Question about Genius Twin Wheel F1
The steering is too sensitive
How do I adjust sensitivity ? It is too tight!
2 Suggested Answers
SOURCE: Pen Sensitivity not working
go to
http://driverscollection.com/?file_cid=40927217892cec14ec94967bbb1
Posted on Sep 14, 2009
2004 Toyota Avalon
the adjustment on the windw regulater is set too tight, or the built in safety threshold is set too sensitive. try lubricating the rubber window channels with some petroleum jelly or high grade machine oil.
Jul 08, 2013 | Cars & Trucks
Gateway the touch pad not function why?
Adjusting the touchpad sensitivity on a Gateway laptop lets you fix and prevent annoying touchpad problems.
Often the touchpad is accidentally brushed while typing, which causes the cursor to move out of place.
Or you may find yourself having to tap too hard or too often on the touchpad to open windows and programs.
These problems can be fixed by simply adjusting the touchpad's sensitivity settings.
Click the "Start" button and double-click "Control Panel."
Double-click "Hardware & Sound" and choose "Mouse" to open the mouse properties box.
Choose the "Device Settings" tab. Highlight "Synaptic Touchpad" in the Devices box by clicking on it. Click the "Settings" button underneath the Devices box.
Choose "Sensitivity" in the properties settings box.
Click "PalmCheck" to adjust the sensitivity of the touchpad to accidental brushes against the pad while typing, which causes the cursor to move.
Click and hold the pointer to adjust the setting on the sensitivity scale.
Click "Touch Sensitivity" to adjust the sensitivity of the touchpad to tapping.
A higher rating on the scale means less tapping pressure will be needed.
Click "OK" to save your touchpad settings.
May 15, 2013 | Acer Aspire Computers & Internet
If I want perfect sensitivity, how should I wear my gloves?
For perfect sensitivity the gloves should neither be too tight or too loose at the fingertips. Furthermore, the glove should fit snugly across the palm without being too tight.
Feb 06, 2013 | Clothing Accessories
Cannot locate where to adjust the handbrake on a hyundai Elantra
If you look under the car there should be a cable leading from the front between the seat area to the back tires. The cable should make a "y" before it reaches the tires. There should be a nut on a bolt that you can use to tighten or loosen the handbrake. bring the handbrake to the second click and then make the cable tight with no slack but no bind on it either. When you release the handbrake the cable should be loose but will begin to engage on the second click. You can make it tighter to make it more sensitive if you like or loosen it to make it less sensitive.
Apr 07, 2010 | 2000 Hyundai Elantra
Adjusting the sensitivity of my motion sensors
No adjustment on sensor other than masking its view.
AlarmProfessor.net
Jan 28, 2010 | GE Security Simon 3 Wireless Home Security...
When it started and idle it makes a squeeking noise
The noise is the serpintine belt, these cars are very sensitive the belt needs to be very tight. The adjuster is a long bolt on the side of the alternator.
Sep 10, 2009 | 1998 Jeep Cherokee
My bulldog Model 2010 Alarm is too sensitive and
I got this from their website.
Adjusting the Shock Sensor Sensitivity
To adjust the shock sensor, disarm the system, press and hold Button #3 (Finder) until the alarm chirps four times
(approximately five seconds), immediately release the button. Tap your vehicle’s hood above the alarm at the sensitivity
level you wish. The harder you hit the car the less sensitivity the alarm will be. The alarm will then chirp three
times. The shock sensor is now set at this sensitivity. Any shock that is equal to, or greater than this sensitivity,
will sound the alarm. Set the sensitivity as often as you wish; however, the sensitivity level will remain set until
the battery is disconnected or you reset it. If you do not tap the car it will automatically go to maximum sensitivity.
This setting is only acceptable if the car is parked inside a garage. NOTE: The factory setting on the shock sensor
should be acceptable for most vehicles.
Sep 09, 2009 | Basic Remote Vehicle Alarm System
Make car alarm more sensitive
Locate the shock sensor. Using a small screwdriver you can adjust the sensitivity of the sensor. Move srew in only 1/4 turns as this will make big adjustments. Adjustments may make alarm too sensitive so try it out and see what works for you.
Apr 04, 2009 | Vehicle Parts & Accessories
AV8R not sensitive enough with HAWX
Im guessing you can adjust the sensitivity in the game, or adjusting the sensitivity on the joystick directly.
Apr 01, 2009 | Saitek Aviator AV8R Joystick
Genius Twin Wheel F1 Logo
46 people viewed this question
Top Genius Video Game Consoles & Games Experts
James Wishart
Are you a Genius Video Game Console and Game Expert? Answer questions, earn points and help others
