Question about Kitchen Ranges
I have a GE Spectra XL44 serial #JGBP35. Burners not lighting oven not heating. +gas and sparks noted when burners turn on but no flame. What's wrong?
  • talk2vy May 19, 2009
    Thank you for your help
  • 355 Answers
It is very rare for gas valves to fail. Most non-ignition problems are due to old igniters which no longer draw enough amperage to allow the gas safety valve to open. You might also consider testing your voltage with a digital meter, as lower voltage will cause ignition problems also. (say 110 volts instead of 120) Replace the igniter.
Posted on May 19, 2009
  • 483 Answers
As per GE no recall on this particular model, and I made a complaint. My two issues were:
1. The element is something that we can check .. if ruined or fried would need replacement.
2. What is "the board"? and this is replaceable by a fairly competent user or a service call?
3. It can be the ignitor as well, Consider replacement as an option.
Thanks
Fame !
Ge Spectra Xl44-three of 4 gas burners will not ignite without a match.
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
May 19, 2010 | GE Spectra JGBP35 Gas Kitchen Range
The oven pilot does not light. The broiler will not work. The only thing that does is the light. GE XL44 range. The burners light and the pilots stay lit.
    If you have standing pilots, make sure the pilot for the oven/broiler is lit as well.  When you turn the thermostat up to call for heat, you should see the pilot get larger. That larger pilot flame heats a hydraulic sensor and opens the main burner valve.
    Jan 10, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
    Xl44 oven burner pulses, doesnt properly heat up.
    it seems the burner in the oven is clogged, by grease, carbon or corrosion, it may need replacing, specialy if this is an older unit
    Jul 30, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
    Getting to the Pilot
    Your model JGBP28DED2WH uses spark ignition on the stove top burners, and a glow bar ignitor, part number WB2X9154 for the oven and broiler. To get to the bake ignitor if oven will not light: Take the racks out of the oven. Remove oven floor by removing two screws at back of oven floor and lifting floor. Remove the square metal flame spreader to get to the burner / ignitor assembly. (note: The ignitor may still glow when you try it, but usually is still the problem)
    Feb 22, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
    GE JGBP34 (XL44) oven won't light
    Look at Lower Igniter
    Check these two Sites here:
    http://www.fixya.com/support/t141325-ge_xl44_range
    and
    http://www.fixya.com/support/t130970-ge_xl44_gas_oven
    I just got this same problem today. Will do the same thing as these guys said in the morning. Good Luck.
    Love these fix-it sites.
    Jan 10, 2009 | GE Spectra JGBP35 Gas Kitchen Range
    Low Heat from GE XL44 gas range
    you can increase the sides of the flames by opening the orifices, if not differences. make the orifices holes a bit bigger, you can have as big of a flame as you want. those orifices are at the connection of the burner with the valve that supplies gas to the burners.
    Dec 08, 2008 | GE Spectra JGBP35 Gas Kitchen Range
    Stove top pilot light
    I have a GE Gas Stove XL44 the stove top buners don't light by themselves without manual lighting. When I turn on the buner knob the buner doesn't click. Also I used my self- cleaning oven for the first time and stopped it before the time was up after that is when the stove top buners wouldn't light by theirselves.
    Jan 20, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
    GE XL44 Gas Stove
    Hi I have a GE X44 gas stove. The 4 top burners work just fine, but the oven no longer turns on. I don't see the blue flame inside the oven. Is it safe to relight the pilot light?????
    Nov 08, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
    Kitchen Ranges Logo
    35 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Paul Carew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
