Question about Siemens HF87950GB Convection Microwave Oven
Temperature is broken - Siemens HF87950GB Convection Microwave Oven
Panasonic microwave does not achieve desired temperature
They never do ! You have to check the temp at where the air comes out of the fan and you need to use a remote electronic thermometer.
the old oven type won't work sitting on a the shelf. 275 degrees at best. Take it back it's not broken ...the just don't work as advertized
Apr 07, 2014 | Panasonic NNCS596S Microwave Oven
Food in the refrigerator department is freezing. I checked the refrigerator temperature setting and it is 46 deg f. I checked the freezer temperature setting and it is 5 deg f. I put a NIST traceble...
When the refrigerator side is getting too cold this is because the control of the compressor has gone bad in some way...
There a few different things that could cause the unit to lose control over the temperature of the fridge side.
If your refrigerator has a damper door that opens and closes to allow cold air to move to the fridge side the damper linkage or the damper motor may have broken or gone bad.
The coils in your fridge may have frozen over and now the air does not move at all so then the ice builds up and can freeze parts of the fridge side.
The thermostat has gone bad and so now the compressor runs continually. This will not be noticed readily on the freezer side but will show up quickly on the fridge side.
Many newer model refrigerators use an electronic sensor or thermistor to read the temperature and supply the info for the circuit board and often a digital readout.
So, here is how I would go about troubleshooting this problem.
Check the coils for ice, defrost the coils with a heat gun or hairdryer, then check for the reason why they iced over. Defrost control or defrost timer bad? Evaporator fan bad?
Check the damper door to see if it is stuck in the open position. If it is then check the motor and the linkage.
Check to see if the refrigeration unit will shut down if the thermostat or digital setting is turned up to a higher temperature. If it continues to run then find the cause and fix it. It may be a bad thermostat, sensor, or control board.
Sometimes with a change is weather to a cooler climate this will be enough to also affect the inside temperatures. Make sure that a bit of adjustment in the thermostat or setting of the temperature will not solve your problem very simply.
I hope the above helps.
Good luck.
Jan 13, 2011 | Microwave Ovens
Ice maker will not make ice
hELLO THERE:
There's no ice If your ice maker has stopped producing ice completely, check these, in this order: It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly. The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Dec 29, 2010 | GE Microwave Ovens
The oven stopped working and had error F3 on the screen. We unplugged and waited then it worked for about 1/2 hour and stopped with the same message. What's wrong
Sorry to read about your problem, I hope this helps you out.
Oven temperature sensor open
Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luckSorry to read about your problem, I hope this helps you out.
Dec 26, 2010 | Hotpoint RVM1435 Microwave Oven
Why is my refrigerator not working properly? well , since I got it I have problems because it never seems to get cold or work properly. I think it might be cause it is digital.
This product comes equipped with an Adaptive Defrost Control (ADC). To activate manual defrost, press and hold the Freezer temperature UP (WARMER) key while pressing the Fresh Food temperature DOWN (COLDER) key 5 times within 6 seconds. A "d" in the freezer temperature window and "F" in the refrigerator temperature window will display when the heater is activated. To deactivate manual defrost, press and hold Freezer temperature UP (WARMER) key while pressing the Fresh Food temperature DOWN (COLDER) key 5 times within 6 seconds. "d" and "F" will be displayed until the defrost cycle is complete. (approx. 8 minutes)
Nov 26, 2010 | Frigidaire Microwave Ovens
My Sharp microwave convection oven (R-967M / R96STM) cuts out during convection pre-heating and cooking, It appears it stops heating after 1 min. If the START button is pressed again the oven starts...
Also the fact it is a convection oven could mean the oven temperature sensor is not picking up the oven temp. it is not telling the machine it is there by the board seeing its resistance, the unit will shut off as a safety feature. The oven sees temperature by reading the value of a temperature dependent resistor. As the temperature changes so does the value of the component ( oven temp sensor) that way the unit determines the temperature inside the unit. Sometimes those sensors will break since they are in the area with the heat and moisture, they get old and break.
Aug 17, 2017 | Sharp Microwave Ovens
My old GE oven (JSP38G052BG) won't bake or broil. It start then stop after 1 or 2 minutes. The heating elements get worm. Can you help me please
Hello ediben11.
If your oven's bake or the broiler heating elements won't heat but the range burners still work;the clock may be set for a timed or self-cleaning cycle. So,make sure to check the clock buttons and the knobs are set properly.
*If your clock has a knob that says "push for manual" then push the knob in after that, try the baking and broiling elements again.
*If it still does not work properly, you may have a defect in the thermostat/selector switch/common wiring.
*If the oven does not have a separate bake or broil selector switch; then the thermostat is probably the problem. It is not easy to check the selector switch or thermostat for proper operation. If you suspect a problem in this area, call a qualified appliance repair technician.
Hope this helps.
Mar 23, 2010 | LG LMVM1945 Microwave Oven
F3 code on GE
ok here is the result to searching GE the answer to thew code.
Please rate our help to keep this free service online
Open oven temperature sensor (circuit) (over 2700 ohms) or, shorted oven temperature sensor. Could be a result of:
· contamination on terminals
· pinched wire in oven temperature sensor circuit
· cold solder joint on control. · Disconnect power to range and remove oven temperature sensor connector from control.
· Measure oven temperature sensor resistance at oven temperature sensor connector (take care not to damage terminals in block) - Should read 1100 ohms at room temperature (approx 72 degrees F).
· Measure each oven temperature sensor lead from connector block to ground. If shorted, look for pinched or cut wire in oven temperature sensor circuit.
· Check connector terminals - Look for deformed or corrosion on terminals. Repair or replace.
If all above is ok replace control.
Aug 28, 2009 | GE JVM1430 Microwave Oven
Siemens HF87950GB Convection Microwave Oven Logo
78 people viewed this question
Top Siemens Microwave Ovens Experts
William Miller
William Miller
Steve
Gerry Harvey
Gerry Harvey
Are you a Siemens Microwave Oven Expert? Answer questions, earn points and help others
