Question about Sony Xperia tipo dual ST21i2 Smartphone - Unlocked | Current
St21i2 wifi problem - Sony Xperia tipo dual ST21i2 Smartphone - Unlocked | Current
There is a sensor problem in my sony xperia st21i
perform a soft reset, this should resolve the problem. the button is located behind the micro sd card slot cover, small red, you can't miss it. search on line regarding Xperia soft reset instructions, pretty simple and fast. you won't loose any data.
Dec 13, 2014 | Sony Xperia Tipo Dual ST21i2 Black Android...
What the unlock code for Sony Xperia M2 please ?
Your service provider has to authorize the unlock and they will provide the code. The account has to be out of contract and paid current before they will unlock it.
Aug 10, 2014 | Sony Xperia Tipo Dual ST21i2 Black Android...
SONY XPERIA ST21I2 ADB DRIVER
Install The flashtools drivers:Flashtool drivers exe Google Drive
After install plug phone in to PC(make sure USB Debugging is enabled on the phone) if driver does not install itself go to Control Panel --> System --> Device Manager and look under Other devices there will be one named Sony Xperia(will have a yellow Question mark next to it) right click choose "update driver". Choose "browse my computer for drivers" on next screen choose "Let me pick" option. under manufacturer choose Sony Ericsson and then install the ADB driver(If the Sony driver does not work try installing the google ADB driver that can be found in the Android SDK)
May 28, 2014 | Sony Xperia tipo dual ST21i2 Smartphone -...
Why does ST21i2 restarts itself
Restarts on Android happen sometimes just like with any other OS(windows,etc.) if it constantly restarts itself(Bootloop) then try a factory restore.
May 06, 2014 | Sony Xperia Tipo Dual ST21i2 Black Android...
How to find pin from access point option in wifi settings of tipo dual ?
It is not possible to extract the stored password once connected to the network. There was a loophole previously in which wifi passwords can be accessed from the phone through an xml.
instead now to connect to your home network you should use the wps button on your router and connect it.
Apr 17, 2014 | Sony Xperia Tipo Dual ST21i2 Black Android...
My sony xperia tipo(DUAL) touch screen freezes after every 15-20 minutes of standby . plz helpp !!!!
There is a solution by Sony for this problem.
Just follow the instructions: http://talk.sonymobile.com/t5/Xperia-miro-Xperia-tipo-tipo/TIPO-TOUCHSCREEN-FIX-PATCH-HERE/td-p/262920
Sep 27, 2013 | Sony Xperia Tipo Dual ST21i2 Black Android...
I need to wipe/clear my Sony Ericsson Satio/U1 mobile device as I am selling it. Any ideas?
1.Tap Dialler and enter *#7370#
2.Tap Yes to restore all original phone settings
3.Enter the lock code (0000 by default) and tap OK
4.The phone restarts
Mar 11, 2010 | Sony Cell Phones
Sony Xperia tipo dual ST21i2 Smartphone - Unlocked | Current Logo
Top Sony Cell Phones Experts
Gil Shultz
Andrew Taylor
Andrew Taylor
Are you a Sony Cell Phone Expert? Answer questions, earn points and help others
