Question about Cell Phones
I need manual for 1990 regal valanti 200 - Cell Phones
How do you insert needles in quanturmlock 5 differential feed
If you have not used this since 1990, it NEEDS a maintenance. The sewing machine oil evaporates and leave a gunky film.
Do you have the manual?
Singer futura CE 200 Instruction Manual
Feb 15, 2015 | Singer CE-200 Quantum Futura Computerized...
I have a 1990 Regal that sat for a year. It turns over, you can hear the fuel pump run but there is no spark at the plugs.
if there is no spark, you need to check the coil! make sure you have power there, and check the coil wire for power!
Mar 06, 2011 | 1990 Buick Regal
I need to replace the crankshaft position sensor in my 1990 Buick Regal 3.1L 6 cylinder. Where is it located?
Between the engine and transmission just above oil pan at the center of engine.
Dec 31, 2010 | 1990 Buick Regal
What is the firing order for a 1990 buick regal 3.1
For 1990 Buick Regal 3.1 liter V-6 VIN "T" check this...
Hope helps (remember rated this).
Aug 12, 2010 | 1990 Buick Regal
Need to know the location of cam sensor on 1990 buick regal
It's just under the water pump. You most likley need to replace the magnet that is on the cam gear to fix it. The sensors hardly ever go bad. The timing cover will need to be removed to fix the magnet.
Oct 29, 2009 | 1990 Buick Regal
Stalling
Where all those parts, so bad,they had to be replaced? You tested them to determine that,and only then,you replaced them? Correct? Now you need help?
Oct 01, 2009 | 1990 Buick Regal
Replacing wheel studs on front of 1990 buick regal
take off the wheel and remove the axle. knock out the bad lugs and press new ones in with a big vise or shop press
Jun 24, 2009 | 1990 Buick Regal
1990 buick regal 3.8L- Backfires, stumbles on acceleration
most likelly it is your fuel pump is not puting godd fuel pressure
have the fuel pressure test and if it is low have the fuel pump and filter replaced
May 28, 2008 | 1990 Buick Regal
Cell Phones Logo
41 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
