Question about KitchenAid KHMS155LSS 1000 Watts Microwave Oven
SPORADIC HEATING my microwave sometimes makes a clicking noise when i press START. it sounds similar to a gas appliance lighting. when it does make that noise, it does not heat whatever is inside. other times, it works fine with no noise.
  • 1 more comment
  • johndoe77 Jan 05, 2008
    Suffering from the same problem. Initially it was about 10% of the time. It is now occurs about 95% of the time virtually rendering the microwave useless.
  • gsanders881 Jan 04, 2009
    I have the same sporadic heating problem with the associated noise as described. Are there parts that can be replaced to correct this problem?
    Thank you.
  • Anonymous Apr 06, 2009
    I have the same problem but it seems to work fine if I push the door a bit more. So I assume the problem is related to the door closing properly.
    Champion:
  • 225 Answers
Check highvoltage crcuit ,and check fan, and turntable motor,
Posted on Oct 20, 2007
Lights on, timer going, but not heating, no whirring sound & turntable not turning
KITCHENAID are a budget make despite what you paid. it is better to buy a company that specialises in microwave ovens rather that a company that buys cheaply made products in China or Taiwan and badges them. As you know KitchinAid is a company that does all sorts of kitchen gadgets and utensils. Toshiba and Panasonic are the brand leaders. GE are long established.
The problem with yours sounds like a safety interlock problem. Every microwave has about 4 safety switches attached to the door so that it is impossible for the unit to be run with the door open. They are small micro-switches that are adjusted like a hair trigger so that as soon as the door moves, power cuts. If it is the switch, it is a cheap fix, if it is the Magnetron, it isn't, so diagnosis is needed by a reputable company. You can't take it apart as they use security screws because of the dangers of cooking yourself and the high voltages in the capacitor, and poisonous Beryllium in the magnetron. Your call on fixing or buying new.
Mar 11, 2017 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Microwave making noise all the time if plugged in & door shut
Sounds like a bad control board. Change it or buy another unit.
Jan 21, 2013 | DeLonghi Microwave Ovens
Sharp 1200w microwave seems to be tripping lightly (can hear clicking noises)and cause heating to be irregular
Clean the food off the inside top of the microwave Now,Or that noise you are hear will stop along with the microwave. The food gets on the Formica Squire which is how the micro waves heat your food. 1st unplug the Microwave then spray the inside of the unit with something like Fantastic or something strong and use glove so you don't burn you hand,Also if you have a scrub brush use it,And clean all the soap out and raise very well.
May 02, 2012 | Sharp Microwave Ovens
I have a GE microwave jvm2070bh02 that is not heating and the motor/blower sounds really loud
It's had it's day and is worn out best get down to Walmart and git yerself a new one for around $100.
Feb 04, 2018 | Microwave Ovens
I press #1 and hit start the blower works and light comes on but no heat
Sounds like the magnetron circuit has failed. It is the part that generates the microwaves that heat the food. It often shorts out, and makes a loud humming or buzzing noise when it fails. It's not usually cost effect to replace since the part alone can cost as much as a new oven.
Dec 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Does not heat
try checking the door switches. they can get just loose enough to not make good contact. the door may be sagging just a fraction.
good luck
Dec 10, 2009 | Emerson MW8778 Microwave Oven
Galanz (french for ''****'') microwave is sporadically beeping
maybe, just maybe, there is an error code showing....and, most microwaves beep when a button is pushed too...LIVE WITH IT!
Jul 06, 2009 | Microwave Ovens
Microwave turns on and counts down but won't heat up/cook
Ok just figured this out! It is a problem with the alignment on the lower door switch. I took the cabinet off and lifted up on the door switch slightly and voila! It works. You could probably fix this without taking it apart, just lift up on the door ever so slightly. I hope this works for you.
Jan 13, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
My GE spacemaker microwave won't heat and makes an unusual sound
I have the same problem on my oven- model JVM1640WB and called an appliance repairman who is honest and reliable (I've used him before). He said the problem is with the electrode, to fix it is roughly $300. He recommended buying a new microwave rather than fixing it.
Nov 17, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Not working
When the microwave sounds okay, but there's no heat, one of the internal door switches, the high voltage circuitry, or the circuit board may have a problem. To resolve this problem, you need the assistance of a qualified appliance repair technician, as repairing microwaves is a pretty risky job.
Oct 05, 2008 | Microwave Ovens
KitchenAid KHMS155LSS 1000 Watts Microwave Oven Logo
547 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
