Question about Safe International Locks & Locksmithing
Default code for digital home safe 69726?
Iv put my things into lockup as moveing just got my things back after 2yr and i dont have my key or my code for digital home safe 69726? could u pls help Thanks Joanne
3 Suggested Answers
SOURCE: I have a Safewell Electronic
just **** a ****
Posted on Apr 06, 2011
joanne_tomli
SOURCE: i have a digital home
i have digital home safe 701-5359 and left keys inside and batterys have gone
Posted on Jul 22, 2011
How to reset number code on my secursafe. I bought never set it up I have key but dont know how to set up safe with pass code
Open the safe with your key (key slot behind the blanking plate btween the safe knob and the keypad).
on the back of the door is a plastic housing put your hand on the side of the housing near to the hinges, you will feel a small push button.
Press it once the unit will beep and the far right led will illuminate.
key in your new code (8 digits) then press either A or B.
Job Done!
Feb 14, 2017 | Home Security
SafeGuard safe won't open - no battery installed.
the user manual will have the default code to open the safe and the instructions on hoe to set what you want as a code
read the bit where it says --do not put the keys in the safe after setting and before closing the door
Jan 08, 2017 | Home Security
How to open digital safe 69726 when batterys dead
Hi Nichola, did you get any weird looking keys with your safe? Sometimes you can pull the badge plate off and use the key to unlock when the batteries has died.
Hope this helps.
Nov 02, 2014 | Home Security
Starts out in 3rd gear
Trans shifts into gear harshly, car feels sluggish off the line, No 1st, 4th or TCC lockup available, Manual 2nd, 3rd and Reverse are only available gears, CEL is on: Transmision is either in limp-home mode or has lost electrical power. If there are lots of error codes in the PCM, check the underhood fuse that powers the transmission, and if it pops again, look for a short in that circuit like an O2 sensor harness touching exhaust. Otherwise, check PCM codes for a particular fault in the transmission causing the PCM to put it in limp-home mode.
What is "limp-home mode" ? This is a fault mode in which the transmission either loses electrical power or the PCM deactivates all of the electronics. The transmission will default to max line pressure. The driver will have Reverse and 3rd, with manual 2nd available by putting the gearshift in 2 or 1 (doesn't matter). 1st, 4th, and TCC lockup will not be available. It will not hurt the car to drive it like this for short periods, but use manual 2nd to get the car moving, and be aware that the trans will generate more heat than normal while operating in limp-home mode due to increased torque converter slippage during 2nd gear starts and no lockup in 3rd gear.
Before guessing at transmission problems, check the fluid level (car warmed up, engine running in Park on level ground) and have the PCM scanned for trouble codes FIRST. This guide is meant for problems that do not show up as PCM codes (like shift A&B solenoid failures, for example).
Thank you for using fixya and good luck
Apr 19, 2010 | 1994 Oldsmobile 88
Will not shift into 2nd gear on a automatic trans
Apr 10, 2010 | 1994 Chevrolet S-10 Blazer
Only runs in 1st and 2nd gear and reverse.
, No 1st, 4th or TCC lockup available, Manual 2nd, 3rd and Reverse are only available gears, CEL is on: Transmission is either in limp-home mode or has lost electrical power. If there are lots of error codes in the PCM, check the under hood fuse that powers the transmission, and if it pops again, look for a short in that circuit like an O2 sensor harness touching exhaust. Otherwise, check PCM codes for a particular fault in the transmission causing the PCM to put it in limp-home mode.
No 1st or 4th available; trans shifts 2nd to 3rd by itself in D or OD and locks the converter : ShiftA solenoid failed. Easy fix in the pan. Or a wiring problem from PCM to trans.. or PCM.
Car goes into gear but feels very sluggish like the brakes are dragging, but it will roll easily (starts out in 4th gear), you manually shift to 2 to get it moving, once it's moving you put it back in OD and the car shifts 3rd to 4th on its own and locks the converter at the appropriate time: ShiftB solenoid failed: Easy fix in the pan. Or a wiring problem from PCM to trans.. or PCM.
Dec 14, 2009 | 2006 Hummer H3
Compaq desktop freezes on me when am working
check the viruses in your system why freeze that... if the same problem after that try to reinstall the os
check another parts
Jun 07, 2009 | Computers & Internet
Forgot pin code to unlock my hardline digital safe
I have pin code but batteries went flat while I was on holiday, how do I unlock my Hardline digital safe? I do not have override key
Dec 09, 2008 | Safe International Digital Electronic Safe...
Locks & Locksmithing Logo
148 people viewed this question
Top Safe International Locks & Locksmithing Experts
Jim London
Jim London
john h
Are you a Safe International Lock and Locksmithing Expert? Answer questions, earn points and help others
