Question about Kenmore Dryers
Heating Issue - Gas Valve Coils?
Kenmore Gas Dryer Model #110-70002991 The dryer will heat up for the first 5 minutes of the cycle - then goes cold, but continues to tumble. If I wait for a time, I can repeat the pattern. I've looked online and it sounds like a gas valve coil issue - however, when trying to find info on a part, Sears indicates that it is a tech only repair and I must schedule a repair appt. Does this sound legit? I'd be happy to have a repairman do this - but I also don't want them to come out and then discover that the repair is more than a new dryer! I'd really like to attempt it by myslef, is possible! Thanks!
    Scholar:
  • 85 Answers
You should be able to order the parts thru Appliance Parts Pros which is advertised on this site. Make sure all gas and electricity is cut off if you do it yourself. Hope this helps!
Posted on May 20, 2009
@yaI have a Whirlpool LGB6300PWO gas dryer and when it starts it fires up ok, but within about 3- 5 minutes the flame goes out. I changed the thermostat, but it did not work. Any ideas?
The reason your gas heated dryer starts off heating ok,but a part way through the cycle it is no longer heating as it did when it started,is beacuse the coils that open the gas valve are getting hot and breaking down when they are warm. At start up of cycle the coils are cool,but when the dryer heats up as it runs the coils that are weak can not handle the heat and do not open the gas valve. Replacing the gas valve coils with fresh,strong ones will open the gas valve the entire duration of the drying cycle. All appliance manufactures use the same exact gas valve coils and label them with their unique part number. Having been in the service business i know they are all the same and the part number for the least expensive gas valve coils is 279834
They can be purchased at your local appliance parts store on online at
searspartsdirect.com
repairclinic.com
apwagner.com
apdepot.com
partselect.com
To replace the coils,remove bracket over them(dont worry about where it says dont grip thats for when dryer is plugged in) unplug them and install new ones,that bracket has notches in it and the coils have tabs that inter lock so they position them self exactly where they fit.
This is what the coils looks like
Aug 29, 2011 | Dryers
Intermittant heating.It will begin to glow....sometimes the flames shoot out for a short time....but then go out. Then, it will continue to glow red without flames igniting,then goes dim....couple minutes...
This is usually caused by faulty coils on the heat valve. they can be purchased seperate from the gas valve and are relatively easy to install..
Oct 27, 2010 | Dryers
Kenmor 80 series gas dryer model # 11076822695 dryer is heating up for about 2 min then it gose cooled for the rest of the cycle
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 20, 2010 | Kenmore 72802 Gas Dryer
Kenmore Gas Dryer ignites then stops heating after ten minutes.
If the glow bar comes back on and the gas does not light,replace the gas valve coils. If the ignitor does not come back on,replace the flame sensor.
Sep 01, 2009 | Kenmore Dryers
Dryer heats for 5 minutes then only blows cool air.
Hello, reading between the lines I'm going to assume you have a gas dryer. This problem is going to be your safety valve coils...basically they get old and over time of heating then cooling develop a short when they heat up...It may appear the gas lights to start but then goes out until the safety valve coils cool back down. Here is a picture of the coils 57d5263.jpgThis should solve your problem. Hope this helps, Please feel free to comment again if you have any further questions or concerns. Good Luck! Mike
Aug 17, 2009 | Kenmore 800 7982 Dryer
Gas dryer not maintaining heat. 70 Series Kenmore/Whirlpool 76722
Fuse is ok . Problem is the soils on the burner valve . If the dryer heats when started , the electricity goes thru the coils to open the valve . Once the coils get warm , 1 will open (short) until it cools back down . The coils can be replaced just by removing the front panel . Only 2 screws hold the coils in place . No turning off gas , dissasembling dryer .
Jul 14, 2009 | Whirlpool Dryers
Maytag MDG5500 - heat goes off after several minutes
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Mar 07, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Heating Problem
If this is a gas dryer, you probably have bad valve coils, they can work intermittently, usually for the first part of a cycle, but when they heat up the internal resistance gets too high and they fail to open the gas valve. Once they cool off, (by continuing to air dry) they will work again for a few minutes. They will also make a buzzing/rattling (maybe "metal" ) noise as voltage is applied. For any Kenmore gas dryer, get part #279834 it contains both valve coils. Very easy to replace. Another possibility is that your duct work is plugged, check airflow. Hope this helps.
Sep 14, 2008 | Kenmore Dryers
Dryer won't dry
  1. thermostate 2 the gas valve cylanoids the 2 black things on top gas valve can be bad will heat then stop heating 4 awhile thay drop out dont open valve watch your valve listen 4 it if comes on run heat goes off dont come back on 4 awhile 3 5 min bad valve cylonoids
Dec 29, 2007 | Kenmore 64952 Electric Dryer
Dryers Logo
83 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
