Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
Payne air handler wiring diagrahm PF1MNA036 needed
I have a payne airhandler blower motor want come on blower model 5sme390x
Many air handlers have a safety switch on the filter access cover panel, our on the electric control panel. The switch may not be making contact, try moving the cover to try making the south work, or remove the cover and verify there is a switch, a button switch and operate it by hand with the a.c. on, user caution with rotating parts.
Nov 02, 2015 | Heating & Cooling
Need wire diagram from T-stat to Air-Handler then cond unit
green goes to g on air-handler,white goes to w on air-handler yellow goes to outside condensor, red from air-handler goes to rh-rc on thermostat, whire off c on air-handler goes to outside condensor.
May 13, 2014 | Ruud Heating & Cooling
I have a Payne Rooftop Gas Heater that had a bad thermostat, and when I replaced the thermostat I believe that I shorted a wire and blew the low voltage fuse on the 24v system when I had the wires hoo
Go to the air handler and look near the transformer for a 3 amp blown fuse. Pull it out and put a new one in (it resembles a fuse used in cars).
Dec 09, 2013 | Heating & Cooling
Berrow fan doesnot stop running after ac shout down
It is snubber problem. It causes due to emf field in fan motor. You have to just add a snuuber component in pcb or problem can be removed by switching mains off
Oct 14, 2013 | Carrier Bryant Payne Air Handler Control...
I have a E2EB-017HA air handler and I want to change it to a variable speed motor. Is this possible
Some companies do sell a variable speed kit. It includes the motor and controls. Get your model and serial number of your unit and contact your local Payne dealer. The can locate the proper kit if available for you.
Feb 03, 2013 | Intertherm E3EB-017H Furnace 17Kw 2
Payne air handler with possible GE X13 Failure
Check your dip switch settings on tonnage and your CFM per ton settings. Also make sure they wired the the low voltage for cooling to Y and not YLO if its a single stage compressor system.
Sep 23, 2012 | GE Carrier Bryant Payne 1/2 Hp 115 230v...
WIRING THE THERMOSTAT TO AC UNIT THEN FROM THE UNIT TO HANDLER
Generally, you would go from the thermostat to the air handler, and then, from the air handler to the outdoor unit. I don't know if you have a heat pump or not, so I will give you a simple diagram and you can contact me if you need more.
Thermostat : Y G R W and sometimes C
Air handler: Y G R W and C
Outdoor unit: two wires connecting to the contactor ( not heat pump)
Thermostat; Y--------------Y(air handler cooling)------------------one side of contactor, outdoor unit
G-------------G (air handler, fan)
R--------------R (air handler ,hot)
W-------------W (air handler, heat)
C--------------C (air handler, common)------------other side of contactor, outdoor unit
This is a typical wiring diagram. Just contact me if you have something different. Hope this helps. Stay cool. mark
Jul 10, 2011 | Heating & Cooling
Have a Payne A3PZ airconditioner and a Roberts Aire thermostate need help with wireing it up. The was I understand is that you need a Payne therostate to use with Payne AC unit. But surely there is a...
No, Payne is a cheap Carrier unit. Keep track of your wires and what terminals they are attached to. Usually, units are either a 4 wire or 5 wire setup. In either of these the R terminal is your 24v power, G term is your fan, W is your heat, and Y is your cool. Some times there is a 5 wire which is your common. You use a common if your thermostat isn't powered by a battery. On the R terminal, they are usually marked RC/RH and have a jumper between them. The only time you should remove the jumper is in a 5 wire set up. RC refers to the common and RH refers to Hot or power. Make sure that when you are installing the new tstat there is usually a very small switch that you change for either an electric unit or a gas unit. Change according to what you have. As long as you keep track of your colors and terminals on your old tstat, you won't have to open up your unit to see where the wires are terminating. Good luck to you!
Mar 22, 2009 | Heating & Cooling
Townhouse ac/heater combo won't start
I am not familiar with this air handler, but I haven't found too many with fuses. You just blow the transformer... but if you found a place that says there is a fuse, maybe there is.
If you can use a volt meter, check the voltage between the red and blue wire in the thermostat. It should be 24 volts AC. If it is there, your problem is something else... Some might suggest you use a short jumper wire from the red to the green and see if the fan comes on to check your 24 volts if you don't have a meter, but I would never suggest that...
If you determine that the 24 volts is not there then you should find that transformer in the air handler and follow the leads out and see if they lead to the fuse, if it exists. You might consider that the transformer is bad if you can't find a fuse. If able, check the primary for your supply voltage, 115 or 230 volts AC, and the secondary, 24 volts AC.
If your lucky, someone that is familiar with this model will answer with all the locations, etc...
Always be careful when working with electricity. If you decide to get into the air handler to troubleshoot your transformer, turn off the breaker while exploring and only turn it back on when you are ready to make voltage measurements and are confident that you know what you are doing.
Jul 17, 2017 | Heating & Cooling
Wiring Diagram
here is a basic wiring diagram for all air cond systems your thermostat consist of treminal r w y and c run a four conductor wire fromm thermostat to ai handler the air handler should allso have eather have red blue white wires or a teminal block marked r w c r stands for red w for white c for comon allso blue run color for color from the thermostat to ai handler with exeption of yellow yellow runs straigth to condenserand retuns in white wire to air handler wich gets conected to comon hope this help[s you
Sep 02, 2007 | Ruud UBHC Air Conditioner
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
137 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
