Question about Ricoh Aficio 1085 Laser Printer
Nashuatec sp1000 - fuser temp. err.
Clean all fuser
the same error
need help
  • 162 Answers
The fusor errors must be erased entering to service program mode pressing total clear, 1 0 7 and “clear stop for more of 3 sec” later put off and on the copier. But must to indicate that code display, in order to be able to help him. Probably some piece was not placed well, or it was damaged when mounting it.
Posted on Aug 31, 2009
  • ??????? ?????????? Oct 10, 2012
    this procedure is for bigger machines !!!! there is no total clear on the keyboard and it is an mfp , not a copier
How to replace the fuser
Fuser roller is at the exit point of the print path.
Obstruction can occurs before and after the roller.
Power off the machine for 10 minutes before service the roller area.
Sensors can get miss-alignment and give false error.
Jan 15, 2014 | Office Equipment & Supplies
Nashuatec dsm616 sc 544
more than likely to be paper wrapped round the hot roller - remove the fuser and split it - then clean the thermistors - should sort it
Oct 21, 2013 | Gestetner Office Equipment & Supplies
Canon IR 330s - i have error message E004. how do i clear it?
This is an error for the thermistors in the fuser not reading temp correctly. Go into service mode by the standard Canon way - Additional Function key, 2 & 8 held down at the same time, then Additional Function key. Press copier, function CLEAR, ERR, then OK. Power cycle the copier and the error is reset. Again if the error come back you will have to check the fuser assembly, heat lamps, thermistor, thermofuse, etc. There is a problerm thsat needs to be fixed and continuing to reset may do major damage to the copier.
Jun 22, 2011 | Canon ImageRUNNER 330s Copier
Please give suggestion for error code E 000004 - 0001
This is a fuser error given by the thermistors in the fuser assembly. It is indicating the fuser is not reaching tmperature quickly enough. You can first reset the error by first clearing any jammed paper in the copoier. Then press the Additional Function key, then the 2 & 8 keys at the same time, then the Aditional Function key again. This should get you into service mode. Press COPIER on the display then Function ( across the top ), then CLEAR then ERR then OK. This clears the error out of memory. Power down using the main power switch then power back on after a few seconds. If the error comes back check to see if the fuser ever got hot, be careful the roller do get very hot. If hot then the thermistors may not be reading the correct temp and they will ahve to be replaced.
Jun 09, 2011 | Canon IMAGERUNNER 8070 Copier
Printer Error Fuser Temp. in xerox 3100mfp
SISODIYA COMPUTERS "I AM SOLVE THE PROBLEM FUSER TEMP ERROR "
BUTTON FAST PRESS STEP BY STEP
LET'S START
PREES- MENU BUTTON
* BUTTON(THIS IS STAR BUTTON)
# BUTTON
1 BUTTON
OK BUTTON
STOP BUTTON
MENU BUTTON
# BUTTON
^ BUTTON(THIS UP ARROW BUTTON)
OK BUTTON
YOU LAST BUTTON PRESS OK AND POWER "OFF" AND WAIT UNTIL 15 MINUTE AND PRINTER START PROMBLEM IS SOLVE FUSER TEMP
Mar 12, 2010 | Xerox Phaser 3100MFP/S Laser Printer
Printer error fuser temp
You will have to replace the fuser. Call 1-800-835-6100 and follow the prompts to purchase parts. It isnt real expensive. Just make sure you still don't have some warranty left on the parts.
Mar 09, 2010 | Xerox Phaser 3100MFP/S Laser Printer
Xerox Phaser 3100 Printer Error Fuser Temp.
fuser Temp printer error problem.please give me the solution.
Sep 14, 2009 | Xerox Phaser 6120/YN Laser Printer
How do I fix this?
please have the check on fuser for damage. Could be a thermistor, thermo switch, or faulty heaters. To clear error, service morefunction/clear/error/ok/ exit service mode and cycle power.
fuser over temp means the fixing assy has exceeded the manufactures maximum temp limits
Fuser error codes cannot be reset by power cycling the machine eventhough that is what the display tells you to do. In order to reset thefuser error code you must enter the service mode & reset the code.To enter the service mode:
press"Additional Functions" button (looks like a picture of a head with a star inside)
press the #2 and #8 at the same time (simultaneousley)
press "additional functions" again
The display should show a choice of
copier,feeder,sorter,fax,or board service modes
Select copier
select clear
select ERR
press OK
Turn power off & back on.
****IMPORTANT****
Afterclearing error stay at the machine to see if it comes to ready. Thefuser assy can reach 139 degrees C.(Water boils @ 100C) The error canonly be cleared through the service mode because a technician shouldinspect the fuser to verify there is nothing faulty that could possiblystart a fire. If you enter the service mode & clear the error,power cycle the machine & during warm up the machine throws a codeagain- turn it off, unplug it & call a tech for fuser repair.
Good Luck!!
Aug 10, 2008 | Canon LASER SHOT LBP-5200 Printer
Cannon 1150
Get in the service menu, press * 2 8 *, choose COUNTER, reset all counters to 0, go to FUNCTION/ CLR/ ERR, press OK. Turn off the machine and then on.
Apr 11, 2008 | Canon CLC 1150 Color Copier
Service Call: 173: Fatal Error
That is a fuser erron code. Abnormal temperature. You will need to replace the fuser. Sometimes I have sen a buildup of toner on the thermistor. If you can get to it. You can try to clean the toner off. Be careful. Very hot.
Aug 10, 2007 | OKI C5150n Led Printer
Ricoh Aficio 1085 Laser Printer Logo
1,208 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
