Question about Remington Health & Beauty
Why does my Remington P-6020 battery keep discharging completely?
I can charge the shaver for hours to get the battery charged Even if it is charged and I store it for a day, the battery is completely discharged. How do I remove it?
5 Suggested Answers
SOURCE: Remington shaver RS4843 Microscreen 2
Bypassed batteries. still no good. bought new shaver
Posted on Jun 05, 2008
EwingElect
  • 276 Answers
SOURCE: New Remington MS 280. Unable to charge after the first few shaves
Check the powerr lead in the first instance. If there's no power from the lead it may need to be replaced.
Otherwise there could be a problem with either the control board or the batteries. It's only a recent model so I'm leaning towards the lead.
Posted on Apr 05, 2009
brector3
  • 1623 Answers
SOURCE: Braun 790cc Shaver battery not holding charge
the item has a 2 year warranty. if you have proof of purchase date, you should call Braun for warranty service. Phone number is in your owner manual
Posted on Jan 16, 2010
brector3
  • 1623 Answers
SOURCE: My rechargeable Remington R960 shaver
You will find the correct battery type at shaveroutlet.com. See link below. You will need two
http://shaveroutlet.com/shaver-replacement-parts/batteries/shaver-battery-pack-for-most-shavers-p-211.html
Posted on Dec 21, 2010
Remington model PG 6020 3.6-4
How old is it? many of the Nicad and Nimi batteries of old held less and less of a charge as they get older.
Jul 27, 2014 | Remington Health & Beauty
Battery not holding charge very long
I've written up a complete step-by-step tutorial on how to replace the battery on a Remington MB-300 Beard trimmer: John Fixes Stuff How to Replace the Batteries in Remington MB 300 Beard...
Apr 06, 2014 | Remington MB-300 Beard Trimmer
I was given a norelco 3605 shaver in excellent condition (used) without instructions and would like to know the charging procedure and duration (the amount of time it takes to fully charge the razor). Is...
The manual says to charge for 16 hours if it has not been used in awhile. They say nothing about it over charging, but the batteries need to be used and let discharge through shaving. A fresh/new battery is supposed to last about 2 weeks before needing a recharge. I think keeping them charged all the time cuts down on battery life.
Jun 07, 2011 | Norelco 3605 X Electric Shaver
My remington ta 4570 suddenly won't charge or even run off the power. the light won't even come on. I know its an older model, but I don't use it that often. any ideas? Thanks
When batteries go completely bad, the shaver will stop working altogether. Most likely, you will just need to change the batteries. But you should open the shaver and inspect it first to make sure there is not a lot of corrosion or any burnt spots on the circuit board.
You will find batteries at shaveroutlet.com. See link below. You will need two batteries.
http://shaveroutlet.com/shaver-battery-pack-for-most-shavers-p-211.html
Apr 22, 2010 | Remington MicroScreen3 TA-4570 Electric...
My shaver will not hold a charge. What could be the problem
Remington model R-9500
Your shaver will not hold a charge because the shavers internal batteries need replacing. If you know how to solder, you can do it yourself or you can have it professionally done. You can purchase batteries or professional repair service from shaveroutlet.com. See links below.
http://shaveroutlet.com/professional-battery-replacement-for-most-models-p-374.html
If you feel this is something you want to try yourself, you will need to remove the back cover of the shaver. You will easily notice two screws on the back. There is a third screw that is near the very top on the back and it is underneath the trimmer where the trimmer connects to the shaver. Remove these 3 screws to take off the back cover.
Inside you will see the batteries. You will need to remove the metal clip that helps secure them into place. You will then need to use a soldering iron to remove the wires from the ends of the old batteries. Solder the new batteries to the wires and put everything back together in reverse order
Once the job has been completed, charge the new batteries for 24 hours.
Jan 24, 2010 | Remington Titanium SmartSystem R-9500...
Sirs When charging razor #3 for first time, for over 4hours as stated by you. The razor is NOT fully charged. Could this be a faulty Braun?
Hello, typically when you charge a new electric shaver for the first time, it can take up to 10-12 hours for the batteries to get a full charge. Even then, it will take several charge - discharge cycles before the batteries are able to accept and hold a true, full charge.
With any battery appliance or tool, it is best to use the item until it is fully discharged or stops working and then allow the item to cool down for at least 30 minutes before recharging the battery device. If you follow that recommendation, you'll get a longer working life out of the batteries before they need to be replaced.
You can give the above a try and see if that helps get the shaver to take a full charge and go from there.
Hope you find this Very Helpful and best regards!
Nov 07, 2009 | Braun Health & Beauty
Braun 5614 rechargeable cordless shaver light flickers
Your batteries are starting to degrade, but the good news is they're still holding a charge for a week, so you really don't need to rush to replace them at this point.
The flickering of the charged indicator is normal, as the shaver is still plugged in and the batteries are fully charged. The flickering is due to the batteries chemicals breaking down, and as such, the charge cycle keeps "topping" them off while it's still plugged in.
When you finally aren't able to get a decent amount of cordless operation and run times from your shaver, then you'll want to get them replaced, whether you decide to do that yourself or have it done by a professional service center, is up to you.
Here's a reference for your future use. www.electricshaver.com carries replacement (factory OEM) batteries for most brands of shavers and they also will provide the repair/replacement service for you, should you decide you don't want to do it yourself. You can also give them a call at 1-888-476-1785 and request a price quote, etc.
Anyway, your shaver is working fine and all you need to do is make sure you're not letting the shaver stay plugged in and charging constantly for more than a day, since any "extra" chargind isn't doing anything except keeping the batteries at a constant state of charge. Heat is a byproduct of charging and discharging any battery and as such, you want to allow for a cool down period before recharging them.
I tend to use my shaver until it is almost completely discharged before recharging it. By doing this, you can get the longest working life out of your batteries before you'll have to replace them.
Oct 21, 2009 | Braun Flex XP 5614 Electric Shaver
Braun shaver won't charge
Batteries have an expiry date, Even if you're not using them they are still discharging. Even the regular AA type you buy at the shops.
Batteries can die even if there is a lack of use. And even regular rechargeable shavers that are used all the time have only a limited life a little shorter that=n what you've had.
Should you get new batteries or a new shaver? probably not, you're using 2-3 times a year. I'd recommend buying a cheap Braun or Remington that can take AA's.
Apr 07, 2009 | Braun Health & Beauty
May 14, 2008 | Health & Beauty
Health & Beauty Logo
42 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
