Phaser 8400 error code 43:117147, Can anyone help?
  • 1 more comment
  • john804 May 19, 2009
    Done that, do you know this error code 43:117147
  • john804 Jul 22, 2009
    wiring and connectors from the front door to the I/O board is ok.
    I Replaced the front door and the I/O board.
    unable to run test Tray 1 Width Sensors due to error message 43:117147 is still coming up
    Any other ideas on how to fix?
  • 75 Answers
1. Check the wiring and connectors from the front door to the I/O board.
2. Run the Test Tray 1 Width Sensors.
3. If the test fails replace the front door.
4. Replace the I/O board.
Posted on May 19, 2009
  • 544 Answers
HI,
can you please check the cartridge or inside.
try to turn it off and turn it on again.
look all the cables thru computer and printer if it is connected properly.
any further question let me know.
thanks,
Printer Phaser 8400 : error 07,010.43:116034
If your printer is networked, if can fix its self by accessing this site
http://www.phasersmart.com/
May 18, 2009 | Xerox Phaser 8400 Laser Printer
What is error code 07,010.43:32309
The print head is not moving freely.
There is s print head block that may be filled up with runoff ink, or the print head wiper blade may be tacked to the print head.
Apr 16, 2009 | Xerox Phaser 8400 Laser Printer
8400 error 07.010.43:125364
7,010.43: The Printhead is stuck in the tilted position, or is not able to tilt
forward to the print position, due to problems.
Printer was caught mid-stride. Need to pop the printhead loose from the wiper and re-home the mechanism to get it rolling again.
Apr 15, 2009 | Xerox Phaser 8400 Laser Printer
Phaser 8400 error code 37,016,43:7052
From the service manual:
37,016.4x - PEST_FAULT_HM_CLUTCH_DISCONNECT
PEST - Head maintenance clutch disconnect. The head maintenance clutch is not
drawing the expected power from the supply.
1. Run the Head Maintenance Clutch test.
2. Check the Head Maintenance Clutch wiring.
3. Disconnect the Wave Amp signal cable from the left
side of the Electronics Module. If the error code
changes, replace the Wave Amp.
4. Replace the head maintenance clutch.
I have the full service manual available should you need it. Thanks and please take a moment to rate this solution as fixya.
Feb 22, 2009 | Xerox Phaser 8400 Laser Printer
Xerox phaser 8400 error
That is a print head tilt error. Either the print head pivot block is contaminated with ink or the wiper blade is tacked to the print head.
Let me know if you want to try to resolve it yourself, I will send you directions.
Feb 17, 2009 | Xerox Phaser 8550DX Laser Printer
Phaser 8400/8500/8560 maintenance kit
No, it will not work because the chip (CRUM) is not compatable.
Jan 13, 2009 | Xerox Phaser 8400 Laser Printer
That is related to the print head heating. Normally one of the print head heaters fails which requires replacement of the print head. The other item I have seen fail and cause that code is the electronics module. Both are very expensive.
Oct 09, 2008 | Xerox Phaser 8400 Laser Printer
Xerox phaser 8400 error code
That code is a jet heater code.The most likely problem is a bad print head, the second most likely bad item is the electronics module that supplies the 40-50 volt source to the print head heater.
Sep 22, 2008 | Xerox Phaser 8400 Laser Printer
8400 fault code
Sep 03, 2008 | Xerox Phaser 8400 Laser Printer
55 people viewed this question
k24674
