Back to:
Tags:
RCA DISH Network 311 Satellite System
Dish Network - Dish 500 Satellite 110 is not... (by 2 users)
posted by Lonnie Cross on Oct 18, 2007
I brought my Dish Network receiver down from my cottage to use at my primary residence.  My neighbor gave me a Dish 500 satellite dish to use so I didn't have to bring my dish home from the cottage.  After installing and aiming the dish, I'm getting a strong signal from 119 but for some reason satellite 110 is not being recognized on my system.  Any ideas on what the problem could be?  Both satellite locations, 119 and 110 worked perfectly at my cottage.  I couldn't find the Dish Network 500 system listed under the "Product" area.     Thanks, Lonnie
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Apr 03, 2008
Had to move to my camper waiting for house to be completed. Have used Sat dish with no problem when camping in the past. Use dish 500 and model 311 receiver. Receiver locks into 119 and 129 sat. We should receive 119 and 110 sat only. Cannot get 110 to lock in even though there is a 50+ signal. 129 locks in in the 40's and 119 in the 60's. Need 110 for our local channels.
Best Solution
posted on Jan 13, 2008
FixYa! (100)
DJDJ
Rank:Apprentice Apprentice
Rating: 96%, 4 votes
i have dish network and my sat. will not pick up signal from 119 and if i do get a signal it says its wrong
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Dish Network - Dish 500 Satellite 110 is not being recognized:
I don't want to Accept this solution
Solution #2
posted on Oct 29, 2007
FixYa! (100)
satscoop
Rank:Wiz Wiz
Rating: 84%, 92 votes
Lonnie, You have a simple problem,the 119 satellite is lower in the sky than the 119 if you make sure the pole you are mounted on is straight and plum ,then simply raise the dish a few elevation degrees and turn the dish to the left.Your dish is aimed low and to the right.
Comment by satscoop, posted on Oct 29, 2007
Sorry,I meant the 119 satellite in the sky is lower in than the 110.There is a great tutorial at satellitescoop.com called how to align a satellite dish.
Thank You!
Solution #3
posted on Jul 10, 2008
Not Rated (0)
agouge6
Rating: 0%, 0 votes
Make sure the sat is aimed the right way. I have a dish 500 sat and it is aimed at the south.
Thank You!
Solution #4
posted on Jun 03, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
i have no idea
Thank You!
Can you Help with these TV Receivers and DVRs problems?
RCA DISH Network(r) 311 Satellite System
in my satellite system the signal is OK, the Eb/No is OK...
Echostar T-101 FTA Digital Terrestrial Reciever
Hi I have a dish that works fine, but the USB is not...
when program is down loaded to box, auto roll comes on,...
I have a RCA DRD303RA satellite receiver that works fine...
Loading problems.
Repair Service
Find TV Receiver and. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
