Question about Kenmore 22422 Top Load Washer
Puddle under 1 yr old washing machine hours after it is finished
Hours after doing laundry, there is a puddle under the washer. It is only 1 year old. The puddle isn't there when the washer is on, or when the washer is emptied, or when clothes are put in the dryer, or when they are taken out of the dryer. It's hours later. What could cause a washing machine to leak hours afterward? I've checked the sink it drains into, and that isn't backed-up or leaking.
    Scholar:
  • 93 Answers
Sounds like either the gasket on the inlet is leaking or not tight or the solenoid housing is cracked causing the leak. When its in use the pressure from the line is realased when the solenoid is opened letting water in. When not in use the solenoid stays closed allowing pressure from the line to build causing the gasket to leak. Check your gaskets, and solenoid housing for leaks and then check to make sure your water pressure is not set too high.
Joe
Posted on May 19, 2009
Tip
""I ordered a new machine because I didn't want to put repair money into a 7...
All of my tips have been tampered with. I deeply regret I must remove the content from these tips. I will not write another tip for fear of further tampering of my literature. If you have any questions I am on facebook.
JW Webster
on Feb 08, 2011 | Kenmore HE2 Plus Front Load Washer
Whirlpool ultra care II quiet wash II - over the past few day has run intermittently. It stops for what appears to be no reason. Can't get it to start. I turn it off, then a few hours later when I...
Sounds like motor overheating and shutting down. Motor will have to be replaced if that's the case. Probably not feasible on a 10 year old machine
Aug 25, 2017 | Whirlpool Washing Machines
I just moved into an apartment equipped with a stackable moffat MCCH6110HSS washer and moffat 350A4502P547 dryer. I've discovered that the washer appears to repeat the rinse/spin cycle over and over again...
HI, I spent many years in apartment maintenance and most communities have maintenace staff to fix issues you have with their equipment,call the leasing office.The most likely cause is a bad timer.
Mar 06, 2011 | Washing Machines
Loud jet noise in spin cycle on Kenmore stackable top load washer
it is the drum bearing seal and it has gone out and ruined the bearings,you would need a lip seal kit and appropriate bearings for that particular unit,i do a lot of maytag front loads and it can take anywhere from 2 hours up to 8 hours depending how the old bearings come out and the damage to the bearing and seal surfaces,the sooner you get to it the less chance of severe damage it will cause,because water will kep on destroying bearings till they lock up and destroy the drive pulley
Mar 05, 2010 | Kenmore 44042 Front Load Washer
Whirlpool Ultimate Care 2 leak after wash cycle
Hello, you may have a small drip from the pump or a small drip from the hose that goes from the pump to the rear of the cabinet. To make sure you will have to run the unit with the cabinet removed. A local service tech can remove the cabinet quicklyand isolate the leak.
Dec 23, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore Elite Oasis
You want to charge me to get answers from you but you want me to tell you my fix for free???!!! I don’t think so!!!
Aug 11, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Black spots on white laundry
is the washer noisey when spinning? If so its probable that the main bearings are worn, & losing the original grease into the wash tub. At 10-14 yrs old its probably not woth fixing (assuming parts are still available)
Oct 19, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore 22422 Top Load Washer Logo
226 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
