Question about Danby DBC2760BLS (5 cu ft) Wine Cooler
HI flashing, fan is running
The wine cooler went from warm to hi flashing. The fan is still running though. What needs replacing?
3 Suggested Answers
  • 883 Answers
SOURCE: too warm
somehow the freon has leaked out, verified by compressor running long times without stopping.
Posted on Jun 08, 2007
  • 1214 Answers
SOURCE: Danby wine cooler is not getting cold. Fan is
Last one of these brought to me had lost it's charge. They are not very well built.
If your within 5 years, take it back to where you bought it. Unit's have a 5 year warranty on the compressor. If the compressor is bad, negotiate trade-in for a newer unit as you can buy a new, better unit for about the same amount of money.
Posted on Dec 11, 2009
One side of my Eurocave SoWine Cooler does not work.
As you must be aware there are individual fans in both the compartments. Check if the fan is running in the compartment not cooling. If not, check the wires / connection of fan or replace the fan.
If the fan is working than the issue may be with the THERMO ELECTRIC ELEMENT. you'll need to replace it.
Sep 09, 2013 | The Wine Enthusiast Wine Enthusiast...
We have a danby dwc283bls wine cooler that no longer cools, and the compressor gets warm (above normal) does it need to be recharged
that's always a possibility but not always the case. The thermostat may not be cycling correctly or set wrong. The condenser could be dirty or if there is a fan, it may not be running. Freeze ups can also cause an "Out of temp." condition. Check it out.
Apr 15, 2010 | Danby DWC283BLS Wine Cooler
Wine Enthusiast 16-bottle thermoelectric wine refrigerator DEAD
usually bad power supply, if the cooling fan isn't running either. These are horribly inefficient coolers that use a lot of power to accomplish little cooling. The power supplies are quite notorious to burn up.
If your supply is 12vdc output, you might be able to replace it with a supply from radio shack. dont use a battery charger though.
Nov 02, 2009 | Refrigerators
The fan went out on our Haier model HVW12ABB, where can I get a replacement? Thank you.
Here is a link to their customer support page. Please let me know if you run into troubble there. Thanks Sea Breeze
Sep 25, 2009 | Haier BC112G Wine Cooler
I just bought a wine cooler not sure where to start to fix it. Fans will not turn on
Hi there.........i take it this is a used / second hand wine cooler......if so you've probably discovered why its been discarded........problem could b due to a faulty compressor unit....the fans are usually wired through the compressor...and run in conjunction with it........if the compressor isnt running then the fans are out .........if the comressor is running then check that there is nothing impeeding the fans rotation.....check for broken or damaged wiring.....check for tampering by someone else....check continuity of wiring through fan coils.........check for faulty starter unit on compressor
regarddss ir Galahad
Aug 12, 2009 | Haier BC112G Wine Cooler
Does not cool the wine,back panel is warm and unit is making a no
If your condensor fan is running and the compressor is running then you will need a tech to look at the sealed system for you.
May 26, 2009 | U-Line 15WC Wine Cooler
WINE COOLER NOISE
when the fan comes on so does the compressor,hold the fan with a rag and see which one is making the noise-mike
Nov 11, 2008 | Danby Silhouette DWC512BL Wine Cooler
Danby wine cooler repair
call Danby at 800 263 2629, you can order parts from them
May 10, 2008 | Danby DWC283BLS Wine Cooler
Too warm
Jun 08, 2007 | Danby DWC440 Wine Cooler
Danby DBC2760BLS (5 cu ft) Wine Cooler Logo
50 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
