Question about MD Sports Sport & Outdoor - Others
Air hockey table has air bubble causing uneven surface.
  • 8 Answers
SOURCE: what is the best air hockey table?
It really depends on what you are looking for: who are the players - young or adults? Do you have money limitations? Do you have space limitations? If you are looking for the nest one, try the Dynamo Hot Flash II Air Hockey Table. Its $3,800. If you want cheaper tables you can go to: http://www.justairhockeytables.com/ and sort them by "best sellers" you'll get the most popular ones.
Posted on Jul 09, 2012
  • 10 Answers
SOURCE: How do I clean my air hockey table?
Air hockey tables can be cleaned with isopropyl and paper towels. Make sure not to use too much at once, and then dry it off with the paper towels, so the alcohol will not soak into the table surface. Note that you should not clean the rails as the dirt inside the rail actually prevent the pucks from flying off the table.
  • 35 Answers
SOURCE: Which Air Hockey table should I buy?
If you want an approved for USAA tournaments then you can check out any of the 8 foot long Dynamo Air Hockey table, just stay away from the "Hot Flash" series.
In the "Hot Flash" Air Hockey tables the painted rails make the puck fly off a lot, and fluorescent table-top makes it hard to see the puck.
A new Dynamo table price varies from $1500 to 2500$ so you should take it into consideration.
Posted on Jul 25, 2012
  • 35 Answers
SOURCE: What's the optimal height of an Air Hockey table?
Theaverage Air Hockey table height is 32 inches, there are also higher tables upto 36 inches if the average 32 inches is not comfortable for you, check outthis sitehttp://www.bmigaming.com/games-sports-airhockey-commercial.htm for more information.
  • 35 Answers
SOURCE: What's the size of a standard Air Hockey table?
There are many types of Air Hockeytables out there. The usual s of an Air Hockey table shifts between 76-84inch long and 44-52 inch wide, the of the surface is 4 inches less thanthe actual of the whole table.
What is a combination air hockey table?
A combination air hockey table is actually an air hockey table that can be transformed to another type of game. For instance, there are hockey tables that can quickly change into a foosball table.
Aug 08, 2012 | Sport & Outdoor - Others
What are different types of air hockey tables?
There are two main types of air hockey tables: recreational (basic) tables and tournament (high-level) tables. Recreational tables come in different s, prices, and obviously, quality. Tournament tables on the other hand are 8 foot long and have the highest quality possible. For more information on air hockey tables, go to these websites: http://www.livestrong.com/article/247618-types-of-air-hockey-tables/ and http://www.justairhockeytables.com/air-hockey-tables/airhockeybuyingguidearticle.cfm
What should I use in order to clean the surface of my air hockey table?
The optimum way to clean the surface of an air hockey table is with isopropyl alcohol. Simply spray it on the surface and quickly dry it off with paper towels.
What's the best air hockey table?
The Valley-Dynamo Hot Flash 2 8 Foot Air Hockey Table is considered to be the best Air Hockey table of all times, this table is the standard table of all the professional tournament although it's price is a bit price if you want to buy it, something like 4000 dollars.
Jul 25, 2012 | Sport & Outdoor - Others
What's the purpose of the tiny holes on the surface?
Air Hockey tables will typically have some sort of machinery that produces a cushion of air on the play surface through those tiny holes, with the purpose of reducing friction and increasing the play speed. In some tables, the machinery is eschewed in favor of a slick table surface, usually plastic, in the interest of saving money in both manufacturing and maintenance costs, this table are not really Air Hockey tables and are not considered as one.
How should I clean my air hockey table?
The best way to clean the surface of your table is with isopropyl alcohol and paper towel. Either spray it on the table surface with a spray bottle, or cover most of the bottle's mouth with your thumb and shake a little bit of it on the table at a time, so as not to use too much at once. Dry it off immediately with the towels, so that the alcohol doesn't soak up into the table surface. There is on important thing you have to remember, do not clean the inside of the table rails! The dirt and grime on the inside of the rails actually helps keep the puck from flying off the table.
Jul 09, 2012 | Sport & Outdoor - Others
Water left on table a few of the air holes have raised bubbles around them, tried pushing on them but they will not go down, anything we can do without replacing the top.
can you remove the top and put it on a flat surface for support ( to prevent warping ) then press down gently on the holes with a large glass marble or something similar , would that do it ?
Oct 16, 2009 | Harvard Xh 7000 Hockey Table
Air flow hockey table
We made a fixture that allows us to clean the table top. We took a piece of wood larger than the fan opening, drilled a hole in it, and installed an air fitting for use with our home air compressor. WIth the fans removed, we run the compressor and hold the fixture against the bottom of the table. That forces all that air to exit out the table surface. To concentrate the flow over problem areas we cover sections of the table during the process. Also, you may need new pucks too if they are old and worn.
Dec 09, 2008 | Dmi Sports Air Hockey Table Dmi Goal Flex...
Sport & Outdoor - Others Logo
66 people viewed this question
Top MD Sports Sport & Outdoor - Others Experts
Are you a MD Sports Sport and Outdoor - Other Expert? Answer questions, earn points and help others
