Question about Homedics Inc Back Massager
Need a new power adapter - Homedics Inc Back Massager
Power adapter for xbox360 is flashing orange
When the power adapter flashes orange, it usually means your console/adapter is only getting half the power it should be getting.
Check all your plugs and make sure everything is plugged in correctly.
If your console isn't turning on, contact Microsoft suppport or buy a new power adapter. If it is turning on, there is no need to do anything.
Mar 15, 2014 | Microsoft Kinect Power Adapter for XBOX...
I need a n ew DC power jack for my pandigital
Most of the Pandigital tablets use the power adapter APR001 which provides 5V at 2A. This is available from Geeks.com here: http://www.geeks.com/details.asp?invtid=APR001 . Other vendors may also have the adapter.
If you need to replace the jack where the adapter connects, try Radio Shack or http://www.mcmelectronics.com . You need to measure the existing jack dimensions carefully. (This ensures that the adapter will connect properly.) When you desolder the old jack and solder in the new one, make sure that you keep the polarity the same. (Otherwise the adapter may not work.)
I hope this helps.
Jan 22, 2013 | PANDIGITAL 7 Android with 2GB Internal...
Need a new adaptor
Google the Internet for a power adapter for your model Sony laptop.
Make sure the the new adapter is the same voltage and amp as the old adapter. This information is printed on the adapter.
Jan 22, 2013 | Sony Vaio Laptop Pcg-7z1l
My adapter led light not functioning...no power to my printer
Hello
You have to replace or repair the adapter.
Good Luck
Jan 26, 2011 | HP Televison & Video
Dell 1737 won't recongnize the Dell AC adapter and battery does not charge. Computer still operates with adapter on ac power. Dell says I need a new motherboard. Computer is 6 months out of warranty.On one...
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether
Sep 17, 2010 | Dell Studio 1737 Laptop
Asus netbook ac power cord adapter stopped working...no blue light on...not charging computer...what to do and need new one?
You need a replacement AC adapter, it's very cheap online.
1)Output Voltage is within +/- 5% of your old charger's output.
2) Output Current is the same or higher than that of your old charger.
3) Connector tip must fit securely into your laptop.
Jul 15, 2010 | ASUS AC Adapter- Universal Notebook AC...
Power cord missing need to make a new one
you can get a new power adapter and power cord from ebay.com
if you go there search for
"Dell inspiron 2650 power adapter" there is several oem power adapters for this notebook.
If you need the actual power adapter inside the notebook (the one on the motherboard) they sell them as well but they are rather hard to replace.
Thanks
Steven
Apr 29, 2010 | Dell Inspiron 2650 Notebook
Power Adapter
I NEED a new power adapter ttttttttttoo.. can you HELP please,, I allready had a so called TV repaire Man try to fix it he said he cant get a new power adapter for it to be fixed .... I stupidly PAYED him waited 9 months later, and still no TV fixed..Im taking him to smalls claimes court.....Very un happy persone ,I just want a new power adapter,....please some one out there...peascorn...I have d:sign TV 3032- ad-13d-2...
May 25, 2008 | byD sign 3032 30 in. HD-Ready LCD...
POWER ADAPTER
LOST POWER ADAPTER NEED TO PURCHASE NEW ONE
Apr 30, 2008 | TruTech PVS12701 Portable DVD Player
Homedics Inc Back Massager Logo
48 people viewed this question
Top Homedics Health & Beauty Experts
Ankit Chandel
Ankit Chandel
Are you a Homedics Health and Beauty Expert? Answer questions, earn points and help others
