Came home from vacation - noticed that the power to our house had been off & then turned on. The Mitsubishi TV has a blinking green light & under that light it says Timer. Have tried disconnecting the Tv & then plugging it back in - still has the green light. The Model WS48511 - bought Feb. 2003. Please advise Thank you. Richard
  • beth_lundin May 20, 2009
    Thank you - I am waiting this morning for a TV Repairman.
  • 8,617 Answers
Very common and easy repair the DM capacitors need replacement. Heres a kit for your model the kit contains the capacitors and the instructions .
http://servicemanuals.vstore.ca/product_info.php/pName/v21v19-mitsubishi-dm-repair-kit/cName/repair-kits
Posted on May 20, 2009
Blinking Green Light on Mitsubishi DLP 52525
the circut that detects the bulb has been also failing in these sets
and the conversion chip that controls the picture , and the transformers are not putting out the full power they are supposed to.
this set will need to be tested to determine the exact cause or causes
Oct 18, 2008 | Mitsubishi WD-52525 52" Rear Projection...
My mitsubishi tv W55613 won't turn on. green light keeps blinking even after resetting
Hit the front of the tv near the blinking light... give it a good rap or two. See if this helps. Helped mine. I had the same problem and the tech who came out to the house told me that it would work and it did! I could hardly believe it but it worked.
Feb 13, 2012 | Mitsubishi WS-55613 55" Rear Projection...
After researching online, my TV problem seems pretty common. TV - Mitsubishi 1080 series WS 55511. Green blinking light blinks for 3 seconds, then goes out and TV never turns on, but I hear a slight...
The green light is known as "The blinking green light of death". This refers to the green LED on the front panel of the TV that normally blinks when turned on after a power failure or when unplugged: the green light is supposed to flash for about 1 minute while both microprocessors boot up: If it won't stop blinking it means that they aren't communicating w/each other. Unfortunately, it's common in Mitsubishi & other RP TV's. Getting this fixed by a professional is around $6-700 with labor, parts, etc. It's really not worth it in my opinion. I would go out and buy an LCD or an LED TV.
Nov 28, 2010 | Televison & Video
I have a WD-52725. When I came home tonight I had noticed that the power had went out at the home. The timer light was blinking green. I do have a surge protector. I tried reset and turning the power off...
Thats a common problem caused by weak caps on the DM and Power boards. When the power goes out the caps drain then cannot recharge so the syeady blinking timer light will happen. You can get the V26 Chassis DM / Power repair kit from www.tvrepairworld.com which has the replacement caps and the CD with repair instructions.
Aug 20, 2010 | Mitsubishi Televison & Video
Power blinking green light
Power supply section may be the problem, that will be the first place to look, look for caps with leaking/bulging tops, see examples of failed TV and monitors due to bad caps here;
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 13, 2010 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Mitsubishi ws-73711 turns on (I see a green power light) then off
press and hold 'device ' and 'menu' buttons on front of tv until the power light starts to blink out an error code . It will blink a few then pause and....repeat.. . Count the blinks. It is giving a two digit error code and repeating it 3 or 4 times. 22=low voltage short detected usually caused by the convergenge amp I.C. .12=normal
Oct 03, 2009 | Mitsubishi Diamond WD-65831 65" Projection...
Blinking green light
TRY TO GET TO THE MENU, SETUP, AND EDIT YOUR SETUP SO EVERYTHING IS DEFAULT. I TOOK A 2001 50" HOME LAST NIGHT, MY SLEEP TIMER LIGHT ON THE FRONT, BLINKED FOR A FEW MIN. THEN, YOU CAN TURN IT ON AND RESET.....HOPE IT HELPS.......????
Dec 07, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Televison & Video Logo
248 people viewed this question
Top Televison & Video Experts
Electro Med Services...
