Question about Home
Ideal standard soft close toilet seat loose - Home
kachbibi1
  • 979 Answers
SOURCE: How to tighten the hinges on a slow close toilet seat?
You don't want to overtighten since you could crack the porcelain. Are your rubber washers in good shape? This will help. You should be able to do this w/out doing any damage.
Posted on Jan 28, 2009
  • 33 Answers
SOURCE: Quiet-Close Kohler toilet seat lost its quiet close feature
Hello len_moon, Look under plumbing in your yellow pages for a Kohler distributor. Also here is the web page for you part numbers. You will need the hinge assembly. Copy and Paste to your address bar. Hope it helps!
http://www.kohlerserviceparts.kohler.com/ServicePartsPage.aspx?DocumentID=c83b1f213d0545f984b01b9f0be37b9d&ModelID=558da26604ce43ec98c83fe8ed0aa604
Posted on Feb 03, 2009
  • 2976 Answers
SOURCE: slow closing toilet seat not working
It needs a new air shock on it. You might be able to take the old one apart and fix it but replacement would be best.
Posted on Feb 18, 2009
  • 54 Answers
SOURCE: loose Toto toilet seat
Lift up plastic caps located on ends of hindge behind seat. use flat screw driver and hold the nut under the outside toilet rim with your fingers or a pair of pliers. Do not over tighten or might crack the bowl.
Posted on Sep 14, 2009
SOURCE: Square toilet seat made by American Standard Model TL 235.
This guy Allen in NY has lots of odd seats. Try him 914-963-6895
Posted on Nov 09, 2009
How to tighten a vitro nupva toilet seat.
Christina, how to tighten or install hidden fasteners on your toilet seat. check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Remove Vitra Shift toilet seat
Soft Close and Quick Release Toilet Seats Installation
How to fix loose toilet seat
http://vitraglobal.com/
Jun 27, 2016 | VitrA Home
How do I remove toilet seat?Appears to be 2 bolts with top access only.
rak soft close toilet seat - YouTube
? 0:31
https://www.youtube.com/watch?v=RLssM9BYJjg
Oct 9, 2013 - Uploaded by Paul Hooker
rak soft close toilet seat. ... How to remove and change a Villeroy & Boch toilet seat with top fixings ...
Rak Series 600 Back To Wall Toilet - YouTube
Nov 29, 2015 | Home
Fix an american standard slow close toilet seat
Check the chain the goes between the handle and the flapper.
It should not be taught. If it is it will not permit the flapper to seat
properly and water will leak out. Adjust the chain length so the flapper is seated and there is just a little slack in the chain.
Aug 02, 2014 | American Standard Cadet 3 Right Height...
Subway toilet, can't access soft close lid under toilet?
You will need to remove the toilet and access the bolts from inside the enclosure. It is a dirty job.... good luck!
Mar 02, 2014 | Villeroy & Boch Home
Soft close toilet seat
Mine is a Bemis and does the same thing. Seat drops and lids does a slow close! Are you going to takes yours back for a new one?
Jan 18, 2014 | Home
The toilet see is not tight. How can I tighten the seat? I have an elongated seat with the soft closing lid.
Right behind the bowl on the underside there is a nut on either side that holds the seat on...tighten those nuts and it will tighten down the seat...
heatman101
Aug 29, 2010 | Toto Aquia II Dual Flush Toilet
I have a Jika Mio soft close seat with a loose hinge which I cannot reach due to closeness of pan to wall!!
The top lid of my soft close toilet seat slams shut.How do I adjust Jiko Mio close coupled toilet.
Mar 27, 2010 | Villeroy & Boch Home
One of the softclose buffers on the Subway toilet seat has pulled
Each soft close 'Barrel' is handed - one left - one right. (One is grey - the other white).
Most soft close errors occur because the seat hinges come loose. When this happen, the barrels slightly pull-out of the seat. (There are silver discs on the barrels - These should be tight against the seat).
Once the barrels become loose the first thing that happens is the top cover won't soft close - but the seat still does.
To rectify - puch both barrels tighly into fitting and tighten the hinges. (See below).
To tighen the seat hinges you need to get a flat headed screwdriver underneath the chrome round hinge cover - and 'flick off'. Underneath is a X head screw which id also hexagonal. You can either tighen both by spanner - or screw driver. (sometimes these can be tricky - but it will come off).
If both cover AND seat do not soft close AND the barrel silver discs are firmly located against the seat - the barrel has probably broken.
If so - spare parts can be obtained here:
http://bathroomstudio.co.uk/villeroy-boch-spares/cat_131.html
Jun 15, 2009 | Villeroy & Boch 9955 S1 Subway Toilet Seat...
Home Logo
29 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
