I bought a 6GB SDHC card. I have a HP Pavillion Lap Top dv2125LA and the driver does not read the SDHC card when I run it into the slot. What can I do. Do I need a new Lap top?
  • 544 Answers
HI,
you can try to reformat the laptop or maybe you nes SDHC card are not comapatible with the software of your laptop.
but i prefer to suggest you that send first your unit to a service center to check it personally and don't just buy a new im sure your problem wil still fix.
any further question please dont hesitate to contact me.
Posted on May 19, 2009
  • Mark Milan silaran
    Mark Milan silaran May 19, 2009
    Please dont forget to rate me sir/mam
    thanks,
Have an HP L7680 all-in-one Just received a Panasonic Limuix camera and cannot read the SDHC memory cards in the SD slot - Printer posts an error
No, it's not possible, it'll never read SDHC in the SD slot. SD slot will only read SD, Mini SD (with adaptor) and Micro SD (with Adaptor). If there's no SDHC card slot, then it doesn't support SDHC Card. The lists of supported memory card are listed below:
CompactFlash™ Type I and II,
Secure Digital/MultiMediaCard/Secure MultiMediaCard (SD),
xD-Picture Card,
Sony Memory Stick®,
MagicGate Memory Stick,
Memory Stick Duo,
Memory Stick Pro
I hope this clears your doubt.
Note: SDHC and SD are different Memory Card types.
Good luck.
Thanks for using FixYa.
Sep 21, 2010 | HP Officejet Pro L7680 All-In-One Printer
Where do i put it in my lap top
It depends on whether your laptop supports SDHC, microSDHC, or neither.
1. Supports MicroSDHC: check on the manual the position of the MicroSDHC slot.
2. Only supports SDHC: you need to purchase an adapter - essentially a full-size SDHC with a slot where the MicroSDHC goes. Plug the micro card in the adapter, plug the adapter+card into the SDHC slot.
3. Neither: you need to purchase both a micro-to-SDHC adapter and a SDHC-to-USB reader (usually SDHC in supported in most "XYZ-in-1 readers", like Quanta 32-in-1 USB reader - check out "SDHC USB reader" in eBay, for example).
Feb 11, 2010 | SanDisk 4GB microSDHC Memory Card
Memory card error for 4GB SDHC card on HP Photosmart printer 2710
Well SD max is 2gb, so you can get 2gb if you want.
SDHC max is 32gb. If you are not on a budget, try upgrading your printer to a newer model.
SDHC is coming out with even newer models, now with a class 10 (10mb read/write speed - but very costly).
However, if it doesn't matter to you, might as well just stick with the same printer, since SD cards are coming down in price. Just make sure you get 2gb cards with a good class speed.
Sep 10, 2009 | HP Photosmart 2710 All-In-One InkJet...
Can't access SDHC card with Rockband 2
Unfortunately, Rock Band 2 came out before the Wii upgrade that allows the use of SDHC cards. Due to the architecture of the Wii which doesn't allow software patches to games, the Rock Band 2 game uses the old drivers that can only read non-SDHC cards.
Unless Harmonix releases a new DVD with the new drivers programmed in, we're out of luck on using SDHC cards with RB2.
May 17, 2009 | Nintendo Rock Band for Wii
SD Slot doesn't work
If the SD card is a high capacity card (SDHC) the SD slot may not be capable of recognizing it. Suggest to try another SD card. If that still doesn't work find the drivers on your laptop manufacturers website.
May 11, 2009 | HP Compaq Presario V2000 Notebook
Just bought 4GB SD card that hx4700 does not recognise - help pse
Your slot in the iPAQ is a SD slot, not a SDHC slot - therefore it will not read the card. Your PC card is probably a dual reader. The SD cards look the same but are different. Have a read of this...
http://en.wikipedia.org/wiki/Secure_Digital_card
Dec 10, 2008 | HP iPAQ HX4700 Pocket PC
Sd Card reader not recognising SDHC cards
When You Insert your SD card into the internal card reader, then the SD card is not recognised by the system and the SD card drive doesn't show there. The problem can be because of driver issue, system issue and device issue.
To fix the problem you need to go at device manager if there is a yelllow sign in SD card controller, the problem is most probably caused by a driver issue. Then you need to update the driver. You can also download the driver for your card reader.
Also, check if your SD Card is broken. You can also check it into different devices port.
If it is detected then you can backup of your data.
If the problem not resolved by any means and you require you SD Card data then I will suggest you read - https://www.stellarinfo.co.in/services/removable-media-recovery.php
Mar 03, 2017 | Computers & Internet
Additional memeory
You might be running into a problem with the new card being a SDHC (Secure Digital High Capacity) card and not just a SD (Secure Digital) card. I have had similar problems with SDHC cards when I put then in older products that have regular SD slots (Photosmart Printer). The cards will still fit into the slots, however the method as to which they are read and written to is different which causes the problem. So, maybe try updating computer hardware drivers or mp3 firmware from the Sansa website. Also, if you can, exchange the 4gb SDHC for a 4gb SD card, this could be a pain in the ****, but this solution should fix your problem definately. Hope some of this helped.
Aug 05, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Problem getting HP Photosmart to recognize digital camera memory card
From what read of the specs, the C6100 does not support SDHC cards, only SD cards. SD cards top out at 2GB; what you have is technically an SDHC (High Capacity) card, which does not work in SD devices.
Jul 22, 2008 | HP Photosmart C6100 All-In-One Printer
SanDisk 4 GB SDHC card won't work in any of my devices
I was having the same problem. It seems that older card readers (2008 and earlier) won't recognize SD cards larger than 2GB. You should first check with your PC mfg., or the card reader mfg. web site to see if there are any firmware or driver updates. If so, update the firmware and drivers and try it again. In my case it worked! Your Blackberry may need a firmware or driver update as well.
Jun 02, 2008 | Electronics - Others
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
