Question about Dishwashers
"Normal Wash" Light blinks intermittently. Washer will not start. I can hit the "Cancel/Drain button and the washer will drain. I have replaced the main circuit board and still have the same problem. What's my next step
  • 9 more comments
  • michaelwatki May 19, 2009
    All of the switches seem to work except for the "On" switch (button). I have replaced the door switch with a new switch.
    "Normal Wash" Light blinks intermittently. Washer will not start. I can hit the "Cancel/Drain button and the washer will drain. I have replaced the main circuit board and the door switch still have the same problem. What's my next step
    Would a bad float switch stop all functions or just the "on" button from cutting on.
    are you able to answer my comments in email form or as a post? thanks
    my float switch is OK. Now where do I go
    Kenmore Ultra Wash Model # 665.16032401
    I'll ask again Are you able to answer my comments in email form or as a post? thanks
  • michaelwatki May 20, 2009
    did not work. the "Normal Wash" light is still flashing and the start button will not activate the dishwasher.
    it's a no go. nothing happened. I have cycled this down for about an hour prior to our start of this conversation. Interestingly enough. the "Cancel Drain" button works and will drain water.
    Ok I will check the lower arm and water inlet assy. Is there a chance that We can continue this dialog tomorrow
    Thank you so much
  • 916 Answers
What model dishwasher is it?
Posted on May 19, 2009
  • 4 more comments
  • machadojr_fe May 19, 2009
    Try Heated Wash, Heated Dry, Heated Wash, Heated Dry
    We can only reply to you here
  • machadojr_fe May 20, 2009
    Please try one more time pressing each one right after another in rabid succession until you have pressed each about 10 times. All the lights should light up and then go through a cycle with a rinse. Please let me know if this does not happen so we can continue.
    Ok then please check the lower arm and water inlet assy
    Chances are they are plugged up and causing the malfunction
    No problem just let me know what you find and I will continue with you as soon as I see it
    Your welcome
  • 355 Answers
Float switch
The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
    Brigadier General:
  • 3,917 Answers
HI,
First make sure the dishwasher is getting power. Check your fuse box for blown fuses. If you have circuit breakers, check to see if they are tripped. Make sure the dishwasher's plug is secure in the outlet.
If power is not the problem, take a closer look at some of the electrical parts of your dishwasher. The most common part to fail is the door switch.
A door switch is used to start and stop your dishwasher. It's a safety feature that won't allow water to flow with the door open. With a faulty door switch, there is a chance your dishwasher won't start at all.
Dishwasher door switches are about an inch long. They are usually black but can be red. There are metal prongs on the body of the switch called terminals. Some door switches have two terminals and some have three.
If your door switch is OK, check the timer assembly. This controls when and how long power is sent to other controls on your dishwasher. If these controls don't receive power, they won't work.
The timer assembly contains a motor. Check this motor as well. It is often cheaper just to replace the timer motor rather than the complete assembly.
My last suggestion is to check the cycle selector switches. These switches indicate cycles for washing, drying, and setting the temperature of the water. If one of your switches is the problem your dishwasher may not start.
Dishwasher cycle selector switches tell the timer which cycle to run by opening and closing electrical circuits. Most selector switches are six to eight inches long. They are usually black and have terminals.
By testing each one of these parts with an ohmmeter you should be able to determine why your dishwasher is not working. It is possible for other parts to fail but these are the most common parts to check.
http://home.howstuffworks.com/how-to-repair-a-dishwasher.htm
Thank You
Updated details: Normal cycle keeps blinking
Have u tried unplugging it for about 2m and plug it bk in that will master reset everything like u just bought it and see how that's works out
Sep 18, 2015 | Dishwashers
Kenmore ultra wash D/W wont start. can cancel things but wont start no heat light and lock on light alternates.
Well, I could be wrong, but is sounds like a bad control module or control console (keypad).
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Jul 20, 2014 | Kenmore Dishwasher With Ultra Wash And...
Amana washer lid lock wont quit blinking
Your washer lid lock button is locked and lid was not put down before it locked, which is why the light is flashing. Therefore, push the "START" button until you see the lid lock button is off (Approx 3 seconds). Once it is off, then you can put the lid down and push the start button again, which will lock the lid into place. The washer will NOT drain or wash or spin unless the lid itself is in the locked position. If you were able to get the lid down and locked and it still doesn't work, then you need a technician to replace a wiring harness. However, you mentioned that the lid lock button was flashing, therefore, it stands to reason that your lid is NOT locked down.
Apr 13, 2014 | Amana NTW4700YQ Top Load Washer NTW4700YQ
Service number kuds301xbl2
I would find the electrical breaker for this unit and shut it off for a minute, then re set the breaker thus resetting your unit.
Apr 28, 2013 | Maytag MDBH975AWS Stainless Steel...
My kenmore dw just stopped running thru cycles except drain
Hello, With the information you supplied I'm going to assume the light is blinking 7 times and pausing then blinking 7 times and so on. With the door cracked open hit the following button combination: -high temp wash
-heated dry
-high temp wash
-heated dry Then close the door and hit cancel. The pump will run for a few moments and then you should be all set. Hope this helps Mike
Nov 19, 2009 | Refrigerators
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
Blinking red lights and no washer operation
Dave, glad I could help, I'll mark this one as solved.
Jun 12, 2008 | Kenmore 4292x Front Load Washer
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Dishwashers Logo
144 people viewed this question
Top Dishwashers Experts
