3 Reseat the connectors between the
laser/scanner and DC controller PCA
(J1009 - J1012).
4 Replace the defective laser/scanner
assembly. Calibrate the printer after
replacing the laser/scanner.
Mar 17, 2014 | HP LaserJet 4650n Printer
I have error 50.22.00 in my Hp M602 printer
Error: 52.XX.00 Error To continue turn off then on
Error Description: Laser/scanner error ? XX = 00 laser/scanner motor startup error ? XX = 20 Laser/scanner rotation error
check your printer scanner assy. need technician support.
Oct 08, 2013 | HP LaserJet 600 M602DN Laser Printer - M
Engine scanner error (internal hardware laser scanner error) error message laser scanner
This means that the laser unit inside your printer has failed. It costs around 100 dollars for the part and it needs to be installed by a trained technician. Best idea is to buy another printer. Sorry.
Sep 29, 2013 | HP Laserjet P1505 Printer, Remanufactured,...
Vertical laser error
If the error code means "vertical laser error" you could check for the flat connector of the vertical laser module. Here I send to you an image to explain it. 0b500ff.jpgIF all is ok. you could try with another vertical laser board and replace it
Apr 20, 2010 | Datalogic Magellan 8500 Wired Barcode...
HP Color LaserJet 2605dn_2605dtn error code 51.22
The 51.xx error occurs when there is an error in connection with the laser, if you open the printer to clean the lens, surely you have forgotten to replace the cable connection purple laser. open it again and reconnect all cables OR: 51.X PRINTER ERROR A loss of beam-detect occurred. X description: 1 = Beam-detect error 2 = Laser error 1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner. 5. Replace the DC controller.
Mar 06, 2010 | HP LaserJet 2605DTN Color Printer
Laser Error Error message 061-370 for Xerox Phaser 6125
From the service manual:
Troubleshooting Procedure Table
Step Actions and Questions Yes No
1 Check the Laser Unit for correct
installation.
Is the Laser Unit correctly installed?
Go to step 3. Reinstall the
Laser Unit. Go
to step 2.
2 Cycle the power.
Does the error still occur?
Go to step 3. Complete.
3 Check the wiring harness connectors
P/J40, P/J41, P/J411, and P/J412
between the MCU Board and the Laser
Unit.
Are the connectors securely
connected?
Go to step 5 Reconnect the
connectors. Go
to step 4.
4 Cycle the power.
Go to step 5. Complete.
5 Replace the Laser Unit (page 8-31).
Replace the
MCU Board
(page 8-59).
Complete.
Jan 31, 2009 | Xerox Phaser 6125 Laser Printer
52 scanner error
HP LASER PRINTER ERROR CODE 52 – INCORRECT SCANNER SPEED ERROR
HP LASER PRINTERS 2, 2D, 3, 3D
1. Defective cable laser scanner to dc controller.
2. Defective laser scanner assembly.
HP LASER PRINTERS 2P, 2P+, 3P
1. Bad scanner motor.
2. bad dc controller.
HP LASER PRINTERS 3SI, 4SI, 4V
1. Faulty cable assembly.
2. Scanner motor problem.
3. Defective laser scanner assembly.
4. Defective dc controller.
HP LASER PRINTERS 4, 4+, 5
1. Faulty laser scanner cable.
HP LASER PRINTERS 4L, 4P, 5P, 5L, 5SI
1. Temporary error. Scanner startup failure.
2. Improperly fitted scanning assembly.
3. Scanner cable problem.
4. Defective laser scanner assembly.
5. Defective dc controller board.
HP LASER PRINTERS 1200, 2200, 3100 FAX, 3200 FAX, 4100
1. Temporary error. scanner rotation error.
2. Replace contact image sensor.
4. Replace laser scanner.
5. Replace cables to laser scanner and engine board
HP LASER PRINTERS  1100, 2100, 4000, 4050, 8000
1. Scanner start up error
2. Replace scanner cable to the D.C. controller and back to scanner. Or replace scanner cable from engine board to scanner ***'y.
3. Replace scanner ***'y.
4. Replace the engine board.
5. Replace the D.C. controller only on the 8000.
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
HP LASER PRINTERS 4200, 4300 ERROR 52.XX
1. Printer scanner speed error has occurred.
2. Replace laser scanner ***'y
3. Replace the D.C. controller ***'y
HP COLOR LASER PRINTER 4600, 5500 ERROR 52.XK, 52.XC, 52.XM, 52.XY
1. Error code K - No Black Color.
2. Error code C - No Cyan Color
3. Error code M - No Magenta color
4. Error code Y - No Yellow color
5. Replace laser scanner ***'y
6. Replace the D.C. controller ***'y
HP LASER PRINTERS 5000, 5100
4. Replace cable ***'y from scanner to D.C. controller.
HP LASER PRINTERS 8100, 8150
1.Laser scanner error/start up/rotation error
2.Replace laser scanner ***'y.
3.Replace D.C. controller board.
4.Replace cable ***'y from scanner to D.C. controller
HP LASER PRINTER 4500, 4550
1. Temporary error. Laser scanner error/start up/rotation error
2. Replace laser scanner.
3. Replace D.C. controller ***'y
HP COLOR LASER PRINTERS 4600, 5500
1.Laser scanner error/start up/rotation error.
2.Take the toners out and reseat them, or replace them
3. Replace laser scanner ***'y
4. Replace D.C controller board.
HP LASER PRINTER 8500, 8550
2. Replace laser scanner motor.
HP LASER PRINTER 9000
1. Temporary laser scanner error/start up/rotation error
3. Replace upper cable guide assembly.
4. Replace DC controller.
Oct 22, 2008 | HP LaserJet 2840 All-In-One Printer
HP LaserJet 8150n Printer Logo
46 people viewed this question
Seeker5211
Seeker5211
