Question about HP Photosmart C4280 Aio Printer
Ink blobs on paper
HP PHOTOSMART PRINTER is leaving ink blobs on the sides of my paper when printing. Is this dirty rollers or leaky ink cartridges?
    Problem Solver:
  • 11 Answers
It could be both. Leaky ink can be a problem and that probly is the problem. But, make sure your rollers are clean and cheak that your ink is not leaking. I hope this has helped you.
DigicalJAI
Posted on May 19, 2009
Put in all new ink. Black ink blobs all over paper when I tried to print. Printing very light almost unreadable.
remove and reinstall the cartridge/s to ensure that they have been installed correctly before buying a new printer
May 07, 2016 | HP Photosmart C6180 All-In-One InkJet...
Ink
is it the exact ink replacement or did you have a company refill it ?
Robert
Aug 29, 2008 | Canon PIXMA iP1600 Printer
All colors won't print
This could be solved, but you can get dirty. so if you want to tackle the problem yourself, use a place covered with papers and use plastic gloves. Don't wear your good pants. you need special cleaning fluid, like you can buy in a ink refill store. A serinse will be handy too.
If the normal cleaning cycle after a few runs does not solve the problem and you are sure all cartridges are full, then comes the dirty part. Remove the cartridges, and while closing the ink outlet, shake it to hear if there is still ink, like the chip indicates. If there is ink, put it aside, till you have out all cartridges. Then down in the cartridge holder, you see 5 holes, where normaly the ink goes in, clean these holes, using tissue or kitchen paper. If everything is clean, put in a few drops of the cleaning fluidwith your gloves on, try to apply a little presure on the fluid. Don't press till the cartridge holder braks, just a little presure. fill the 5 holes with the fluid. (The one or two colours that print correct, you can skip.)
If there was enough room, to work along side this or these cartridges, you could leave them in place.
Then put back all cartridges and start a set of cleaning cycles, or just start printing a colour picture, telling the printer you are using high quality photo paper, but jus use plain paper, because first all the cleaning fluid needs to pass the heads.
When you think collours are comin back, check the head alignement to see if all nozzles are clean.
Even if you don't need to print, switch on the printer at least once a week, to keep the nozzles open.
Success
Mar 18, 2014 | HP Photosmart 7520
Hp 3210 not printing magenta and leaving large quantities of magenta ink in printer blobs on right side of paper
defective cartridge; make sure you buy ANY cartridge from a REPUTABLE, not cheap, cartridge company.
Dec 24, 2012 | HP Photosmart 3210 Printer
My printer only prints the first couple of lines of print then stops and spits out the paper.
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can also be poor ink cartridge contacts
Please also check if the roller aligment is out , the sensors are dirty.
Oct 30, 2010 | HP Photosmart Premium C309A All-In-One...
My HP Photosmart 3210 printer is not printing black color
must be dryed ink on ink cartdrige, or dirty print-head (ink cartdrige) conntector.
try these :
To clean the print head from the control panel
1. Load letter or A4 unused plain white paper into the main tray.
2. Press Setup.
3. Press 5, then press 2.
This displays the Tools menu and then selects Clean Printhead.
or
To clean the ink cartridge contacts
1. Unplug the power cord from the back of the HP All-in-One.
2. Lift the ink cartridge access door.
3. Squeeze the tab below an ink cartridge to release the latch inside the HP All-in-One, and then lift the latch.
4. Inspect the ink cartridge contacts for ink and debris buildup.
5. Dip a clean foam rubber swab or lint-free cloth into distilled water, and squeeze any excess water from it.
6. Clean only the copper-colored contacts.
7. Place the ink cartridge back into the empty slot and press down on the gray latch until it clicks into place.
8. Repeat if necessary for the other ink cartridges.
9. Gently close the ink cartridge access door and plug the power cord into the back of the HP All-in-One.
These steps is printer manual on pag 99 and 100
Jan 15, 2010 | HP Photosmart 3210 Printer
Having an issue with my ML 1210. It prints these
The roller had an ink spot it it which is transferring to the paper. clean the roller carefully with some rubbing alcohol on a clean cloth. then let it air dry for 30 minutes before using it. Have the printer unplugged while you do this and use a minimal amount of alcohol, just a damp cloth will do the job.
Oct 02, 2009 | Samsung ML 1210 Laser Printer
My HP Photosmart suddenly started blobbing out ink.
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 06, 2009 | HP Photosmart D7260 Printer
HP C3180 all in one printer won't realign
We've encountered several problem like this. Hope this gives an idea; I understand the cartridge will not moved back to park tray or flash ink tray back and forth because the return pick-up guide were not properly placed into each original position. It will block the ink tray moving back and forth. You can roll back the roller into the original place by removing the back cover if it has, then turn the pick-up roller slowly allowing the roller to turn and backed to its original position. Removed also remains of jammed paper pieces.
Best regards,
Rosener Guyano
Nov 29, 2007 | HP Photosmart C3180 All-In-One InkJet...
HP Photosmart C4280 Aio Printer Logo
362 people viewed this question
Seeker5211
Seeker5211
