Question about Coby CR-A77 Clock Radio
How to set clock
Cant figure how to set clock which button tried them all
I cant find an online manual for an audiovox CD alarm clock radio model 1167, and cant figure out how to set the alarm. a link to the actual manual would be great
With the power off, push the alarm 1 button, then push the clock set button. Use the skip & preset buttons to set the hour. Push the clock set button again to change to the minute. Again use the skip & preset buttons to set the minute. Push the clock set button again to set. You will see an alarm clock in the upper left of the screen to show the alarm in now set. To cancel push the alarm button and then the stop/alarm off button.
Mar 09, 2011 | Hardware & Accessories
I cant figure out how to change the time on my clock, I have tried just about anything i can think of but I am not able to figure it out.
Radio off.Push the set button and then before the set light goes off use the seek and scan buttons to change the hour and minutes.If this is a factory radio.This is how you change the time.Hope this helps.Good luck.
Feb 02, 2010 | 1993 GMC Sierra
Cant figure out how to set clock
try this first,
1 push button= clock
2 set the #s of the time
3 repush the clock button
Jun 24, 2009 | Emerson MW8168B Microwave Oven
Cant figure out how to set the time
1> Press and hold the select button. The setup display appears. 2> Press the select button repeatedly until "CLOCK-ADJ" appears. 3> Press (DSPL). The hour indication flashes. 4> Rotate the volume control dial to set the hour and minute. To move the digital indication, pres (DSPL). 5> Press the select button. The setup is complete and the clock starts. To display the clock, press (DSPL). Press (DSPL) again to return to previous display. The clock uses a 12-hour digital indication.
Jun 15, 2009 | Sony CDX-GT300 CD Player
Cant get the clock to set
most you hold down the time button and push up or down. try something similiar, hold down a button and push an up button? just play with it but don't reset it andcause more problems
Jun 01, 2009 | Pioneer DEH-245 CD Changer
I cant set the clock on the tdk iwave to 12 hour format
hi just wondering if you figured it out considering this was in 2009.. i cant figure it out either
Jan 09, 2009 | Audio Players & Recorders
I believe you have to hold down the display button until the clock blinks, then use the jog wheel.
Dec 01, 2008 | iLO CA3000V CD Player
Clock?
there is a menu button to the right of the radio volume knob. with the radio on push and hold that button then push it until it says set clock or the clock starts flashing. then adjust clock
Aug 15, 2008 | 2006 Jaguar S-Type
Complicated GE clock radio/CD player
To set the time:
Hit the SET Wake/Time Button closest to the CD player until the clock face appears in the bottom left hand of the display.
Use the TRACK Rev Search Fwd Arrows to adjust the time.
Rev will decrease by minutes and Fwd will increase by minutes.
Hope this helps.
Jan 10, 2008 | Audio Players & Recorders
Dont know how to set the clock.
turn your unit off by pressing the SRC button. then press the clock button (clock appears). press the audio (or function button) and then the hour blinks. press up or down to change setting and left or right to switch from hours to minutes. press audio button. wallah!
Jan 21, 2007 | Pioneer DEH-1600 CD Player
Coby CR-A77 Clock Radio Logo
26 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
