Not found may problem is: card reader not found, not read. may card reder is intaisxmxc, internal card reader/writer 3.5" all-in-one with usb 2.0.- and not install funtion. and not driver.
    Master:
  • 118 Answers
Please UNINSTALL UR USB drivers then put reinstall ur USB drivers then try to use them if not works then check the mother board to check the usb cables
please vote for me
Posted on May 19, 2009
Can I convert a Kenmore Elite reader/writer 19000 to USB?
Not unless it was USB to start with you can't "convert"
Oct 30, 2017 | Kenmore Sewing Machines
How do i get my 2gb memory card to work on my samsung e900
Hi - Sometimes devices are finicky about which SD cards they work with. I suggest you try a different brand card. Be sure to purchase it where they have an easy return policy just in case. The phone definitely supports two GB cards.
Luckily two GB cards are pretty cheap and it's always good to have a spare.
Good Luck, Mikeywaf
Mar 01, 2011 | Samsung SGH-E900 Cellular Phone
I have not used my Husqvarna reader/writer for a while. I put the program on windows 98 because I bought a new Mac, and it says the reader/writer cannot be found. Therefore I cannot get my embroidery on...
You might just need new drivers for the reader/writer. Try the Husqvarna website first, or else do an internet search for "Husqvarna Reader/Writer drivers" or something similar. Is the reader/writer a USB or serial connection? You are going to have problems if it is serial and I am not sure there is a solution, but USB connection should definitely be able to get working.
Nov 14, 2010 | Husqvarna Designer I
TARGUS High Sped USB Memory Card Reader/Writer failure...
1. Go to Start>> Right click My Computer>> Manage>> Device Manager 2. Expand the USB Controller section 3. Right click and Uninstall all of the listed USB devices 4. Reboot the system
Feb 27, 2010 | Electronics - Others
3.5'' internal memory card reader/writer installation problem
Your reader/writer is set up for use on 2 USB ports (hence the 9 pin connector), one port for the reader and one for the externak USB port. This has nothing to do with the port version. The long and short of it is you need a card with a matching internal header. NEVER break off a pin! Some of these headers have reversed connectons so you probably broke of one of the data pins and runed that header's ability. Typically the readers like you have come with several cables, so that they can match the headers you have available. Older motherboards and add on USB cards did not use standardized header configurations aas you seem to have found out. Your best bet at this point is contact the manufacturer of the reader and find out what brand of add on USB cards they recommend and go with that. AND AGAIN NEVER REMOVE ANY PINS FROM A HEADER !!!
Feb 11, 2010 | Computers & Internet
I need a step by step instruction on using the msr206u
1. Install software 2. Install driver if required (usb) 3. Reset computer 4. connect msr206 to computer 5. open software for msr206 6. choose the hico or loco setting 7. input the data 8. press writer / read 9. swipe the magnetic card
Dec 24, 2009 | Unitech MSR 206-33 (msr206-33) Magnetic...
Sigma card reader/writer doesn't recognize my new SD card
What I suspect here is that, the USB port that you are using is a USB 1.0 port, which has a lower voltage not enough to power on your Storage drive.
In this case, there are two things you can do,
1. Change the USB port you are using for the storage drive to a USB 2.0 one (Just keep Checking all the ports one by one in case you dont know which one it is).
2. If your Storage drive has external power facility, just plug it in an external power first, before connecting it to the system.
If there are no USB 2.0 Ports on your system at all,
then just go to any electronic store and tell them you want to buy a USB 2.0 Expansion card.
and if it is a laptop, A USB 2.0 PCMCIA card.
Install it on your system, and connect your external drive through it.
Hope this helps you out.
Goodluck
Nov 19, 2009 | Electronics - Others
I lost the usb cable for my camera and am trying to remove images from the internal sd card. how can i do this?
For your USB
> Contact kodak store at 1 888 369 6600 ask for KODAK USB Cable, Model U-8 or simply log on to www.kodak.com/go/shop.
To remove images from the internal memory of the camera
1. Turn the Mode dial to Favorites
2. Press the Menu button
3. Highlight delete or the minus icon, then press the OK button.
All pictures stored in the Favorites section of internal memory are removed.
4. Press the Menu button to exit the menu
** Kodak CD33 has 16 MB internal memory and it has a slot for MEMORY CARD 3428db8.jpginternal memory is different to memory card. You can use the camera without memory card but it's only up to 16MB while if your using s memory card you can load up to SD Memory Card 2 GB.
16MB if camera is set to 2MP it will only take about 2-5 photos while if your using a Memory card with a size of 1GB and camera is set to 2MP about 1137 photos.
* Contact Kodak support line @ 1 800 235 6325 (23KODAK)
Nov 16, 2009 | Kodak EasyShare CD33 Digital Camera
I want o put pictures back on my camea that are saved to my computer
You will need a card reader/writer, which are usually very inexpensive and found in any camera shop. You just have to place your SD or CF card in the reader and copy your files to it as if it was a USB key. Make sure it is a reader/writer device, because there are some that only read the cards, but won't write back.
Apr 14, 2009 | Cameras
4D Extra and Reader/Writer
QUESTIONS:
is the reader writer a USB or parallel cord? (they have both.
If it's USB you need the 256K card otherwise the regular card, and yes it can work you just have to have the right card for your reader writer.
Jan 18, 2009 | Husqvarna Rose
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
