Question about Refrigerators
Frigidaire FRS26R4CB1 fridge temp too cold
In the last week, all the liquids have started freezing up in the fridge side. Temperature has always been set at default and the setting was unchanged when it first froze up. I have dropped the setting to the warmest setting and fridge is still averaging 18 degrees.  I disassembled the entire control box to check if damper had ice making it stick open or if it was inoperable. Everything looked normal and I can hear damper door opening and closing when running. It sounds like the temperature control box is not operating properly. How can I test that is the actually problem without replaing the part? Or is there another part that I should look at first? Freezer is still operating properly. Thanks for any insight you may have.
HVACRH20
  • 237 Answers
SOURCE: Hot point side by side electronics not operating damper
See if you have some paperwork on how to test, etc. located in a plastic bag taped up to the underside of the fridge. Pull the front vent cover off and you should see (feel) a bag taped up there with the test paperwork in it. If you don't have it let us know and maybe I can email it to you.
Posted on Dec 26, 2006
  • 1314 Answers
SOURCE: Temperature variation in freezer on Whirlpool ED22TQFXN
need your model number for unit reply but dont rare me till we are done get model num off serial plate in fridge
Posted on Jan 02, 2008
SOURCE: freezer temp too high
Air must circulate in the freezer when working properly. I am guessing the recirculating vent in the freezer may be blocked which would not bring warmer air back to the coil to be cooled. As for the door, I theorize there may be too much negative pressure which pulls the door in while you were pulling out ... don't have solution yet.
Posted on Apr 01, 2008
SOURCE: Inside Dsiplay Not Always on
Hi -
I haven't solved my problem, yet, but i have determined that it's beyond my scope and will require a pro's visit to my house.
thanks for the line.
b
Posted on Aug 18, 2008
huuum
  • 750 Answers
SOURCE: Freezer not cold enough; fridge OK
Hello cokoliso,
Welcome to Fixya
You said, your Trio won't make ice. Freezer stays at about 25 degrees regardless of control setting. Fridge maintains 40 degrees at mid setting. Shouldn't the freezer be close to zero? Is there a way to check the temperature sensor in the freezer?
To check the temperature you can buy a refrigerator thermometer at the hardware store.
Ask if it can be used in the freezer too!
The fridge sounds slightly to cold and the freezer not enough.
Fist look in your freezer and check if the articles there are full to the max and covering the air vents usually found in the rear of the freezer.If so clear an opening for the freezer to breath.
Refrigerators and freezers usually share the cold air and I've seen this be the problem on many occasions.
If freezer was not I blocking the vents or even full to the max.
Then pull the plug out or if you can not reach the plug, trip the breaker off for 5 minutes and see if this resets the system.BUT do not plug the fridge back in before at least 3 minutes.
Let me know how it goes and send me any questions.
Thank You, Huuum
Please remember to leave a rating .
Posted on Oct 03, 2008
It sounds like you have it pinpointed with the control being the problem. There is an adjustment, but it's complicated, and there's different types. A refrigerator is like politics..you have an obvious annoyance, there, but often the core cause is less obvious. Ambient room temperatures in winter dropping lower tend to trick a fridge into thinking it's time to shut off inappropriately..the control sensor in the milk-side says it's safe; while in the freezer, your ice cream is doomed..sort of like the congress and senate, if you know what I'm saying. Your problem, however, is the opposite, as your 'ice-box' doesn't stop running at all (right? yes, in fact you better go catch it before it runs away, ha-ha!)..well. Something simple that can cause your problem is plugged condenser coils which are next to the compressor. You can see them by removing the cardboard cover in back. ALWAYS REPLACE THE COVER. The coils are either a box-type or they spread all around underneath. If they are full of dust and pet hair, and chewing-gum foil wrappers, etc., get a long wire bristle brush and poke it around to free the coils of all that air-flow restriction, and that will make a big difference..Also, voting out all the incumbents. Happy New Year. And G-d bless America
Dec 30, 2013 | Refrigerators
Refrigerator side freezing and cannot control temp.
099b99d4-9ea3-4dba-a2ca-6c92989fe8af.jpgLook and see if the air damper called a=> 5304482075 Temperature Control Thermostat is opening and closing after selecting a different temperature. This along with the termostat are what controls the fresh food section temperatures. I am here should you have questions, Thanks Sea Breeze
Apr 25, 2013 | Frigidaire Refrigerators
Temperature controls
The control on the back wall controls the freezer part of the unit,,the one on topof unit and the closest to you, controls the refrigerator( bottom ) part of the refrig. Temp.
Jun 07, 2012 | Frigidaire Refrigerators
II have a model 5707591 side by side in my garage.as long as the ambient temp is 35-40 F everything works great.when it gets below that the freezer cant keep frozen.temps will rise to 25 F while the fridge...
the thermostat isn't cycling because it's to cold in the garrage,the machine isn't calling for cold air because the garrage is so cold so the fridge isn't gonna run until the temperature starts to get warm and then the fridge will start again to keep it cold.put some heat in the garrage and it will run fine
Feb 27, 2011 | Kenmore Refrigerators
Side by side unit. no temperature control in freezer or fridge temperature of fridge is 60 degrees F on top. Freezer temp is 45 degrees. Bottom part of fridge is 28 degrees F.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 13, 2011 | Frigidaire PLHS267ZA Side by Side...
Frigidaire is freezing everything!
Possible defrost timer or thermostat failure.
Jul 11, 2017 | Frigidaire FRS26H5AS Side by Side...
Frigidaire side by side - fridge side temp too low
It sounds as though your thermostat is not cycling your compressor off causing it to run until the point of freezing. If you sit and listen, you will hear it hum. If it never stops humming, 9 times out of 10, the power outage shorted your thermostat.
Jan 30, 2009 | Frigidaire FRS26R4A Side by Side...
Food stays frozen regardless of temperature setting
It is possible it has a bad thermostat but most likely cause would be a bad damper motor.  It is the vent inside the fridge that opens and closes, based on temp. setting, to allow cold air from the freezer into the fridge section.
Oct 14, 2007 | Frigidaire FRS26H5AS Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
