Question about Intel Play QX3 Monocular Microscope
QX3 microscope I dont have the cd driver to instal in my computer windows 8, can some one help me please?
    Sniper:
  • 72 Answers
Here are the instruction for installing the QX3 (or QX3+) Microscope with Windows 8 and Windows 8.1. You must be using a 32-BIT VERSION of Windows 8 or 8.1.
Note: The QX3 is not compatible with 64-bit versions of XP, Vista, Windows 7 or 8.
Note, DO NOT use the software from the CD that came with the microscope.
DO NOT plug in the QX3 microscope until Step 4.
Step 1. Download and run the QX3plus.exe program from:
http://tinyurl.com/QX3-Win8-1
After the program installs, uncheck "I would like to view the README file." Click "Finish".
Step 2. Download and run the qcodinstl.exe program from:
If asked about NTVDM, click "Install this feature" then click "Close"
Step 3. Download IntelQX3driverXP.zip and save (do not open) the file from:
Step 4. Now, plug in the microscope. The driver should load silently.
If the "Found New Hardware" wizard appears and you get a message saying that the driver installation was not successful. Click the Close box. You need to install the driver manually by following these steps:
a. Right-click START - Select "Device Manager"
b. Right-click on the Intel QX3 Icon and select "Update Driver Software", select "Browse my computer for driver software"
e. Browse to the Download folder with the extracted QX3 drivers from Step 3. above. The driver software should install successfully.
IMPORTANT: Before you run the QX3Plus program for the first time, right click the "Intel Play QX3 Microscope" icon on the desktop, click "Properties", click the "Compatibility" tab, check the box next to "Run this program in compatibility mode for:", then choose "Windows 98 / Windows ME" in the drop-down box. You should also check "Run as Administrator" if your account is a "Standard user". Click "Apply" then "Ok".
Step 5. Finally, double-click the "Intel Play QX3 Microscope" icon on the desktop and the program should run.
If you get a message that the microscope is not plugged in, quit and restart the program.
If the program hangs or crashes, reboot the computer, then restart the program.
Comments and suggestions to mmehall [at] yahoo.com
Posted on Aug 11, 2014
  • 72 Answers
SOURCE: need drivers for intel qx3 microscope i have vista os
Instruction for installing the QX3 Microscope with Vista
Step 1. Install the QX3+ downloaded from Intel:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&Inst=Yes&ProductID=160&DwnldID=4419&strOSs=All&OSFullName=All%20Operating%20Systems&lang=eng
Step 2. Download and install the QCODINSTL Codecs software from:
http://www.intel.com/support/intelplay/qx3/sb/cs-016002.htm
Step 3. Download and extract the QX3 Drivers from:
http://hyperslug.s3.amazonaws.com/IntelQX3driverXP.zip
When the "Found New Hardware" wizard appears, select "Locate and install driver software (Recommended)", a message "Installing device driver software" will appear. If you click on "details", you will notice see "Searching Windows Update", after a while you will be able to select "I don't have a disc. Show me other options" and browse to the folder with the extracted QX3 drivers from Step 3. above. The hardware should install successfully.
Double-click on the QX3+ icon on the desktop and the program should run.
Posted on Nov 30, 2008
  • 72 Answers
SOURCE: qx3 miroscope
This worked for my QX3 on my Vista computer!
When the "Found New Hardware" wizard appears, select "Locate and install driver software (Recommended)", a message "Installing device driver software" will appear. If you click on "details", you will see "Searching Windows Update", after a while you will be able to select "I don't have a disc. Show me other options" and browse to the folder with the extracted QX3 drivers from Step 3. above. The hardware should install successfully.
Posted on Dec 05, 2008
  • 72 Answers
SOURCE: QX3 micrscope dont work with Vista
Uninstall the existing Intel microscope software and then follow the steps below.
Instruction for installing the QX3 or QX3+ Microscope with Vista
Step 1. Install the QX3PLUS.EXE software downloaded from Intel:
Step 2. Download and install the QCODINSTL.EXE software from:
Posted on May 24, 2009
  • 72 Answers
SOURCE: vista driver for Intel QX3 Microscope
  • 4 Answers
SOURCE: I have QX3 computer microscope
I could not find driver. I placed in Windows 98 compatibility mode on my Vista. I right click Intel Play shortcut...go to "Open File location". Find QX3 application....right click. Go to properties...Compatibility tab and choose windows 98 / Windows ME. Click ok. Worked for me hope it works for you!
Posted on Aug 10, 2009
I need dowland drivers to intel play model APB 24221 99A
Here are the instruction for installing the QX3 (or QX3+) Microscope with Vista and Windows 7. You must be using a 32-BIT VERSION. The QX3 is not compatible with 64-bit versions.
Step 1. Download and install the QX3PLUS.EXE software from Intel:
http://tinyurl.com/QX3-Win7-Files
When the "Found New Hardware" wizard appears you will see a message saying that the driver installation was not successful. Click the Close box. You need to install the driver manually by following these steps:
a. Click START - Select Devices & Printers
b. Right-click on the Intel QX3 Icon and select Properties
c. Click the Hardware tab - click Properties
d. Click Update Driver - select "Browse my computer for driver software"
e. Browse to the folder with the extracted QX3 drivers from Step 3. above. The driver software should install successfully.
Before you run the QX3Plus program right click the icon, click on "Properties", click the "Compatibility" tab, check the box next to "Run this program in compatibility mode for:", then choose in the drop-down box "Windows 98 / Windows ME". You should also check "Run as Administrator" if your account is a "Standard user".
Step 5. Now double-click on the QX3+ icon on the desktop and the program should run.
Aug 13, 2014 | Intel Play QX3 Monocular Microscope
Qx3 microscope driver for Windows 8
Apr 05, 2014 | Intel Play QX3 Monocular Microscope
Windows 7 driver
Step 1. Download and install the QX3PLUS.EXE software from:
Jan 19, 2014 | Intel Play QX3 Monocular Microscope
Digital blue qx3 drivers
Here are the instruction for installing the Intel QX3 (or Digital Blue QX3+) Microscope with Windows 7 or Windows 8.1. You must be using a 32-BIT VERSION of Windows 7 or 8.1.
Aug 20, 2013 | Intel Play QX3 Monocular Microscope
May 02, 2013 | Intel Play QX3 Monocular Microscope
I was given QX3, not QX5 software with instructions in German. My computer is windows 7. should I still install the two intel play disks which came with the computer microscope. Can I install it as...
Mar 26, 2013 | Intel Play QX3 Monocular Microscope
Is there a winndows 7 driver for QX3 microscope please?
Here are the instruction for installing the QX3 (or QX3+) Microscope with Windows 7. You must be using a 32-BIT VERSION. The QX3 is not compatible with 64-bit versions of Windows 7 or Vista.
Before you run the programs below, right click the icon, click on "Properties", click the "Compatibility" tab, check the box next to "Run this program in compatibility mode for:", then choose in the drop-down box "Windows 98 / Windows ME". You should also check "Run as Administrator" if your account is a "Standard user".
http://tinyurl.com/qx3plus or
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&Inst=Yes&ProductID=160&DwnldID=4419&strOSs=All&OSFullName=All%20Operating%20Systems?=eng
http://tinyurl.com/QCODINSTL or
http://downloadcenter.intel.com/Detail_Desc.aspx?strState=LIVE&ProductID=160&DwnldID=2089&agr=N&lang=eng&PrdMap=160
http://tinyurl.com/IntelQX3driverXP or
May 25, 2011 | Intel Play QX3 Monocular Microscope
Vista driver for Intel QX3 Microscope
Jan 10, 2009 | Intel Play QX3 Monocular Microscope
Dec 16, 2008 | Intel Play QX3 Monocular Microscope
Qx3 miroscope
Feb 01, 2008 | Intel Play QX3 Monocular Microscope
Intel Play QX3 Monocular Microscope Logo
169 people viewed this question
Top Intel Science & Laboratory Experts
Gareth Cockram
Gareth Cockram
William McMath
ray gallant
Are you an Intel Science and Laboratory Expert? Answer questions, earn points and help others
