Question about Frigidaire 30" Self-Cleaning Slide-In Gas Range - White
Frigidaire ples389ech F13 error code when broil is selected
4 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: whenI try to bake or broil--get error msg. F13
Unplug the oven.
Wait 30 seconds and plug it back in.
If the code reappears you must replace the EOC.9electronic clock).
Posted on Mar 04, 2009
SOURCE: Receiving Error F13
Turn the breaker to the stove off for one minute, reset time and everything should work just fine. It worked for me.
Ken
Posted on Jun 01, 2009
  • 35 Answers
SOURCE: getting F13 err code when trying to bake or
Hi william_j522,
the F13 error is related to the clock. this error can occur when the clock looses communication between the keypad or any of the sensor in the stove, including the heat probe. sometimes resetting the power will fix the problem.
try disconnecting power to the stove completely and flip the corresponding breaker on and off on the breaker box.
wait 30 seconds and than turn everything back on.
if the problem returns after power-up, replace the clock.
Regards
R.K.
Posted on Oct 22, 2009
Frigidaire fault code f13 kitchen range what does that mean ?
Thank you for your inquiry, raymond bouley!
I understand that your Frigidaire range is displaying an error code of "F13". An "F13" error code typically stands for a bad EEPROM (Erasable Programmable Memory) identification or check sum error. The best way to clear this code is to disconnect power from your range for roughly ten minutes. If you continue to experience an issue it could be a possible that you have a faulty board or wiring harness. I would then recommend having a professional out to perform a diagnosis on your range. Hope this helps. -Matt
Jan 13, 2015 | Frigidaire Kitchen Ranges
I have a frigidair Gallery Series Range. All of a sudden I get a F13 error code when I try to Bake or Broil
hmmm...can you go to the main circuit breaker panel, turn off the power to that unit, and reset it, by turning the breaker back on. You'll need to reset the clock after this, yet you may find you'll be in good stead.
Apr 28, 2008 | Kitchen Ranges
F13 tappan error code, what is it? tappan goes from code 12 straight to 14? there isn't a 13
the code is for the clock timer for bake and broil. The "clock board" will have to be replaced. About $120.
Dec 15, 2014 | Tappan Kitchen Ranges
F13 code
Hello friend, thank you for your post!
Based off the information you have provided your question is under an "F13" error code but you also stated that it is showing you an "F1" error. I have researched both error codes for you. "F13" usually indicates error identification, which could be an issue within your control board. "F1" typically can indicate that the range has detected an issue with the runaway temperature (overheating). Both codes could be corrected with a reset, which you can do by flipping the household circuit breaker for roughly ten minutes. If that does not correct the issue I would recommend contacting a professional. I hope this is helpful. -Matt
Aug 07, 2014 | Frigidaire Ovens
Why my oven shows f 13
your eoc is bad, electronic oven control (clock)
Apr 11, 2013 | Frigidaire FEF336BC Electric Kitchen Range
I get a error f13 when i turn on broiler
http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx
Above are the codes and meanings.
The "F13" error code means "Bad EEPROM identification/Checksum error".
If reseting the power does not help then according to Frigidaire suggested corrective action the electronic oven control (aka EOC) has to be replaced.
- The part number for the EOC is AP3874704
Dec 13, 2010 | Frigidaire Kitchen Ranges
Error f13 on my frigidaire oven how do i fix it
If reseting the power did not help then according to Frigidaire suggested corrective action the electronic oven control (aka EOC) has to be replaced.
Feb 19, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Getting F13 err code when trying to bake or broil. Frigidare model PLES399EC
Hi william_j522,
Regards
R.K.
Oct 22, 2009 | Frigidaire PLES399EC Electric Kitchen...
WhenI try to bake or broil--get error msg. F13
Unplug the oven.
Mar 03, 2009 | Frigidaire FEF352 Electric Kitchen Range
Receiving Error F13
Ken
Jan 08, 2009 | Frigidaire PLCS389DC Dual Fuel (Electric...
Frigidaire 30" Self-Cleaning Slide-In Gas Range - White Logo
44 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
