Question about Pool & Spa
Hot tub error codes
Receiving an error code of Esb
3 Suggested Answers
  • 37 Answers
SOURCE: reset error code hot tub
tub is in sleep mode usually to change u must press temp button then light button you want to b on standard mode STD
Posted on Oct 11, 2009
Testimonial: "Thank you!"
Ian  Hot Tub
  • 77 Answers
SOURCE: Error code reads
'Sn' is a general error message relating to the temperature sensors.
Assuming that you have a Balboa spa pack (M7 version), turn off the power and remove the spa pack cover, you'll find two temperature sensors mounted in the top of the heater tube one at each end. Follow the wiring from the sensor to the plug(s) on the PCB and check that the connections are good, they have a habit of devekoping a poor connection.
If you have a multimeter you could also check the resistance of the two sensors. They should both be the same. If they aren't the same you'll probably have to replace them.
One final thing just to check... Ensure that there are no blockages within the heater. Unless you have service/gate valves you will have to drain the hot tub, unscrew the unions and check inside the heater for debris within the heater assembly.
If you're from the UK I may be able to help regarding parts etc.
Kind Regards,
Ian.
http://hottub.synthasite.com
Posted on Apr 08, 2010
What does code ic mean?
I have not seen an ic error code. I have seen ICE several times. So either you do not have the original pack that came with the spa or your display may be malfunctioning.
What is your hot tub doing while the ic code is pressent?
Portable Hot Tubs and Spas On Sale
Apr 12, 2015 | Dream Maker Spas Dream Maker Ez Spa Hot...
What does error code -0.3 mean on an Aruba Hot tub
Don't think that's an error message? Could be letting you know heat is bypassed for Max setting?
Feb 11, 2015 | Qca Spas Majestic Series Aruba Xl Hot Tub
Error codes
Here is a link showing the most common error codes for hot tubs using Balboa Instrument spa packs.
Balboa Direct Factory Direct Balboa Water Group Bath and Spa...
Rod
US Parts Center
Nov 16, 2013 | Qca Spas Majestic Series Aruba Xl Hot Tub
Will a flow switch stop the tub of any operation
Is the board getting power, is the control lighting up?
Do you see any error codes on the top side control?
Improper flow will give you an error code, caused by flow issues or a faulty flow switch. Make sure all gate valves are open and the water can flow freely.
If not then check your Hi Limit sensor. This is the overheat safety sensor if it fails the tub will not function at all.
Sep 23, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
My hot tub top control is flashing SPA6,and hot tub is not heating up.
Here is a link for you to resource that error code.
click that link and scroll through them until you find your error code.
Rod
US Parts Center
Aug 19, 2012 | Jacuzzi Pool & Spa
Hot tub error code sn
check recirculation pump and heater element
Apr 17, 2012 | Pool & Spa
What does FL mean on my hot tub?? water doesnt circulate but is still sort of warm...
FL could be a code for low flow. If you have no circulation this sounds like it. If your pump runs and you have no flow you could have a problem with your pump. Or if you have the tub drained then it could be an air lock, if you open the drain valve till you get water out that should fix that. Also check to be sure the isolation valves are open under the spa. I hope this helps.
Feb 07, 2010 | Qca Spas Dream Series Dream Master Hot Tub...
Reset error code hot tub
Oct 04, 2009 | Qca Spas Dream Series Dream Master Hot Tub...
Pool & Spa Logo
56 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
