Question about Air Conditioning and Heat for Ford Fusion
Blower fan resistor in fusion -03 where can I find it?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 87 Answers
It is part of the switch
Posted on Dec 02, 2014
Where is the heater fan relay located 03 chevy venture
It's part of the blower motor resistor assembly . right below the blower motor under right side of dash
Apr 21, 2017 | Cars & Trucks
What is the location of power stage/transistor unit on the blower fan on 2001 volvo s80
Volvo Forum • 2000 v70 Blower Motor/Resistor Question - Matthews ...
www.matthewsvolvosite.com/forums/viewtopic.php?p=166169
Jan 8, 2011 - 14 posts - ‎1 author I replaced my blower motor and resistor - with the help and ... On ECC the transistor power stage (referred to as resistor) will shut off blower if the ... the current to blower(voltage level to blower) is controlled by the ECC control unit. ... Hook the negative side of the car battery (or other 12 V source) to the fan. Volvo Forum • S40 fan speed erratic
Jul 18, 2013
Volvo Forum • Wanting create a repair procedure for ...
Feb 24, 2008
More results from www.matthewsvolvosite.com
All how to replace blower motor in volvo s70 v70 c70 XC70 ...
? 3:03
www.youtube.com/watch?v=frZl49p2quk
Sep 5, 2007 - Uploaded by volvoproject All how to replace blower motor in volvo s70 v70 c70 XC70 ....Awesome video....took 15 mins to install blower motor andresistor on my .... Most time was spent trying to remove theelectrical wires from around the blower properly (there ... I was suprised how much bigger the fan is irl than it looked in this vid!
Oct 07, 2015 | 2001 Volvo S80
The heating and air conditioning fan only works on the highest speed position. What would cause the lower speeds not to work?
If the system is a Manual ( not the EATC / Electronic Automatice Temperature Control System ) it is most likely the blower motor resistor.
For the new body style 2004 ( not the 2004 Heritage or Lightning models ), it is behind the glove box.
Open teh glove box, press on one side, to allow the glove box to hang down.
The Blower motor resistor is located in the side of the blower motor housing.
If your 2004 is a Heritage or Lightning, the blower motor resistor is access from under the dash / glove box area.
On this type ( same as the 97-03 ) the blower motor resistor or the resistor and pigtail might need to be replaced.
Just pay attention to which body style 2004 you have ( new like the 2005-2008 or the 2004 Heritage / Lightning, which looks like the 97-03 MY trucks.
Aug 09, 2010 | 2004 Ford F150
Ford fusion 2007, blown blower fuse, replaced fuse, works at highest speed only (highest of 4) the other three setings don't work.
hte blower resistor is shot, near the blower motor, have the blower motor checked my guess is that it requiring too much power to run, hence the blown fuse
May 06, 2010 | 2006 Ford Fusion
Blower moter resistor location 03 lancer oz ralley
It is under the dash on the passenger side close to the blower fan. Follow the wires, there should be a connector visible for the resistor on the housing. The resistor is usually held in place by a couple screws.
Check the pic. #10 is the resistor pack.
Dec 07, 2009 | 2003 Mitsubishi Lancer
I have a 2003 GTP and at times the heater fan stops working and now the display unit quits working and it says the fuel is low but I have 3/4 of a tank
I believe that these are two separate problims. The Heater fan stops working because the blower motor resistor block is bad. This is a common problem on the 03 Grand Prix. You'll need to remove the blower and replace the resistor block. The blower is under the center of the drivers onsole.
Oct 11, 2009 | 2003 Pontiac Grand Prix
2003 Ford Explorer Fan Blower Motor
Jeff, If I understand you correctly you say your blower motor only works on high? check your blower motor resistor, located next to blower motor. The resistor makes the other speeds availiable, high bypasses the resistor, let me know if that fixes you up
May 27, 2009 | 2003 Ford Explorer
Heater fan will not shut off runs all the time on high speed. 03 dodge grand caravan
Sounds like resistor is faulty. I believe on that vehicle, look up under dash behind glove box, and you should see blower & the harness that runs from it to a resistor attached to housing/duct. Pull connector off to stop blower. Replace resistor.
Apr 19, 2009 | 2003 Dodge Grand Caravan AWD
2003 silverado blower problem
maybe your blower motor relay has a short
Dec 05, 2008 | 2003 Ford Focus
Air Conditioning and Heat for Ford Fusion Logo
41 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
