Question about Toshiba Satellite U305-S7467 Notebook
My Toshiba Satellite P55t-A5202 won't download anything from the store
I have tried to download Taptiles, but it stayed on pending until the next day, where an error had occurred. Now, I am trying to download Doodle God Blitz, but it is still on pending. it started "downloading" yesterday, but it still says pending, even if I shut it down to download. It won't download Roblox off the internet either. I saved it and when I click "run", it opens up the webpage...but I cant play any gamees.
mitch_3020
  • 67 Answers
SOURCE: Toshiba Satellite laptop boots up but shuts down on its own very shortly
Hi JOJO0803,
Based from the error message you're getting it sounds to me that your problem there is not software related but is more hardware in nature.Since you're getting a message "disk read error occurred IDE#0" this pertains to a problem with the hard drive itself. It's possible that your hard drive developed bad sectors or errors on the disc itself.
So to be sure I would recommend that you run the hardware diagnostics for your laptop computer especially the one for the hard drive since you're getting this message. If the hard drive fails the test or any other part fails in the test, contact your techsupport and ask for replacement parts if your PC is still under warranty. Otherwise you may have to buy parts for your laptop.
If the hard drive tests passed and all the other hardware tests also passed then you may proceed to troubeshoot the software using the Windows XP Home CD. Boot from the WinXP Home CD, and you get to the setup screen, choose "R" for recovery console and then on the prompt type "CHKDSK /R" let it run, it may take a while. afterwards it will bring you back to the prompt then type EXIT and it will reboot the system, see if that fixes the problem. Worst case scenario you may have to format then reinstall Windows XP again to fix this problem.
Hope this helps!
Peace! :)
Posted on Oct 23, 2008
SOURCE: Won't Boot up
im having a wierd problem my toshiba error 03-EEEE-0000 happened right after MYSTICALLY my atheros wireless wouldnt work so i formamtted wen i put in any windows CD it says BAD COMMAND.. same with recovery PLEASE HELP
Posted on Oct 30, 2008
cpenzes
  • 1102 Answers
SOURCE: My Toshiba Satellite L300D keeps shutting down when I start it up
restart in bios setup
then click to default settings press f10 to save and exit
if problem persists let me know
don't forget to rate
Posted on Feb 09, 2009
rockitman187
  • 2559 Answers
SOURCE: toshiba satellite P15-S420 odd power & freezing problems
  1. Click Start and then Control Panel.
  2. If you're in Category view, click Performance and Maintenance.
  3. Then click on Power Options.
    If you're in Classic view, double-click on Power Options.
  4. Click the Hibernate tab.
  5. The Enable Hibernation box should be unchecked.
  6. Click Apply.
  7. Click the Power Schemes tab.
  8. In the Plugged in column, from System Standby option, set a time out period.
  9. Click Apply.
  10. You can adjust the Turn off monitor and Turn off hard disks settings as well.
  11. Click Apply. Click OK. Close the control panel.
This is what you should see
Please rate this a fixya
  • 104 Answers
SOURCE: Toshiba Satellite A205-S5814 laptop will not power on
clear the bios by removing the small battery on the mainboard for 10 hours.the power on
Posted on Aug 01, 2009
Remove battery p55t-a5202
after you turn it off, unplug the adapter, close the display and turn it over. You will want to have a small jeweler's flat blade screwdriver, or similar, to pry out the 14 small rubber plugs from the screw holes. Then you'll need a #1 Phillip's-head screwdriver to remove the 14 screws. Carefully separate the bottom cover. There you will see the battery. It is plugged into J6001. It is held in by 4 screws and some wires that are taped/dressed to it.
Feb 26, 2015 | Toshiba Satellite Computers & Internet
Clean heatsink on a toshiba p55t-a5202
usually canned air does a good job .
Feb 21, 2015 | Toshiba Computers & Internet
How do I access/clean keyboard toshiba p55t-a5116 with harman kardan
You can remove the keyboard and then blow everything clean with canned air. Go here for help - http://cpufandeal.com/toshiba-satellite-p55t-a5116-laptop-cpu-cooling-fan.html
Dec 30, 2014 | Toshiba Satellite Computers & Internet
I am having issues with my Toshiba p55t-a5202 15.6 in laptop. I did a refresh on it yesterday and when I turned it on today it's just a black screen that says my pc will restart in two days to finish...
Check the date and time. If it has downloaded some updates and then on re boot they will install. If the date is wrong, it may wait for the correct date. Or you may have an odd virus.
May 20, 2014 | Computers & Internet
Can't find the cursor on the screen
Press the windows smart key and close the laptop down. After rebooting, you should be fine.
Mar 13, 2014 | Toshiba Computers & Internet
Unlock bios
se puede desbloquear bios de toshiba P55t-A5202
Jan 10, 2014 | Dell Vostro 3300 Laptop Computer (Intel...
Toshiba satellite p55t-a5202 laptop hibernates then wont turn on
I have had the same problem with my toshiba p55t-a5202 from best buy took it in 2xs then was without a comp for weeks. The 3rd time I just took out 14 screws on bottom(do not loose them) carefully removed bottom cover (push in and up at sides to remove) then found battery. I followed the wires to the middle slightly larger white plug. Then took a very small screw diver and pushed down gently in the flat spot while pulling gently to disconnect the plug. The side lights went out. Then pluged it back in the same way I took it out. I put all screws back on the bottom cover. Pluged it back in and turned it on and whallaa! My lap top was working and I didn't have to be without it for weeks!! I like this comp but will NEVER buy another one with an internal battery. I guess til the next time it not responsive! Ugh! Goodluck!
Oct 07, 2013 | Toshiba Satellite L355D-S7813 Notebook
Toshiba Satellite U305-S7467 Notebook Logo
23 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
