Question about Amana PTC123B35AE Air Conditioner
Air conditioner not running - Amana PTC123B35AE Air Conditioner
I have a split system air conditioner that quit blowing cold air
either the compressor is not running or you have a leak and are low on freon. the outside fan running does not tell you the compressor is running.
Jun 18, 2014 | Coleman Outdoor Split System Air...
The Ruud air conditioner is running but the house temperature is not dropping and we have checked that there is cold air coming out of the runs.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Aug 24, 2011 | Ruud UAKA030 Air Conditioner
Compressor is running but ac not cooling
The unit leaked the refrigerant and so it does not cool even though it is running... Here is a tip about troubleshooting your air conditioner...
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 27, 2010 | Royal Sovereign ARP9011TL Air Conditioner
The motor is running but hot air is coming in the house. Fan has stopped running outside
heatman101
Sep 26, 2010 | Goodman Heating & Cooling
Frigidaire FAH125N2T Air Conditioner is 6 years and still runs very smooth but no longer blows cold air. What could be the problem?
There are many things that can cause your air conditioner not to cool…
heatman101
Sep 04, 2010 | Frigidaire FAH125N2T Air Conditioner
The airconditioner runs the compresser seems to be running and the fan is running on hi.however it isn't cooling what could be wrong?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 31, 2010 | Dometic Rooftop RV Air Conditioner
Air conditioners remove the moisture from the air, and so does a dehumidifier. Does running a dehumidifier make the air conditioner run less? Does running the small dehumidifier save energy in that the...
a dehumidifier is basically the same thing as an air conditioner but both coils (condenser and evaporator) are in the same unit meaning a dehumidifier exhaust warm air in the same room it is in. running a dehumidifier would make an air conditioner run more because of the warm exhaust, but you are correct, when you run an air conditioner it acts like a dehumidifier and dries the air. as far as saving energy it all depends on the size of the AC and dehumidifier and the size of the room. If you want warm dry air use a dehumidifier if you want cool dry air run the AC but not both.
May 18, 2010 | Dehumidifiers
My air conditioner air handler humsbut moter does not turn on compressor runs ok Goodman air conditioner
either bad motor ....or.... if you are lucky a bad run capacitor. you will need some sort of capacitor checker and multimeter to diagnose it further.
Oct 30, 2009 | Goodman CLQ36AR49 Air Conditioner
Amana PTC123B35AE Air Conditioner Logo
20 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
