Question about Konica Minolta Office Equipment & Supplies
Konica 7145 error code F34-2
Konica Copier error code F-34-2
  • Konica Minolta Master
  • 6,161 Answers
Do this once code comes back replace the fuser continue reset couls cause fire ruining a perfectly good day
To reset failure codes, perform the following:
1. Enter the 25 mode (turn the machine ON, while pressing the 2 and 5 keys).
2. Select [1. software SW settings].
3. Using the arrows on the left of the touchscreen scroll to DIP SW 3.
4. Using the middle arrows scroll to BIT 1.
5. On the touchscreen select OFF (0).
6. Power the copier OFF/ON.
Posted on Jul 04, 2016
  • 1003 Answers
SOURCE: Minolta Konica 7145 error code 26-3
NOT SURE BUT YOU CAN GET SERVICE MANUAL WITH ERROR CODES DEFINITIONS www.precisionroller.com type in your model
Posted on Jan 13, 2008
  • 6 Answers
SOURCE: Konica 7030 F-34-1 code
try to change the thermistor, if u confirm both the heater lamps is working.
the fuser unit from 7022 is not compatible with the 7020 machine.
Posted on Aug 09, 2008
SOURCE: error code f35-3 on konica minolta 7145 copier
How to reset failure codes (F34, F35, F36). To reset failure codes, perform the following: 1. Enter the 25 mode (turn the machine ON, while pressing the 2 and 5 keys). 2. Select [1. software SW settings]. 3. Using the arrows on the left of the touchscreen scroll to DIP SW 3. 4. Using the middle arrows scroll to BIT 1. 5. On the touchscreen select OFF (0). 6. Power the copier OFF/ON.
Posted on Sep 22, 2008
  • 158 Answers
SOURCE: I HAVE A KONICA 7145 COPIER ANND HAVE THE E-56-1 COPIAR
this code means the system control board and the main control board are not communicating with each other. the new main boards have modified to prevent this code. to reset the code turn the main switch on the left side of the machine off for about 10 seconds then back on
Posted on Oct 15, 2009
  • 37 Answers
SOURCE: error code F-35-1 in bizhub 7145 copier
quote is probably in the right price range. you need to look at how many copies are on your machine. look at any future repairs/supplies that will be needed. like drum, developer unit. If these are also needing to be changed soon, you will have to plan on those costs also. Any comparable machine that you get get will be expensive to repair the big items. You have to put all of the money that you spent on the machine and find out how many copies you have made. you can then figure out the cost per copy. At the same time, if this machine does everything that you need from a copier, do you want to buy a new one at much higher cost.
Posted on Oct 17, 2009
How to remove minolta 7135 code E 56-1
replace the image control board, all check all connection to printed circuit board remove each connector seperately and check for a bent pin
Oct 11, 2016 | Konica Minolta Office Equipment & Supplies
Konica 7145
fuser code hot part replace it
Apr 13, 2014 | Konica Minolta Konica 7145 Minolta Bizhub...
Appear Please call service F-34-1 kindly help me if know problem this.
with this machine, that code is normally due to worn temp sensors, once they are replaced you can reset the code by:
To reset fuser failure codes, perform the following:
1. Access 25 mode (power OFF, hold the 2 and 5 keys, power ON).
2. Select option 1 [Software SW].
3. Use the scroll arrows to scroll to address 3-1.
4. Select OFF.
5. Power the machine OFF/ON.
the part number for the sensors are p/n 26NA88011
Oct 12, 2013 | Konica Minolta Konica 7145 Minolta Bizhub...
My konica minolta bizhub 7145 b/w copier is showing error code F-51-5 The copier will power up and then seize. The copier is about 5 years old with a total count of 320,000 copies
Hi the problem is going to be with the M1 motor most of the time replacing this motor will fix the issue However in rare cases if it still gives you the same error after replacing m1 motor then you will need to change CB Main Body control board my advice is to replace the motor and if it still gives error code replace the cb board but it will fix your problem
Mar 09, 2011 | Konica Minolta Bizhub 222 Black and White...
What are codes F-34 and F-35?
These are heat sensor abnormality error codes in Konica Minolta 7222/7145/7135/7235/7228 models.You did not mention the model.
Oct 04, 2010 | Konica Minolta Bizhub C300 All-In-One...
Konica 7040 error code F-34-3
Friend, this code refers to short-circuit the corona separation and transfer, check for accumulation of toner and do a cleanup in the corona.
May 21, 2010 | Konica Minolta Office Equipment & Supplies
Oct 04, 2009 | Konica Minolta Office Equipment & Supplies
Eror code 82-2 konica minolta 7145
eror code f_26_1 konica minolta 7145
Feb 23, 2009 | Canon imageRUNNER 400S Copier
Jan 12, 2008 | Canon imageRUNNER 400S Copier
46 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
