Have a Wurlitzer 2910, the coin mech just stopped working and while cleaning the contacts near the selection buttons, a screwdrive hit one of the contacts and now the carousel will not work when you select the song. It worked great until then accept for one slight problem, any of the songs in the 1 category (A-1, B-1 etc, when selected would play the 3 category (A-3, B-3, etc)
  • 275 Answers
SOURCE: Turntable does not turn
First, try cleaning the lens.Use a good quality Lens cleaner. If this does not work, Open machine and see for mechanical problems - broken belts, etc.
Posted on Oct 02, 2006
MechMusicSF
  • 16 Answers
SOURCE: Seeburg Stereo Phonograph Model ESL100 Q-65-H5
End of record switch out of adjustment or bad? Disconnected?
Posted on Apr 18, 2009
  • 211 Answers
SOURCE: Wurlitzer 3600 series wont select a record ?
If the buttons don't latch in, the machine is not in credit. Put on free play or put some money in.
Dave F.
Posted on Jun 25, 2009
SOURCE: Jukebox won't play selection, selects cd's 1-100 in order
Dear Amanda, Here is the manual,
Try re-programming your juke box per the instructions in the manual.
If you will e-mail me at deeddawg@bellsouth.net , I will E-mail you the 100 page manual in PDF format.
Gary.
Posted on Aug 17, 2009
  • 567 Answers
SOURCE: i have a wurlitzer super star juke box. the
for the manual email me
philhemmings@hotmail.com
Posted on Sep 25, 2010
Maytag Coin Washer can't select Cycle after putting in coins
check the coin mech
If it is turning on properly
check the selector itself.possibly the switch
Mar 18, 2015 | Maytag MAH21PDD Commercial Front-Load...
I have a 1964 rockola princess and I just got it for Christmas . Right now it doesn't play. I have power to it but it will not select. The carisell is also not rotating. Any suggestions ?
Inside usually on the front of the mech is a three way switch.
"OFF" in the middle and "SCAN or OPERATE" on the outsides.
First hold the switch on SCAN to see if the carousel turns.
If it does, put the switch to operate, it may turn some more but then it should stop, or if there are some selections left on it should play them. If it stops then make sure you can give the machine a "CREDIT" either by dropping a coin in if the coin mech works or find the credit button inside and flick it a few times to see if it puts on credits. If everything's ok you should be able to use the keys to select. If you need more help email me or maybe we could Skype.
Email martinyreg@gmail.com
Dec 25, 2014 | Televison & Video
I have a 1946 Wurlitzer 1015, when i make a selection all that happens is a hum from the junction box. The record tray is stuck in the upright position. I can move the motor arm manually but cannot ge
What has happened is the mech is jammed..Seen this before. I unjammed the mech by hand, Also check cam follower bearings make sure the arm that holds the bearing is not broke..
Jun 30, 2014 | Audio Players & Recorders
Seeburg AY160 scans twice wont pick up record
If it still wont select, check the pulse amplifier. It plugs into the selection receiver chassis and has the RCA plug on the top. Open it up and change the capacitor(s) and there is a high value resistor in there as well CHANGE IT! It is commonly bad. Also check the tube, and replace it if it;s ? or weak.
Apr 07, 2014 | Wurlitzer Jukebox 1015 One More Time...
I have a 1962 Wurlitzer 1015 which has a Selection and Credit computer for coins credits. There was this Auto mode which used to be able to use but now, the jukebox can only operate one disc at a time. ...
It would not be 1962 as CDs weren't invented.
Continuous play is achieved by flipping the Continuous Play switch on the right of the computer. Or using the Option button on the remote control. One or the other plugs into GREEN plug on the left side of the computer. If the plug is off it won't work.
Jan 10, 2014 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer Problem
If you are near Sheffield U.K. try The Jukebox Doctor (me) who services Wurlitzers.
May 13, 2010 | Wurlitzer Jukebox 1015 One More Time...
The coin mechanism is hard to push the coin slider, but it works.
Coin mech is held in place with 4 screw heads in key hole slots.
Move the mechinisim UPWARDS about 3mm and wiggle it around to disengage the screws.
The hex bar is only used to stop the mech going upwards.
Sep 12, 2009 | Whirlpool CAM2752RQ Coin Operated...
JUKEBOX WAS SHUT OFF WITHOUT REJECTING ALL THE RECORDS.
What exactly do you mean by "shut off before all the 45's were rejected" ? The mech only load one record at a time, either from the left or right side of the carousel. If the power was shut off before a record unloaded from the turntable, you can manually return the mech to the start position. Do this by getting in to the back of the juke. on the upper right, near the top of the deck, there is a motor. There should be a little white gear coming from the bottom of it. I am assuming if you look in the middle of the mech, you will see a cam with a lobe on one side of it. Turning the white gear will advance the mech adn turn the cam counter clockwise. As the lobe on the cam nears the front of the mech, the record lifting arms should pull down clear of the carousel and return the record to the carousel. Stop turning the gear when the lobe of the cam has driven the lifting arms downward. Inspect your pin bank and push down any "popped" pins. This will prevent the juke from trying to start when you turn it back on.
Hope this helps
Jan 16, 2009 | Wurlitzer Jukebox 1015 One More Time...
35 people viewed this question
 Grubhead
Grubhead
